Positive Thermal Coefficent Diodes
SMD2920P030~300 Series
The SMD2920 Series PTC provides surface mount overcurrent protection for applications where space is at a
premium and resettable protection is desired.
Features
• RoHS compliant, lead-free and halogen-free
• Fast response to fault currents
• Compact design saves board space
• Low resistance
• Low-profile
• Compatible with high temperature solders
ROHS
Applications
• USB peripherals
• Disk drives
• CD-ROMs
• Plug and play protection for motherboards
and peripherals
• Mobile phones - battery and port protection
• Disk drives
• PDAs / digital cameras
• Game console port protection
Dimension
MARKING CODE VARIES
WITH AMPERAGE RATING
(See Electrical Characteristic Table)
SHOWN IS 1.0AMP RATING
2.3 ± 0.1
A
N
B
C
N
Bottom
View
5.6± 0.1
Top
View
Side
View
5.1 ± 0.1
D
Bottom
View
N
Type Number
2.3 ± 0.1
A
B
C
D
Min.
Max.
Min.
Max.
Min.
Max.
Min.
SMD2920P030TF
6.73
7.98
4.80
5.44
0.60
1.15
0.30
SMD2920P050TF
6.73
7.98
4.80
5.44
0.60
1.15
0.30
SMD2920P075TF
6.73
7.98
4.80
5.44
0.60
1.15
0.30
SMD2920P075TF/60
6.73
7.98
4.80
5.44
0.60
1.15
0.30
SMD2920P100TF
6.73
7.98
4.80
5.44
0.40
1.00
0.30
SMD2920P125TF
6.73
7.98
4.80
5.44
0.40
0.90
0.30
SMD2920P150TF
6.73
7.98
4.80
5.44
0.40
0.90
0.30
SMD2920P185TF
6.73
7.98
4.80
5.44
0.30
0.90
0.30
D
E
SMD2920P200TF
6.73
7.98
4.80
5.44
0.30
0.90
0.30
SMD2920P200TF/24
6.73
7.98
4.80
5.44
0.30
0.90
0.30
SMD2920P250TF
6.73
7.98
4.80
5.44
0.30
0.90
0.30
SMD2920P260TF
6.73
7.98
4.80
5.44
0.30
0.90
0.30
SMD2920P300TF
6.73
7.98
4.80
5.44
0.30
0.90
0.30
SMD2920P300TF/15
6.73
7.98
4.80
5.44
0.30
0.90
0.30
All data is subject to change,Please check our data sheets at www ruilon com for updates.
©2012 RuiLong Yuan,Inc.
PTC 01
Electriacl Characteristics
Type Number
Ihold
Itrip
Vmax
Imax
Pd
max.
(A)
(A)
V(dc)
(A)
(W)
SMD2920P030TF
0.30
0.60
60
100
1.5
SMD2920P050TF
0.50
1.00
60
100
1.5
Maximum Time
To Trip
Current
Time
(A)
(Sec.)
1.50
3.00
2.50
4.00
Resistance
Rmin
(Ω)
R1max
(Ω)
0.180
1.400
0.600
4.800
SMD2920P075TF
0.75
1.50
33
100
1.5
8.00
0.30
0.100
1.000
SMD2920P075TF/60
0.75
1.50
60
100
1.5
8.00
0.30
0.065
1.000
SMD2920P100TF
1.10
2.20
33
100
1.5
8.00
0.50
0.065
0.410
SMD2920P125TF
1.25
2.50
33
100
1.5
8.00
2.00
0.050
0.250
SMD2920P150TF
1.50
3.00
33
100
1.5
8.00
2.00
0.035
0.230
SMD2920P185TF
1.85
3.70
33
100
1.5
8.00
2.50
0.030
0.150
SMD2920P200TF
2.00
4.00
16
100
1.5
8.00
4.50
0.020
0.120
SMD2920P200TF/24
2.00
4.00
24
100
1.5
8.00
4.50
0.020
0.120
SMD2920P250TF
2.50
5.00
16
100
1.5
8.00
16.00
0.020
0.085
SMD2920P260TF
2.60
5.20
6
100
1.5
8.00
10.00
0.014
0.075
SMD2920P300TF
3.00
6.00
6
40
1.5
8.00
20.00
0.012
0.048
SMD2920P300TF/15
3.00
6.00
16
100
1.5
8.00
20.00
0.012
0.048
Ihold = Hold current: maximum current device will pass without tripping in 20°C still air.
Itrip = Trip current: minimum current at which the device will trip in 20°C still air.
Vmax = Maximum voltage device can withstand without damage at rated current (Imax)
Imax = Maximum fault current device can withstand without damage at rated voltage (Vmax)
Pd = Power dissipated from device when in the tripped state at 20°C still air.
Rmin = Minimum resistance of device in initial (un-soldered) state.
