山东晶导微电子股份有限公司
RS1A THRU RS1M
Jingdao Microelectronics co.LTD
Surface Mount Fast Recovery Rectifiers
Reverse Voltage - 50 to 1000 V
PINNING
Forward Current - 1 A
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Easy to pick and place
• Fast reverse recovery time
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: RS1A~RS1M
Simplified outline SMA and symbol
MECHANICAL DATA
• Case: SMA
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.055g / 0.002oz
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols
RS1A
RS1B
RS1D
RS1G
RS1J
RS1K
RS1M
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
at T c= 125 °C
I F(AV)
1
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
30
A
Maximum Forward Voltage at 1 A
VF
1.3
V
IR
5
50
μA
Cj
15
pF
Parameter
Maximum DC Reverse Current
Ta = 25 °C
at Rated DC Blocking Voltage
Ta =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
Typical Thermal Resistance
(1)
(2)
Operating and Storage Temperature Range
t rr
150
RθJA
T,j T
stg
250
500
ns
75
°C/W
-55 ~ +150
°C
(1)Measured with IF = 0.5 A, IR = 1 A, Irr = 0.25 A
(2)P.C.B. mounted with 1.0 X 1.0" (2.54 X 2.54 cm) copper pad areas.
2015.11
SMA-F-RS1A ~RS1M-1A1KV
Page 1 of 3
Fig.2 Typical Reverse Characteristics
Average Forward Current (A)
1.2
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current( μ A)
Fig.1 Forward Current Derating Curve
100
T J =125 °C
10
1.0
T J =25 °C
0.1
00
Fig.3 Typical Instaneous Forward
Characteristics
40
60
80
100
120
140
Reverse Voltage (%)
pF)
Fig.4 Typical Junction Capacitance
T J =25 °C
JunctionCapacitance (
Instaneous Forward Current (A)
10
percent of Rated Peak
Case Temperature (°C)
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
100
T J =25 °C
10
1
0.0
0.5
1.0
1.5
2.0
2.5
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
35
30
25
10
05
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2015.11
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
RS1A THRU RS1M
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
A
SMA
c
a
VM
e
A
HE
g
e
E
A
D
E
HE
c
e
g
max
2.2
4.5
2.7
5.2
0.31
1.6
1.5
min
1.9
4.0
2.3
4.7
0.15
1.3
0.9
max
87
181
106
205
12
63
59
min
75
157
91
185
6
51
35
UNIT
mm
mil
The recommended mounting pad size
2.4
(94)
0.3
12
Type number
Marking code
RS1A
RS1A
1.8
(71)
mm
Unit :
(mil)
2015.11
a
Marking
1.8
(71)
1.8
(71)
g
e
A
D
JD511214B6
RS1B
RS1B
RS1D
RS1D
RS1G
RS1G
RS1J
RS1J
RS1K
RS1K
RS1M
RS1M
Page 3 of 3
很抱歉,暂时无法提供与“RS1J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.07906
- 500+0.06448
- 1500+0.05638
- 国内价格
- 50+0.07247
- 1000+0.05910
