PRODUCT DATASHEET
Surface Mount PTC Devices
ASMD0603 Series Surface Mount PTC Devices
Description
The ASMD0603 series provides miniature surface
mount resettable overcurrent protection with holding
current from 100mA to 500mA.
This world’s smallest PTC is suitable for ultra
portable applications where space is at a premium and
the device current is low.
Features
● RoHS compliant and lead-free
● Low profile
● Halogen-free
● Fast response to fault current
● Compact design saves board space
● Compatible with high temperature solders
Agency Approvals
Agency
Applications
File Number
pending
Regulation
JDT FUSE Industrial Corp.
www.jdtfuse.com
pending
● Mobile phones and PDAs
● USB peripherals
● Portable MP3 and media player
● IC VCC protection
● Mobile Internet Device (MID)
Standard
2002/95/EC
EN14582
Page 1/7
Performance Specification
V max
Model
I max
(V dc)
(A)
I hold
I trip
Maximum
Time To Trip
Pd
@25°C
(A)
@25°C
(A)
Typ.
(W)
Resistance
Current
(A)
Time
(Sec)
R i min
R1max
(Ω)
(Ω)
ASMD0603-010
15.0
40
0.10
0.30
0.5
0.5
1.00
0.900
6.000
ASMD0603-020
9.0
40
0.20
0.50
0.5
1.0
0.60
0.550
3.500
ASMD0603-025
9.0
40
0.25
0.55
0.5
8.0
0.08
0.500
3.000
ASMD0603-035
6.0
40
0.35
0.75
0.5
8.0
0.10
0.200
1.400
ASMD0603-050
6.0
40
0.50
1.00
0.5
8.0
0.10
0.100
0.800
ASMD0603-075
6.0
40
0.75
1.40
0.5
8.0
0.10
0.060
0.450
ASMD0603-100
6.0
40
1.00
2.00
0.5
8.0
0.10
0.040
0.300
I hold = Hold Current. Maximum current device will not trip in 25°C still air.
I trip = Trip Current. Minimum current at which the device will always trip in 25°C still air.
V max = Maximum operating voltage device can withstand without damage at rated current (Imax).
I max = Maximum fault current device can withstand without damage at rated voltage (V max).
Pd
= Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage.
Ri min/max = Minimum/Maximum device resistance prior to tripping at 25°C.
R1max = Maximum device resistance is measured one hour post reflow.
CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame.
Environmental Specifications
Conditions
Test
Resistance change
Passive aging
+85°C, 1000 hrs.
±5% typical
Humidity aging
+85°C, 85% R.H. , 168 hours
±5% typical
Thermal shock
+85°C to -40°C, 20 times
±33% typical
Resistance to solvent
MIL-STD-202,Method 215
No change
MIL-STD-202,Method 201
No change
Vibration
Ambient operating conditions : - 40 °C to +85 °C
Maximum surface temperature of the device in the tripped state is 125 °C
www.jdtfuse.com
Page 2/7
Percentage of Derated Current
Thermal Derating Curve
Derating Curves for ASMD0603 Series
200
150
100
50
-20
Temperature (°C )
60
80
Average Time-Current Curve
100
0.10A
0.20A
TIME IN SECOND
10
0.25A
1
0.35A
0.1
0.50A
0.01
0.75A
0.001
1.00A
0.1
1
CURRENT IN AMPERES
10
Thermal Derading Chart
Model
Maximum ambient operating temperature (Tmao) vs. hold current (Ihold)
- 40°C
- 20°C
0°C
25°C
40°C
50°C
60°C
70°C
85°C
ASMD0603-010
0.13
0.12
0.11
0.10
0.08
0.07
0.06
0.05
0.03
ASMD0603-020
0.27
0.25
0.23
0.20
0.17
0.14
0.12
0.10
0.07
ASMD0603-025
0.32
0.29
0.27
0.25
0.21
0.18
0.16
0.05
0.03
ASMD0603-035
0.47
0.41
0.38
0.35
0.29
0.26
0.24
0.20
0.14
ASMD0603-050
0.67
0.59
0.54
0.50
0.41
0.37
0.34
0.29
0.20
ASMD0603-075
0.98
0.85
0.81
0.75
0.60
0.54
0.44
0.40
0.31
ASMD0603-100
1.30
1.12
1.08
1.00
0.80
0.72
0.58
0.53
www.jdtfuse.com
0.42
Page 3/7
Soldering Parameters
TP 20~40 S
TP 260
Ramp-up
Critical Zone
TL to TP
TL 217
tL
Tsmax
60~150 s
Temperature (°C )
200
Tsmin
Ramp-down
150
ts
Preheat 60~180 s
25
t 25°C to peak
Time
Profile Feature
Average Ramp-Up Rate
Pb-Free Assembly
3℃/second mac.