Thermal Derating Chart-IH(A)
Type number
-40℃
-20℃
0℃
23℃
40℃
50℃
60℃
70℃
85℃
SMD2920P030TF
0.45
0.40
0.35
0.30
0.25
0.23
0.20
0.17
0.14
SMD2920P050TF
0.76
0.67
0.59
0.50
0.42
0.38
0.33
0.29
0.23
SMD2920P075TF
1.13
1.01
0.88
0.75
0.62
0.56
0.50
0.44
0.34
SMD2920P075TF/60
1.13
1.01
0.88
0.75
0.62
0.56
0.50
0.44
0.34
SMD2920P100TF
1.66
1.47
1.29
1.10
0.91
0.83
0.73
0.64
0.50
SMD2920P125TF
1.89
1.68
1.46
1.25
1.04
0.94
0.83
0.73
0.56
SMD2920P150TF
2.27
2.01
1.76
1.50
1.25
1.13
1.00
0.87
0.74
SMD2920P185TF
2.80
2.47
2.17
1.85
1.54
1.39
1.22
1.07
0.85
SMD2920P200TF
3.02
2.68
2.34
2.00
1.66
1.50
1.32
1.16
0.90
SMD2920P200TF/24
3.02
2.68
2.34
2.00
1.66
1.50
1.32
1.16
0.90
SMD2920P250TF
3.78
3.35
2.93
2.50
2.08
1.88
1.65
1.45
1.13
SMD2920P260TF
3.64
3.25
2.91
2.60
2.26
2.08
1.95
1.74
1.13
SMD2920P300TF
4.53
4.02
3.51
3.00
2.52
2.26
1.99
1.75
1.34
SMD2920P300TF/15
4.53
4.02
3.51
3.00
2.52
2.26
1.99
1.75
1.34
Thermal Deratin g Cu r v e
Typ ical Time-To-Tri p At 25° C
Derating Curves for SMD Series
Average Time Current Curves
100
160
0.50A
0.75A
140
Percentage of Derated
Current
1.00A
120
1.25A
Time In Seconds
10
100
80
60
40
1.5A
1.85A
1
2.0A
2.5A
2.6A
0.1
0.3A
-20
Temperature (°C)
PTC 02
3.00A
60
80
0.01
0.1
1
Current In Amperes
10
100
Temperature(°C)
Recommended Solder Reflow Conditions
300
250
200
190
160
100
Preheating
Soldering
Cooling
60-120
sec.
30-60
sec.
120
sec.
Tape And Reel Specifications (mm)
Governing Specifications
W
P0
P1
P2
A0
B0
B1max.
D0
F
E1
E2min.
Tmax.
T1max.
K0
Leader min.
Trailer min.
Reel Dimensions
A max.
N min.
W1
W 2max.
EIA 481-2
16.0 ± 0.3
4.0 ± 0.10
8.0 ± 0.10
2.0 ± 0.05
5.70 ± 0.10
8.00 ± 0.10
12.1
1.5 + 0.1, -0
7.5 ± 0.05
1.75 ± 0.10
14.25
0.6
0.1
0.80 ± 0.1
390
160
•Recommended reflow methods:IR, vapor phase oven, hot air oven.
•Devices are not designed to be wave soldered to the bottom side
of the board.
•Recommended maximum paste thickness is 0.25 mm (0.010 inch).
•Devices can be cleaned using standard method and solvents.
Note:If reflow temperatures exceed the recommended profile,
devices may not meet the performance requirements.
EIA Tape Component Dimentions
P0
T
• Storage conditions:40°C max, 70% R.H.
• Devices may not meet specified performance
if storage conditions are exceeded.
Order Information
E1
A0
B1
F
K0
B0
T1
P1
W
E2
EIA Reel Dimentions
W2(measured at hub)
A
N(hub dia.)
Cover tape
W1(measured at hub)
Carrier tape
Embossed cavity
SMD2920
Product name
050L
Hold
Size 7555mm/2920 mils
Current
0.50A
SMD:surface mount device
Tape & reel packaging per EIA481-1
Embossment
P2
Cover tape
178
60
16.4 + 2.0, -0.0
22.4
Storage And Handling
D0
Packaging
Tape & Reel Quantity
2,000 pcs/reel
4
PTC 03
RUILONG.YUAN CO.,LTD
Tel: +86- 0755-82908296
Fax: +86- 0755-82908002
Email: jack@ruilon.com
Website: http://www.ruilon.com
RuiLongYuan Electronics are trademarks.
Information furnished is believed to be accurate and reliable. However, users should independently evaluate the suitability of and test each
product selected for their own applications. RUILONYUAN Electronics reserves the right to change or update, without notice, any information
contained in this publication; to change, without notice, the design, construction, processing, or specification of any product; and to discontinue
or limit production or distribution of any product. This publication supersedes and replaces all information previously supplied. Without
expressed or written consent by an officer of RUILONYUAN Electronics, RUILONYUAN Electronics does not authorize the use of any of its
products as components in nuclear facility applications, aerospace, or in critical life support devices or systems. RUILONYUAN Electronics
expressly disclaims all implied warranties regarding the information contained herein, including, but not limited to, any implied warranties of
merchantability or fitness for a particular purpose. RUILONYUAN Electronics’ only obligations are those in the RUILONYUAN Electronics
Standard Terms and Conditions of Sale and in no case will RUILONYUAN Electronics be liable for any incidental, indirect, or consequential
damages.
PTC 04
很抱歉,暂时无法提供与“SMD2920P185TF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.75811
- 50+0.62022
- 150+0.55127
- 1500+0.43554
- 3000+0.39419
- 4500+0.37347
- 国内价格
- 5+0.75050
- 50+0.61400
- 150+0.54580
- 1500+0.43120
- 国内价格
- 5+0.66685
- 50+0.54556
- 300+0.48491
- 600+0.47764
- 1500+0.38311
- 国内价格
- 1+0.60384
- 50+0.40293
- 1500+0.36408
