ASMD2920-200
ASMD2920-200
    JDTFUSE(集电通)
    FUSE-2920
    PTC自恢复保险丝 PTC_7.98X5.44MM_SM Ih=2A It=4A Vmax=24
ASMD2920-200 数据手册
PRODUCT DATASHEET Surface Mount PTC Devices ASMD2920 Series Surface Mount PTC Devices ASMD2920 Series Surface Mount PTC Devices Description The ASMD2920 series provides surface mount resettable overcurrent protection with holding current from 0.3A to 3.0A. This series is suitable for applications with higher holding current and higher working voltage up to 60V. Features ● RoHS compliant and lead-free ● Low profile ● Halogen-free ● Fast response to fault current ● High voltage ● Compatible with high temperature solders Agency Approvals Agency Applications File Number pending pending ● Power over Ethernet(POE) ● IEEE 1394 port protection ● Powered USB for POS and IPC ● Low voltage telecom equipment ● Automotive electronics control module protection Industrial control Security systems Regulation Standard 2002/95/EC EN14582 JDT FUSE Industrial Corp. www.jdtfuse.com Page 1/7 ASMD2920 Series Surface Mount PTC Devices Performance Specification Model V max (V dc) I max (A) I hold I trip Maximum Time To Trip Pd @25°C (A) @25°C (A) Typ. (W) Resistance Current (A) Time (Sec) R i min R1max (Ω) (Ω) ASMD2920-030 60 100 0.30 0.60 1.5 1.5 3.0 0.600 4.800 ASMD2920-050 60 100 0.50 1.00 1.5 2.5 4.0 0.180 1.400 ASMD2920-075 33 100 0.75 1.50 1.5 8.0 0.3 0.100 1.000 ASMD2920-100 33 100 1.10 2.20 1.5 8.0 0.5 0.065 0.410 ASMD2920-125 33 100 1.25 2.50 1.5 8.0 2.0 0.050 0.250 ASMD2920-150 33 100 1.50 3.00 1.5 8.0 2.0 0.035 0.230 ASMD2920-185 33 100 1.85 3.70 1.5 8.0 2.5 0.030 0.150 ASMD2920-200 24 100 2.00 4.00 1.5 8.0 4.5 0.020 0.120 ASMD2920-250 16 100 2.50 5.00 1.5 8.0 16.0 0.020 0.085 ASMD2920-260 6 100 2.60 5.20 1.5 8.0 10.0 0.014 0.075 ASMD2920-300 Test ASMD2920-300-16V 6 40 3.00 6.00 1.5 8.0 20.0 0.012 0.048 16 100 3.00 6.00 1.5 8.0 20.0 0.012 0.048 ASMD2920-400 16 40 4.00 8.00 1.5 20.0 4.0 0.008 0.040 ASMD2920-500 6 40 5.00 10.00 1.5 25.0 5.0 0.005 0.031 ASMD2920-500-12V 12 40 5.00 10.00 1.5 25.0 5.0 0.005 0.031 ASMD2920-500-16V 16 40 5.00 10.00 1.5 25.0 5.0 0.005 0.031 ASMD2920-600 12 40 6.00 12.00 1.5 25.0 6.0 0.004 0.020 ASMD2920-700 12 40 7.00 14.00 1.5 25.0 6.0 0.0025 0.010 I hold = Hold Current. Maximum current device will not trip in 25°C still air. I trip = Trip Current. Minimum current at which the device will always trip in 25°C still air. V max = Maximum operating voltage device can withstand without damage at rated current (Imax). I max = Maximum fault current device can withstand without damage at rated voltage (V max). Pd = Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage. Ri min/max = Minimum/Maximum device resistance prior to tripping at 25°C. R1max = Maximum device resistance is measured one hour post reflow. CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame. Environmental Specifications Conditions Resistance change Passive aging +85°C, 1000 hrs. ±5% typical Humidity aging +85°C, 85% R.H. , 168 hours ±5% typical Thermal shock +85°C to -40°C, 20 times ±33% typical Resistance to solvent MIL-STD-202,Method 215 No change Vibration MIL-STD-202,Method 201 No change   Ambient operating conditions : - 40 °C