ASMD0603-020
ASMD0603-020
    JDTFUSE(集电通)
    FUSE0603 PTC自恢复保险丝 9V
ASMD0603-020 数据手册
PRODUCT DATASHEET Surface Mount PTC Devices ASMD0603 Series Surface Mount PTC Devices ASMD0603 Series Surface Mount PTC Devices Description The ASMD0603 series provides miniature surface mount resettable overcurrent protection with holding current from 100mA to 500mA. This world’s smallest PTC is suitable for ultra portable applications where space is at a premium and the device current is low. Features ● RoHS compliant and lead-free ● Low profile ● Halogen-free ● Fast response to fault current ● Compact design saves board space ● Compatible with high temperature solders Agency Approvals Agency Applications File Number pending   Regulation     JDT FUSE Industrial Corp. www.jdtfuse.com pending ● Mobile phones and PDAs ● USB peripherals ● Portable MP3 and media player ● IC VCC protection ● Mobile Internet Device (MID) Standard 2002/95/EC EN14582 Page 1/7 ASMD0603 Series Surface Mount PTC Devices Performance Specification V max Model I max (V dc) (A) I hold I trip Maximum Time To Trip Pd @25°C (A) @25°C (A) Typ. (W) Resistance Current (A) Time (Sec) R i min R1max (Ω) (Ω) ASMD0603-010 15.0 40 0.10 0.30 0.5 0.5 1.00 0.900 6.000 ASMD0603-020 9.0 40 0.20 0.50 0.5 1.0 0.60 0.550 3.500 ASMD0603-025 9.0 40 0.25 0.55 0.5 8.0 0.08 0.500 3.000 ASMD0603-035 6.0 40 0.35 0.75 0.5 8.0 0.10 0.200 1.400 ASMD0603-050 6.0 40 0.50 1.00 0.5 8.0 0.10 0.100 0.800 ASMD0603-075 6.0 40 0.75 1.40 0.5 8.0 0.10 0.060 0.450 ASMD0603-100 6.0 40 1.00 2.00 0.5 8.0 0.10 0.040 0.300 I hold = Hold Current. Maximum current device will not trip in 25°C still air. I trip = Trip Current. Minimum current at which the device will always trip in 25°C still air. V max = Maximum operating voltage device can withstand without damage at rated current (Imax). I max = Maximum fault current device can withstand without damage at rated voltage (V max). Pd = Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage. Ri min/max = Minimum/Maximum device resistance prior to tripping at 25°C. R1max = Maximum device resistance is measured one hour post reflow. CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame. Environmental Specifications Conditions Test Resistance change Passive aging     +85°C, 1000 hrs. ±5% typical Humidity aging     +85°C, 85% R.H. , 168 hours ±5% typical Thermal shock     +85°C to -40°C, 20 times ±33% typical Resistance to solvent     MIL-STD-202,Method 215 No change MIL-STD-202,Method 201 No change Vibration     Ambient operating conditions : - 40 °C to +85 °C Maximum surface temperature of the device in the tripped state is 125 °C JDT FUSE Industrial Corp. www.jdtfuse.com Page 2/7 ASMD0603 Series Surface Mount PTC Devices Percentage of Derated Current Thermal Derating Curve Derating Curves for ASMD0603 Series 200 150 100 50 0 -40 -20 0 20 40 Temperature (°C ) 60 80 Average Time-Current Curve 100 0.10A 0.20A TIME IN SECOND 10 0.25A 1 0.35A 0.1 0.50A 0.01 0.75A 0.001 1.00A 0.1 1 CURRENT IN AMPERES 10 Thermal Derading Chart Model Maximum ambient operating temperature (Tmao) vs. hold current (Ihold) - 40°C - 20°C 0°C 25°C 40°C 50°C 60°C 70°C 85°C ASMD0603-010 0.13 0.12 0.11 0.10 0.08 0.07 0.06 0.05 0.03 ASMD0603-020 0.27 0.25 0.23 0.20 0.17 