(Ts max to T p)
Preheat
-Temperature Min(Ts min)
150℃
-Temperature Max(Ts max)
200℃
-Time(Ts min to Ts max)
60~180 seconds
Time maintained above:
-Temperature(TL)
217℃
-Time(tL)
60~150 seconds
Peak Temperature(Tp)
260℃
Ramp-Down Rate
6℃/second max.
Time 25℃ to Peak Temperature 8 minutes max
Storage Condition
0℃~35℃,≤70%RH
Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free
Recommended maximum paste thickness is 0.25mm
Devices can be cleaned using standard industry methods and solvents.
Note 1:All temperature refer to topside of the package, measured on the package body surface.
Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements.
www.jdtfuse.com
Page 4/7
Physical Dimensions(mm.)
A
Model
B
C
D
E
Min.
Max.
Min.
Max.
Min.
Max.
Min.
Min.
ASMD0603-010
1.45
1.85
0.65
1.05
0.40
1.00
0.15
0.10
ASMD0603-020
1.45
1.85
0.65
1.05
0.40
1.00
0.15
0.10
ASMD0603-025
1.45
1.85
0.65
1.05
0.40
1.00
0.15
0.10
ASMD0603-035
1.45
1.85
0.65
1.05
0.40
1.00
0.15
0.10
ASMD0603-050
1.45
1.85
0.65
1.05
0.50
1.10
0.15
0.10
ASMD0603-075
1.45
1.85
0.65
1.05
0.50
1.10
0.15
0.10
ASMD0603-100
1.45
1.85
0.65
1.05
0.50
1.10
0.15
0.10
Termination Pad Characteristics
Terminal pad materials:Tin-plated Nickel-Copper
Terminal pad solder ability:Meets EIA specification RS186-9E and ANSI/J-STD-002 Category 3
Packaging Quantity and Marking
1.0±0.1
Part Number
1.0±0.1
SMD0603 HF Series
Quantity
5,000 pcs/reel
Tape & reel packaging per EIA481-1
0.7±0.1
www.jdtfuse.com
0.7±0.1
Page 5/7
Tape And Reel Specifications (mm)
Governing Specifications
P1
W
8.0 ± 0.2
P0
4.0 ± 0.10
P1
4.0 ± 0.10
P2
2.0 ± 0.05
A0
1.05 ± 0.10
B0
1.85 ± 0.10
B1max.
1.55 + 0.05
D0
3.5 ± 0.05
F
1.75 ± 0.10
E1
6.25
E2min.
0.75
T
0.1
T1max.
0.75/0.95 ± 0.1
P2
D0
P0
E1
F
W
T
D2
K0
A0
B0
H
K0
Leader min.
390
Trailer min.
160
Reel Dimensions
A max.
178
N min.
60
W4
W3
D
C
W2
W1
W2
9.0 ± 0.5
12.0 ± 0.05
Storage And Handling
● Storage conditions:40°C max, 70% R.H.
● Devices may not meet specified performance
if storage conditions are exceeded.Technology Corp.
www.jdtfuse.com
W
F
W1
H1
Page 6/7
Part Number System
ASMD 0603 -
Special Voltage Rating(Optional)
Holding Current Rating
Device Dimensions:
Length/width(Unit:1/100 inch) Size 1508 mm / 0603 inch
Surface Mount Device
Cross Reference
Cross Reference
Model
Tyco / PolySwitch®
Littelfuse / POLY-FUSE®
Polytronics / EVERFUSE®
ASMD0603-010
0603L010
SMD0603P010TF
ASMD0603-020
0603L020
SMD0603P020TF
ASMD0603-025
0603L025
SMD0603P025TF
ASMD0603-035
0603L035
SMD0603P035TF
ASMD0603-050
0603L050
SMD0603P050TF
ASMD0603-075
ASMD0603-100
“PolySwitch” is a registered trademark of Tyco Electronics.
“POLY-FUSE” is a registered trademark of Littelfuse,Inc.
“EVERFUSE” is a registered trademark of Polytronics Technology Corp.
www.jdtfuse.com
Page 7/7
很抱歉,暂时无法提供与“ASMD0603-010”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.20812
- 20+0.19012
- 100+0.17212
- 500+0.15412
- 1000+0.14572
- 2000+0.13972
- 国内价格
- 10+0.31677
- 100+0.25291
- 300+0.22097
- 1000+0.19702
- 4000+0.16975
- 8000+0.16015
- 国内价格
- 20+0.53020
- 100+0.31620
- 1000+0.22140
- 4000+0.15810
- 8000+0.15020
- 40000+0.13910
- 国内价格
- 1+0.24090
- 200+0.15510
- 2000+0.13530
- 4000+0.11990