to +85 °C Maximum surface temperature of the device in the tripped state is 125 °C JDT FUSE Industrial Corp. www.jdtfuse.com Page 2/7 ASMD2920 Series Surface Mount PTC Devices Thermal Derating Curve Derating Curves for ASMD2920 Series Percentage of Derated Current 160 140 120 100 80 60 40 20 0 -40 -20 0 20 40 60 80 Temperature (°C ) Average Time-Current Curve 100 0.30A TIME IN SECOND 0.50A 0.75A 10 1.00A 1.25A 1 1.50A 1.85A 2.0A 0.1 2.50A 2.60A 3.00A 0.01 0.1 1 10 100 CURRENT IN AMPERES JDT FUSE Industrial Corp. www.jdtfuse.com Page 3/7 ASMD2920 Series Surface Mount PTC Devices Thermal Derading Chart Maximum ambient operating temperature (Tmao) vs. hold current (Ihold) Model - 40°C - 20°C 0°C 25°C 40°C 50°C 60°C 70°C 85°C ASMD2920-030 0.45 0.40 0.35 0.30 0.25 0.23 0.20 0.17 0.14 ASMD2920-050 0.76 0.67 0.59 0.50 0.42 0.38 0.33 0.29 0.23 ASMD2920-075 1.13 1.01 0.88 0.75 0.62 0.56 0.50 0.44 0.34 ASMD2920-100 1.66 1.47 1.29 1.10 0.91 0.83 0.73 0.64 0.50 ASMD2920-125 1.89 1.68 1.46 1.25 1.04 0.94 0.83 0.73 0.56 ASMD2920-150 2.27 2.01 1.76 1.50 1.25 1.13 1.00 0.87 0.74 ASMD2920-185 2.80 2.47 2.17 1.85 1.54 1.39 1.22 1.07 0.85 ASMD2920-200 3.02 2.68 2.34 2.00 1.66 1.50 1.32 1.16 0.90 ASMD2920-250 3.78 3.35 2.93 2.50 2.08 1.88 1.65 1.45 1.13 ASMD2920-260 3.64 3.25 2.91 2.60 2.26 2.08 1.95 1.74 1.13 ASMD2920-300 4.53 4.02 3.51 3.00 2.52 2.26 1.99 1.75 1.34 ASMD2920-400 6.04 5.36 4.68 4.00 3.36 3.01 2.65 2.33 1.79 ASMD2920-500 7.55 6.70 5.85 5.00 4.20 3.77 3.32 2.92 2.23 ASMD2920-600 8.60 7.70 6.80 6.00 4.95 4.60 4.06 3.65 3.15 Soldering Parameters TP 20~40 S TP 260 Ramp-up Profile Feature Critical Zone TL to TP TL 217 tL Tsmax Temperature (°C ) Preheat Tsmin Ramp-down ts Preheat 60~180 s 25 3℃/second mac. (Ts max to T p) 60~150 s 200 150 Average Ramp-Up Rate Pb-Free Assembly t 25°C to peak Time Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free Recommended maximum paste thickness is 0.25mm Devices can be cleaned using standard industry methods and solvents. Note 1:All temperature refer to topside of the package, measured on the package body surface. Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements. JDT FUSE Industrial Corp. www.jdtfuse.com -Temperature Min(Ts min) 150℃ -Temperature Max(Ts max) 200℃ -Time(Ts min to Ts max) 60~180 seconds Time maintained above: -Temperature(TL) 217℃ -Time(tL) 60~150 seconds Peak Temperature(Tp) 260℃ Ramp-Down Rate 6℃/second max. Time 25℃ to Peak Temperature 8 minutes max Storage Condition 0℃~35℃,≤70%RH Page 4/7 ASMD2920 Series Surface Mount PTC Devices Physical Dimensions(mm.) A Model B C D E Min. Max. Min. Max. Min. Max. Min. Min. ASMD2920-030 6.73 7.98 4.80 5.44 0.60 1.30 0.30 0.25 ASMD2920-050 6.73 7.98 4.80 5.44 0.60 1.30 0.30 0.25 ASMD2920-075 6.73 7.98 4.80 5.44 0.60 1.30 0.30 0.25 ASMD2920-100 6.73 7.98 4.80 5.44 0.40 1.00 0.30 0.25 ASMD2920-125 6.73 7.98 4.80 5.44 0.40 0.90 0.30 0.25 ASMD2920-150 6.73 7.98 4.80 5.44 0.40 0.90 0.30 0.25 ASMD2920-185 6.73 7.98 4.80 5.44 0.30 0.90 0.30 0.25 ASMD2920-200 6.73 7.98 4.80 5.44 0.30 0.90 0.30 0.25 ASMD2920-250 6.73 7.98 4.80 5.44 0.30 0.90 0.30 0.25 ASMD2920-260 6.73 7.98 4.80 5.44 0.30 0.90 0.30 0.25 ASMD2920-300 6.73 7.98 4.80 5.44 0.60 1.30 0.30 