ASMD1812-300
ASMD1812-300
    JDTFUSE(集电通)
    ASMD1812系列 表面安装PTC器件 FUSE1812 8V
ASMD1812-300 数据手册
PRODUCT DATASHEET ASMD1812 Series Surface Mount PTC Devices ASMD1812 Series Surface Mount PTC Devices Description The ASMD1812 series provides surface mount resettable overcurrent protection with holding current from 0.1A to 3.5A. This series offers complete portfolio in terms of holding current and working voltage, and is suitable for wide range of applications. Features ● RoHS compliant and lead-free ● Low profile ● Halogen-free ● Fast response to fault current ● Compact design saves board space ● Compatible with high temperature solders Agency Approvals Agency Applications File Number pending pending ● USB hubs, ports and peripherals ● Motherboard USB & IEEE 1394 protection ● Set-top-box and HDMI ● Optical disk drives ● Game console port protection General electronics Regulation Standard 2002/95/EC EN14582 JDT FUSE Industrial Corp. www.jdtfuse.com Page 1/7 ASMD1812 Series Surface Mount PTC Devices Performance Specification Model V max (V dc) I max (A) I hold I trip Maximum Time To Trip Pd @25°C (A) @25°C (A) Typ. (W) Resistance Current (A) Time (Sec) R i min R1max (Ω) (Ω) ASMD1812-010 30.0 100 0.10 0.30 0.8 0.5 1.50 0.750 15.000 ASMD1812-014 60.0 100 0.14 0.34 0.8 1.5 0.15 0.650 6.000 ASMD1812-020 30.0 100 0.20 0.40 0.8 8.0 0.02 0.350 5.000 ASMD1812-030 30.0 100 0.30 0.60 0.8 8.0 0.10 0.250 3.000 ASMD1812-050 15.0 100 0.50 1.00 0.8 8.0 0.15 0.150 1.000 ASMD1812-050-30 30.0 100 0.50 1.00 0.8 8.0 0.15 0.150 1.000 ASMD1812-050-60 60.0 100 0.50 1.00 0.8 8.0 0.15 0.150 1.400 ASMD1812-075 13.2 100 0.75 1.50 0.8 8.0 0.20 0.090 0.450 ASMD1812-110 8.0 100 1.10 2.20 0.8 8.0 0.30 0.050 0.250 ASMD1812-110-16 16.0 100 1.10 2.20 0.8 8.0 0.30 0.050 0.250 ASMD1812-125 16.0 100 1.25 2.50 0.8 8.0 0.40 0.050 0.140 ASMD1812-150 8.0 100 1.50 3.00 0.8 8.0 0.50 0.040 0.160 ASMD1812-150-16 16.0 100 1.50 3.00 0.8 8.0 0.50 0.040 0.160 ASMD1812-160 8.0 100 1.60 2.80 0.8 8.0 1.00 0.030 0.130 ASMD1812-200 8.0 100 2.00 4.00 0.8 8.0 2.00 0.020 0.100 ASMD1812-260 8.0 100 2.60 5.00 0.8 8.0 2.50 0.015 0.050 ASMD1812-300 8.0 100 3.00 5.00 0.8 8.0 4.00 0.012 0.040 ASMD1812-350 6.0 100 3.50 6.00 2.0 10.0 4.00 0.008 0.030 I hold = Hold Current. Maximum current device will not trip in 25°C still air. I trip = Trip Current. Minimum current at which the device will always trip in 25°C still air. V max = Maximum operating voltage device can withstand without damage at rated current (Imax). I max = Maximum fault current device can withstand without damage at rated voltage (V max). Pd = Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage. Ri min/max Test= Minimum/Maximum device resistance prior to tripping at 25°C. R1max = Maximum device resistance is measured one hour post reflow. CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame. Environmental Specifications Conditions Resistance change Passive aging +85°C, 1000 hrs. ±5% typical Humidity aging +85°C, 85% R.H. , 168 hours ±5% typical Thermal shock +85°C to -40°C, 20 times ±33% typical Resistance to solvent MIL-STD-202,Method 215 No change Vibration MIL-STD-202,Method 201 No change   Ambient operating conditions : - 40 °C to +85 °C Maximum surface temperature of the device in the tripped state is 125 °C JDT FUSE Industrial Corp. www.jdtfuse.com Page 2/7 ASMD1812 Series