PRODUCT DATASHEET
Nano Fuse
JFC2410 快断
JFC2410 快断
SCOPE
Agency Approvals
AGENCY
AGENCY FILE NUMBER
E486200
Notebook PC
LCD/PDF TV
LCD/PDP panel
LCD monitor
LCD backlight inverter
Portable DVE player
Power supply
Networking
PC server
Cooling fan system
Storage system
Telecom system
Wireless base station
White goods
Game console
Automotive
Battery charging circuit
Office Automation
Industrial equipment
Medical equipment
PART NUMBERING
JF C xxxx - xxxx F S
S=SMD
T=Time-Lag
F=Fast Acting
四位电流
四位体积
C=Ceramic
T=Thin Film
H=High Temperature Ceramic Series
JF=JDT Fuse
JDT FUSE Electronics Corp.
www.jdtfuse.com
Page 1/6
JFC2410 快断
RATED CURRENT AND RATED VOLTAGE
● Rated Current 10mA━30A
● Rated Voltage 250V AC ( 20A-30A:72V AC )
MARKING
The fuses shall have the following marking
● Manufacturing factory mark &logo :
● Rated Current(A):_mA / _A
● Electrical characteristics: F
Note
There is no provision on label size and position
APPEARANCES AND CONFIGURATION
● Appearance : No significant stains, rust or crack,
mark should be easy to recognize.
● Shape: Surface Mount Fuse
Performance Specification
Part Number
Rated
Current
(A)
JFC2410-0100FS
Nominal Cold
Resistance
(ohms)
Nominal
Melting
I2t (A2sec)
0.10
3.1000
0.00138
JFC2410-0500FS
0.50
0.4200
0.0795
JFC2410-0750FS
0.75
0.2450
0.185
JFC2410-1100FS
1.00
0.1530
0.459
JFC2410-1150FS
1.50
0.0630
0.853
JFC2410-1200FS
2.00
0.0367
0.530
JFC2410-1250FS
2.50
0.0286
1.029
JFC2410-1300FS
3.00
0.0227
1.650
JFC2410-1350FS
3.50
0.0200
2.469
JFC2410-1400FS
4.00
0.0160
3.152
JFC2410-1500FS
5.00
0.0125
5.566
JFC2410-1600FS
6.00
0.0108
8.670
JFC2410-1630FS
6.30
0.0096
9.170
JFC2410-1700FS
7.00
0.0090
10.32
JFC2410-1800FS
8.00
0.0077
20.23
JFC2410-2100FS
10.0
0.0056
26.46
JFC2410-2120FS
12.0
0.0049
47.97
JFC2410-2150FS
15.0
0.0037
97.82
JFC2410-2200FS
20.0
0.0023
210
JFC2410-2250FS
25.0
0.0017
400
JFC2410-2300FS
30.0
0.0012
900
www.jdtfuse.com
Max
Voltage
Rating(V)
250V
72V
Interrupting
Rating
50A@250V
500A@72V
Page 2/6
JFC2410 快断
OUTLINE DRAWING AND STRUCTURE
● Outline Drawing and dimensions (unit : mm)
2.6±0.2
1.4±0.1
2.6±0.2
6.10 ± .20
① Cap
② Ceramic tube
● Structure
NO.
Component
Material
Quantity
①
Cap
Silver Plated Brass
2
②
Body
Ceramic tube
1
PRODUCT CHARACTERISTICS
No.
Item
Contain
1
Insulation Resistance
10,000 ohms minimum
2
Solderability
3
Resistance to Soldering
Heat
4
Thermal Shock
5
Mechanical Shock
6
Vibration
7
Moisture Resistance
8
Salt spray
T=235℃±5℃, t=5+0/-0.5s, Cover≧95%
Reference standard
MIL-STD-202G, Method 302 Test ConditionA
MIL-STD-202G, Method 208H
10 sec at 260℃
MIL-STD-202G, Method 210F Test Condition B
5 cycles, -65℃ to 125℃,
15minutes @each extreme
MIL-STD-202G, Method 107G Test Condition B
100G’s peak for 6
milliseconds, 3 cycles
MIL-STD-202G, Method 213B Test 1
0.03” amplitude, 10-55 Hz in
1 min. 2hrs each XYZ=6hrs
MIL-STD-202G, Method 201A
10 cycles
MIL-STD-202G, Method 106G
48hrs
MIL-STD-202G, Method 101E Test Condition B
ELECTRICAL CHARACTERISTICS
● Pre-Arcing Time / Current Characteristics:
Ampere Rating
% of Ampere Rating
Opening Time
100%
4 hours, Minimum
200%
5 sec, Maximum
10mA – 30A
● Breaking Capacity
10mA-15A : 50A@250V AC/50A@125V AC
20A-30A:500A@72V AC
www.jdtfuse.com
Page 3/6
JFC2410 快断
ENVIRONMENTAL CHARACTERISTIC
● Operating temperature range : -55℃ to 125℃
● Company operating temperature of the environment more than 25+/-5℃, in the selection of
fuse specifications, it needs to consider the impact of the operating environment of the
temperature fuse. Photo: temperature derating curve.
Temperature Rerating Curve
Test
.062A
.125A
.160A
.200A
.250A
.315A
.375A
.500A
.750A
1A
1.5A
2A
2.5A
3A
3.5A
4A
5A
7A
8A
10A
12A
15A
Average Time-Current Curve
100
TIME IN SECONDS
10
1
0.1
0.01
0.001
0.05 0.1
1
10
100
1000
CURRENT IN AMPERES
www.jdtfuse.com
Page 4/6
JFC2410 快断
INSTALLATION WAY AND PARAMETERS
● Propose that the following picture installation way is installed and satisfied the required size.
6.86
3.15
Recommended pad layout
2.95
1.96
● Recommended Customer Soldering Parameters
TP 20~40 S
TP 260
Ramp-up
Critical Zone
TL to TP
TL 217
tL
Tsmax
60~150 s
Temperature (°C )
200
Tsmin
Ramp-down
150
ts
Preheat 60~180 s
25
t 25°C to peak
Time
Reflow Condition
Preheating
Soldering
www.jdtfuse.com
Pb-Free assembly
Temperature Min Ts(min)
150℃
Temperature Max Ts(man)
200℃
Time Max
120 secs
Temperature (TL)(Liquidus)
260℃
Time Max (TL)
60 secs
Temperature (TP)
Max 260℃
Time Max (TP)
10 secs
Page 5/6
JFC2410 快断
OTHER NOTICE IN USED
● It could be in conformance with another file which made by our company.
PACKING
● Packing Quantity
● 1000 fuses each disc
OTHERS
● If in use beyond the requirements of the specifications, must pass through the mutual confirmation !
● If the specification is not appropriate, must through consultation between the two sides and by the company to modify.
www.jdtfuse.com
Page 6/6
很抱歉,暂时无法提供与“JFC2410-1300FS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.46323
- 100+0.37199
- 300+0.32637
- 1500+0.28465
- 4500+0.25728
- 10500+0.24359
- 国内价格
- 10+0.45610
- 100+0.36180
- 300+0.31680
- 1500+0.27620
- 4500+0.24960
- 10500+0.23630
- 国内价格
- 5+0.34000
- 20+0.31000
- 100+0.28000
- 500+0.25000
- 1000+0.23600
- 2000+0.22600
- 国内价格
- 1+0.41470
- 50+0.24310
- 1500+0.22000