0.25 ASMD2920-400 6.73 7.98 4.80 5.44 0.60 1.30 0.30 0.25 ASMD2920-500 6.73 7.98 4.80 5.44 0.60 1.30 0.30 0.25 ASMD2920-500-12V 6.73 7.98 4.80 5.44 0.60 1.30 0.30 0.25 ASMD2920-500-16V 6.73 7.98 4.80 5.44 0.80 1.50 0.30 0.25 ASMD2920-600 6.73 7.98 4.80 5.44 0.80 1.50 0.30 0.25 ASMD2920-700 6.73 7.98 4.80 5.44 0.80 1.50 0.30 0.25 Termination Pad Characteristics Terminal pad materials:Tin-plated Nickel-Copper Terminal pad solder ability:Meets EIA specification RS186-9E and ANSI/J-STD-002 Category 3. Packaging Quantity and Marking 5.1±0.1 Part Number 5.6±0.1 ASMD2920 Series Quantity 2,000 pcs/reel Tape & reel packaging per EIA481-1 2.3±0.1 JDT FUSE Industrial Corp. www.jdtfuse.com 2.3±0.1 Page 5/7 ASMD2920 Series Surface Mount PTC Devices Tape And Reel Specifications (mm) Governing Specifications EIA 481-1 W 16.00 ± 0.3 P0 4.00 ± 0.10 P1 8.00 ± 0.10 P2 2.00 ± 0.05 A0 5.70 ± 0.10 B0 8.00 ± 0.10 B1max. 12.10 D0 1.50 + 0.1, -0 F 7.50 ± 0.05 E1 1.75 ± 0.10 E2min. 14.25 T 0.60 T1max. 0.10 K0 0.80 ± 0.1 Leader min. 390 Trailer min. 160 Reel Dimensions   A max. 178 N min. 60 W1 16.40 ± 0.5 W2 22.40 Storage And Handling ● Storage conditions:40°C max, 70% R.H. ● Devices may not meet specified performance if storage conditions are exceeded.Technology Corp. JDT FUSE Industrial Corp. www.jdtfuse.com P1 P2 D0 P0 E1 F W T D2 K0 A0 B0 H W4 W3 D C W2 W F W1 H1 Page 6/7 ASMD2920 Series Surface Mount PTC Devices Part Number System ASMD 2920 - Special Voltage Rating(Optional) Holding Current Rating Device Dimensions: Length/width(Unit:1/100 inch) Size 7555 mm / 2920 inch Surface Mount Device Cross Reference Cross Reference Model Tyco / PolySwitch® Littelfuse / POLY-FUSE® Polytronics / EVERFUSE® ASMD2920-030 SMD030F 2920L030 SMD2920P030TF ASMD2920-050 SMD050F 2920L050 SMD2920P050TF ASMD2920-075 SMD075F 2920L075 SMD2920P075TF ASMD2920-100 SMD100F/33 2920L100 SMD2920P110TF ASMD2920-125 SMD125F 2920L125 SMD2920P125TF ASMD2920-150 SMD150F/33(3425) 2920L150 SMD2920P150TF ASMD2920-185 SMD185F(3425) 2920L185 SMD2920P185TF ASMD2920-200 SMD200F(3425) 2920L200 SMD2920P200TF ASMD2920-250 SMD250F(3425) 2920L250 SMD2920P250TF ASMD2920-260 SMD260F 2920L260 SMD2920P260TF ASMD2920-300 SMD300F 2920L300 SMD2920P300TF ASMD2920-300-16 - 2920L300/15 SMD2920P300TF/15 ASMD2920-400 - - - ASMD2920-500 - - - ASMD2920-500-12V - - - ASMD2920-500-16V - - - ASMD2920-600 - - - ASMD2920-700 - - - “PolySwitch” is a registered trademark of Tyco Electronics. “POLY-FUSE” is a registered trademark of Littelfuse,Inc. “EVERFUSE” is a registered trademark of Polytronics Technology Corp. JDT FUSE Industrial Corp. www.jdtfuse.com Page 7/7
ASMD2920-200 价格&库存
很抱歉,暂时无法提供与“ASMD2920-200”相匹配的价格&库存,您可以联系我们找货
ASMD2920-200
  • 10+1.73510
  • 100+1.03500
  • 500+0.72450
  • 1500+0.51750
  • 3000+0.49160
  • 15000+0.45540
ASMD2920-200
  • 5+0.67136
  • 50+0.52538
  • 150+0.45239
  • 1500+0.39765
  • 3000+0.35383
  • 4500+0.33197
库存:1523
ASMD2920-200
  • 10+1.73510
  • 100+1.03500
  • 500+0.72450
  • 1500+0.51750
  • 3000+0.49160
  • 15000+0.45540
库存:31129
ASMD2920-200
  • 1+0.46401
  • 30+0.44801
  • 100+0.41601
  • 500+0.38401
  • 1000+0.36801
库存:35
ASMD2920-200
    • 1+0.57200
    • 50+0.38170
    • 1500+0.34540
