BSD3C(A)XX1V
Transient Voltage Suppressors
ROHS
Features
500 Watts Peak Pulse Power per Line (tp = 8/20μs)
Replacement for MLV (0805)
Unidirectional & Bidirectional Configurations
Protects one I/O or power line
Low Clamping Voltage
Working Voltage: 3.3V, 5V, 12V, 15V and 24V
Low Leakage Current
Response Time is Typically < 1 ns
IEC COMPATIBILITY (EN61000-4)
IEC 61000-4-2 (ESD) ±15kV (air), ±8kV (contact)
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 24A (8/20μs)
Applications
Mechanical Characteristics
JEDEC SOD-323 package
Molding compound flammability rating:
UL 94V-0
Marking: Marking Code
Packaging: Tape and Reel per EIA 481
RoHS/WEEE Compliant
Laptop Computers
Cellular Phones
Digital Cameras
Personal Digital Assistants (PDAs)
Schematic & PIN Configuration
1
2
Bidirectional
2
1
Unidirectional
1/4
BSD3C(A)XX1V
ROHS
Absolute Maximum Rating
Rating
Symbol
Value
Units
Unidirectional Peak Pulse Power(tp =8/20μs)-See Figure 1
PPP
500
Watts
Bidirectional Peak Pulse Power(tp =8/20μs)-See Figure 1
Ppp
400
Watts
Operating Temperature
TJ
-55 to + 125
°C
TSTG
-55 to +150
°C
Storage Temperature
Electrical Parameters(T=25°C)
Symbol
Parameter
IPP
IF
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
I
Working Peak Reverse Voltage
Test Current
IF
Forward Current
VF
Forward Voltage @ IF
V
IR VF
IT
Breakdown Voltage @ IT
IT
Bidirectional
IT
IR
VC VBR VRWM
Maximum Reverse Leakage Current @ VRWM
Unidirectional
VRWMVBR VC
IPP
Electrical Characteristics
Reverse
Stand off
Voltage
VRWM
Minimum
Breakdown
Voltage
VBR@1mA
Maximum
Clamping
Voltage
Vc @IPP
Maximum
Peak Pulse
Current
Ipp
Maximum
Reverse
Leakage
IR@VRWM
Typical
Capacitance
DC=0V
CJ@ 1 MHz
(Volts)
(Volts)
(Volts)
(Amps)
(μA)
(pF)
BSD3A031V
3.3
4.0
17
27
70
200
BSD3C031V
3B
4.0
18
25
70
100
BSD3A051V
05
6.0
1
150
BSD3C051V
5B
6.0
24
75
BSD3A121V
12
13.3
35
15
1
50
BSD3C121V
12B
13.3
39
12
1
25
BSD3A151V
15
16.7
42
12
1
40
BSD3C151V
15B
16.7
55
9
1
BSD3A241V
24
26.7
60
8
1
30
BSD3C241V
24B
26.7
67
6
1
15
Part Number
2/4
BSD3C(A)XX1V
ROHS
Typical Characteristics
Figure 2: Power Derating Curve
10
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power vs. Pulse Time
500W 8/20µs
Waveform
1
0.1
110
100
90
80
70
60
50
40
30
0.1
1
10
100
td – Pulse Duration - µs
25
50
75
100
125
Ambient Temperature - TA (℃)
Figure 4: Normalized Junction Capacitance
vs. Reverse Voltage
Figure 3: Clamping Voltage vs. Peak Pulse
Current
1.1
80
1.0
F=1MHz
0.9
60
Cj(VR)/Cj(VR=0)
Clamping Voltage -Vc(V)
150
40
0.8
0.7
0.6
0.5
0.4
0.3
0.1
4
6
8
10
12
Peak Pulse Current -Ipp(A)
12
18
24
30
Reverse Voltage -VR(V)
Figure 5: Pulse Waveform
tr=8µs
110
Waveform
Paramters
tr=8µs
td=20µs
100
Percent Ipp
90
80
70
60
50
40
Half Value Ipp/2
30
td=20µs
10
10
15
30
Time (µs)
3/4
BSD3C(A)XX1V
ROHS
Outline Drawing – SOD323
PACKAGE OUTLINE
C
A
B
E
1
DIMENSIONS
2
SYMBOL
D
F
H
L
L1
3.000
A
B
C
D
E
F
L
L1
H
MILLIMETER
INCHES
MIN
MAX
1.600 1.800
0.250 0.350
2.500 2.700
1.000
1.200 1.400
0.080 0.150
0.475 REF
0.250 0.400
0.000 0.100
MIN
MAX
0.063 0.071
0.010 0.014
0.098 0.106
0.039
0.047 0.055
0.003 0.006
0.019 REF
0.010 0.016
0.000 0.004
Notes
1. Controlling Dimensions inMillimeters.
2. Dimensions are exclusive of mold flash and metal burrs.
0.800
0.800
DIMENSIONS: MILLIMETERS
Marking Codes
Part Number
BSD3A031V
BSD3C031V
Package
Marking Code
03
BSD3A051V
3B
05
BSD3C051V
5B
BSD3A081V
08
BSD3C081V
BSD3A121V
8B
BSD3C121V
12
AB
BSD3A151V
15
BSD3C151V
BSD3A241V
BSD3C241V
BB
Qty:3k/Reel
24
CB
4/4
很抱歉,暂时无法提供与“BSD3C361V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.41328
- 100+0.33925
- 600+0.30323
- 1200+0.29868
- 3000+0.25314
- 国内价格
- 10+0.49440
- 100+0.39910
- 300+0.35240
- 3000+0.28800
- 6000+0.26030
- 9000+0.24640
- 国内价格
- 1+0.40810
- 200+0.26400
- 1500+0.22880
- 3000+0.20240
- 国内价格
- 10+0.49594
- 100+0.40263
- 300+0.35597
- 3000+0.29085
- 6000+0.26288
- 9000+0.24884