Surface Mount PTC Devices Thermal Derating Curve Percentage of Derated Current Derating Curves for ASMD1812 Series 160 140 120 100 80 60 40 20 0 -40 -20 0 20 40 60 80 Temperature (°C ) Average Time-Current Curve 100 0.30A TIME IN SECOND 0.50A 0.75A 10 1.00A 1.25A 1.50A 1 1.85A 2.0A 2.50A 0.1 2.60A 3.00A 3.50A 0.01 0.1 1 10 100 CURRENT IN AMPERES JDT FUSE Industrial Corp. www.jdtfuse.com Page 3/7 ASMD1812 Series Surface Mount PTC Devices Thermal Derading Chart Maximum ambient operating temperature (Tmao) vs. hold current (Ihold) Model - 40°C - 20°C 0°C 25°C 40°C 50°C 60°C 70°C 85°C ASMD1812-010 0.16 0.14 0.12 0.10 0.08 0.07 0.06 0.05 0.03 ASMD1812-014 0.23 0.19 0.17 0.14 0.12 0.10 0.09 0.08 0.06 ASMD1812-020 0.29 0.26 0.23 0.20 0.17 0.15 0.14 0.12 0.10 ASMD1812-030 0.44 0.39 0.35 0.30 0.26 0.23 0.21 0.18 0.15 ASMD1812-050 0.59 0.57 0.55 0.50 0.45 0.43 0.35 0.30 0.23 ASMD1812-075 1.10 0.99 0.87 0.75 0.63 0.57 0.49 0.45 0.35 ASMD1812-110 1.60 1.45 1.28 1.10 0.92 0.83 0.71 0.66 0.52 ASMD1812-110-16V 1.59 1.44 1.27 1.10 0.92 0.82 0.70 0.64 0.50 ASMD1812-125 2.00 1.75 1.52 1.25 1.00 0.95 0.90 0.75 0.53 ASMD1812-150 2.30 2.05 1.77 1.50 1.23 1.09 0.95 0.82 0.61 ASMD1812-150-16V 2.28 2.03 1.75 1.50 1.21 1.07 0.93 0.79 0.58 ASMD1812-160 2.10 1.96 1.88 1.60 1.26 1.12 0.98 0.84 0.63 ASMD1812-200 2.88 2.61 2.25 2.00 1.80 1.66 1.45 1.09 0.80 ASMD1812-260 3.90 3.42 2.96 2.60 2.33 2.07 1.94 1.35 1.00 ASMD1812-300 4.15 3.76 3.46 3.00 2.55 2.28 2.01 1.61 1.33 ASMD1812-350 4.84 4.39 4.04 3.50 2.98 2.66 2.35 1.88 1.55 Soldering Parameters TP 20~40 S TP 260 Ramp-up Profile Feature Critical Zone TL to TP TL 217 tL Tsmax Temperature (°C ) Preheat Tsmin Ramp-down ts Preheat 60~180 s 25 3℃/second mac. (Ts max to T p) 60~150 s 200 150 Average Ramp-Up Rate Pb-Free Assembly t 25°C to peak Time Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free Recommended maximum paste thickness is 0.25mm Devices can be cleaned using standard industry methods and solvents. Note 1:All temperature refer to topside of the package, measured on the package body surface. Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements. JDT FUSE Industrial Corp. www.jdtfuse.com -Temperature Min(Ts min) 150℃ -Temperature Max(Ts max) 200℃ -Time(Ts min to Ts max) 60~180 seconds Time maintained above: -Temperature(TL) 217℃ -Time(tL) 60~150 seconds Peak Temperature(Tp) 260℃ Ramp-Down Rate 6℃/second max. Time 25℃ to Peak Temperature 8 minutes max Storage Condition 0℃~35℃,≤70%RH Page 4/7 ASMD1812 Series Surface Mount PTC Devices Physical Dimensions(mm.) A Model B C D E Min. Max. Min. Max. Min. Max. Min. Min. ASMD1812-010 4.37 4.73 3.07 3.41 0.50 1.00 0.30 0.25 ASMD1812-014 4.37 4.73 3.07 3.41 0.50 1.00 0.30 0.25 ASMD1812-020 4.37 4.73 3.07 3.41 0.50 1.30 0.30 0.25 ASMD1812-030 4.37 4.73 3.07 3.41 0.50 1.00 0.30 0.25 ASMD1812-050 4.37 4.73 3.07 3.41 0.40 0.90 0.30 0.25 ASMD1812-050-30V 4.37 4.73 3.07 3.41 0.70 1.30 0.30 0.25 ASMD1812-050-60V 4.37 4.73 3.07 3.41 1.10 1.80 0.30 0.25 ASMD1812-075 4.37 4.73 3.07 3.41 0.40 0.90 0.30 0.25 ASMD1812-110 4.37 4.73 3.07 3.41 0.40 0.90 0.30 0.25 ASMD1812-110-16V 4.37 4.73 3.07 3.41 0.60 1.30 0.30 0.25 ASMD1812-125 4.37 4.73 3.07 3.41 0.60 1.30 0.30 0.25 ASMD1812-150 4.37 4.73 3.07 3.41 0.40 1.20 0.30 0.25 ASMD1812-150-16V 4.37 4.73 3.07 3.41 0.40 1.20 0.30 0.25 ASMD1812-160 4.37 4.73 3.07 3.41 0.40 1.20 0.30 0.25 ASMD1812-200 4.37 4.73 3.07 3.41 0.50 1.30 0.30 0.25 ASMD1812-260 4.37 4.73 3.07 3.41 0.50 1.50 0.30 0.25 ASMD1812-300 4.37 4.73 3.07 3.41 0.50 1.50 0.30 0.25 ASMD1812-350 4.37 4.73 3.07 3.41 0.50 1.50 0.30 0.25 Termination Pad Characteristics Terminal pad materials:Tin-plated Nickel-Copper Terminal pad solder ability:Meets EIA specification RS186-9E and ANSI/J-STD-002 Category 3. Packaging Quantity and Marking 3.2±0.1 Part Number 3.2±0.1 SMD812 Series Quantity 1,500 pcs/reel Tape & reel packaging per EIA481-1 1.78±0.1 JDT FUSE Industrial Corp. www.jdtfuse.com 1.78±0.1 Page 5/7 ASMD1812 Series Surface Mount PTC Devices Tape And Reel Specifications (mm) Governing Specifications EIA 481-1 W 12 ± 0.3 P0 4.0 ± 0.10 P1 8.0 ± 0.10 P2 2.0 ± 0.05 A0 3.5 ± 0.10 B0 5.1 ± 0.10 B1max. 5.9 D0 1.50 + 0.1, -0 F 5.5 ± 0.05 E1 1.75 ± 0.10 E2min. 10.25 T 0.6 T1max. 0.1 K0 0.9 ± 0.1 Leader min. 390 Trailer min. 160 Reel Dimensions   A max. 178 N min. 60 W1 12.4 ± 0.5 W2 18.4 Storage And Handling ● Storage conditions:40°C max, 70% R.H. ● Devices may not meet specified performance if storage conditions are exceeded.Technology Corp. JDT FUSE Industrial Corp. www.jdtfuse.com P1 P2 D0 P0 E1 F W T D2 K0 A0 B0 H W4 W3 D C W2 W F W1 H1 Page 6/7 ASMD1812 Series Surface Mount PTC Devices Part Number System ASMD 1812 - Special Voltage Rating(Optional) Holding Current Rating Device Dimensions: Length/width(Unit:1/100 inch) Size 4532 mm / 1812 inch Surface Mount Device Cross Reference Cross Reference Model Tyco / PolySwitch® Littelfuse / POLY-FUSE® Polytronics / EVERFUSE® ASMD1812-010 miniSMDC010F 1812L010 SMD1812P010TF ASMD1812-014 -miniSMDC014F 1812L014 SMD1812P014TF ASMD1812-020 miniSMDC020F 1812L020 SMD1812P020TF ASMD1812-030 - 1812L035 SMD1812P030TF ASMD1812-050 miniSMDC050F 1812L050 SMD1812P050TF ASMD1812-050-30V miniSMDC050F 1812L050/30 SMD1812P050TF/30 ASMD1812-050-60V - - - ASMD1812-075 miniSMDC750F 1812L075 SMD1812P075TF ASMD1812-110 miniSMDC110F 1812L110 SMD1812P110TF ASMD1812-110-16V miniSMDC110F/16 1812L110/16 SMD1812P110TF/16 ASMD1812-125 miniSMDC125F 1812L125 SMD1812P125TF ASMD1812-150 miniSMDC150F 1812L150 SMD1812P150TF ASMD1812-150-16V miniSMDC150F/12 1812L150/12 SMD1812P150TF/12 ASMD1812-160 miniSMDC160F 1812L160 SMD1812P160TF ASMD1812-200 miniSMDC200F 1812L200 SMD1812P200TF ASMD1812-260 miniSMDC260F 1812L260 SMD1812P260TF ASMD1812-300 miniSMDC300F 1812L300 SMD1812P300TF ASMD1812-350 - - - “PolySwitch” is a registered trademark of Tyco Electronics. “POLY-FUSE” is a registered trademark of Littelfuse,Inc. “EVERFUSE” is a registered trademark of Polytronics Technology Corp. JDT FUSE Industrial Corp. www.jdtfuse.com Page 7/7
ASMD1812-300
1. 物料型号:通常指的是保险丝的具体型号,例如ASMD1812,这是一个贴片式自恢复保险丝的型号。
2. 器件简介:自恢复保险丝是一种过流保护元件,能够在电路出现过电流时自动断开,当过电流消失后又能自动恢复导电,从而保护电路不受损害。
3. 引脚分配:对于贴片式保险丝,通常没有引脚,而是通过焊接在电路板上的焊盘来连接电路。
4. 参数特性:包括最大工作电压、最大工作电流、保持电流(保险丝动作的最小电流)、断路电流(保险丝断开的最大电流)等。
5. 功能详解:自恢复保险丝的主要功能是在电路出现过电流时提供保护,避免电路因过流而损坏。
6. 应用信息:广泛应用于各种电子设备中,如手机、电脑、家用电器等,用于保护电路免受过电流的损害。
7. 封装信息:ASMD1812是一种贴片封装,尺寸为1812(长1.8mm,宽1.2mm),适用于自动贴装。
ASMD1812-300 价格&库存
很抱歉,暂时无法提供与“ASMD1812-300”相匹配的价格&库存,您可以联系我们找货
ASMD1812-300
  • 5+0.54611
  • 50+0.43662
  • 150+0.38187
  • 1500+0.33217
  • 3000+0.29928
  • 4500+0.28285
库存:1193
ASMD1812-300
  • 10+0.44175
  • 100+0.41325
  • 500+0.38475
  • 2000+0.34200
  • 5000+0.32775
  • 10000+0.31920