0.14 0.12 0.10 0.07 ASMD0603-025 0.32 0.29 0.27 0.25 0.21 0.18 0.16 0.05 0.03 ASMD0603-035 0.47 0.41 0.38 0.35 0.29 0.26 0.24 0.20 0.14 ASMD0603-050 0.67 0.59 0.54 0.50 0.41 0.37 0.34 0.29 0.20 ASMD0603-075 0.98 0.85 0.81 0.75 0.60 0.54 0.44 0.40 0.31 ASMD0603-100 1.30 1.12 1.08 1.00 0.80 0.72 0.58 0.53 JDT FUSE Industrial Corp. www.jdtfuse.com     0.42 Page 3/7 ASMD0603 Series Surface Mount PTC Devices Soldering Parameters TP 20~40 S TP 260 Ramp-up Critical Zone TL to TP TL 217 tL Tsmax 60~150 s Temperature (°C ) 200 Tsmin Ramp-down 150 ts Preheat 60~180 s 25 t 25°C to peak Time Profile Feature Average Ramp-Up Rate Pb-Free Assembly 3℃/second mac. (Ts max to T p) Preheat -Temperature Min(Ts min) 150℃ -Temperature Max(Ts max) 200℃ -Time(Ts min to Ts max) 60~180 seconds Time maintained above: -Temperature(TL) 217℃ -Time(tL) 60~150 seconds Peak Temperature(Tp) 260℃ Ramp-Down Rate 6℃/second max. Time 25℃ to Peak Temperature 8 minutes max Storage Condition 0℃~35℃,≤70%RH Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free Recommended maximum paste thickness is 0.25mm Devices can be cleaned using standard industry methods and solvents. Note 1:All temperature refer to topside of the package, measured on the package body surface. Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements. JDT FUSE Industrial Corp. www.jdtfuse.com Page 4/7 ASMD0603 Series Surface Mount PTC Devices Physical Dimensions(mm.) A Model B C D E Min. Max. Min. Max. Min. Max. Min. Min. ASMD0603-010 1.45 1.85 0.65 1.05 0.40 1.00 0.15 0.10 ASMD0603-020 1.45 1.85 0.65 1.05 0.40 1.00 0.15 0.10 ASMD0603-025 1.45 1.85 0.65 1.05 0.40 1.00 0.15 0.10 ASMD0603-035 1.45 1.85 0.65 1.05 0.40 1.00 0.15 0.10 ASMD0603-050 1.45 1.85 0.65 1.05 0.50 1.10 0.15 0.10 ASMD0603-075 1.45 1.85 0.65 1.05 0.50 1.10 0.15 0.10 ASMD0603-100 1.45 1.85 0.65 1.05 0.50 1.10 0.15 0.10 Termination Pad Characteristics Terminal pad materials:Tin-plated Nickel-Copper Terminal pad solder ability:Meets EIA specification RS186-9E and ANSI/J-STD-002 Category 3 Packaging Quantity and Marking 1.0±0.1 Part Number 1.0±0.1 SMD0603 HF Series Quantity 5,000 pcs/reel Tape & reel packaging per EIA481-1 0.7±0.1 JDT FUSE Industrial Corp. www.jdtfuse.com 0.7±0.1 Page 5/7 ASMD0603 Series Surface Mount PTC Devices Tape And Reel Specifications (mm) Governing Specifications P1 W 8.0 ± 0.2 P0 4.0 ± 0.10 P1 4.0 ± 0.10 P2 2.0 ± 0.05 A0 1.05 ± 0.10 B0 1.85 ± 0.10 B1max. 1.55 + 0.05 D0 3.5 ± 0.05 F 1.75 ± 0.10 E1 6.25 E2min. 0.75 T 0.1 T1max. 0.75/0.95 ± 0.1 P2 D0 P0 E1 F W T D2 K0 A0 B0 H K0 Leader min. 390 Trailer min. 160 Reel Dimensions   A max. 178 N min. 60 W4 W3 D C W2 W1 W2 9.0 ± 0.5 12.0 ± 0.05 Storage And Handling ● Storage conditions:40°C max, 70% R.H. ● Devices may not meet specified performance if storage conditions are exceeded.Technology Corp. JDT FUSE Industrial Corp. www.jdtfuse.com W F W1 H1 Page 6/7 ASMD0603 Series Surface Mount PTC Devices Part Number System ASMD 0603 - Special Voltage Rating(Optional) Holding Current Rating Device Dimensions: Length/width(Unit:1/100 inch) Size 1508 mm / 0603 inch Surface Mount Device Cross Reference Cross Reference Model Tyco / PolySwitch® Littelfuse / POLY-FUSE® Polytronics / EVERFUSE® ASMD0603-010 - 0603L010 SMD0603P010TF ASMD0603-020 - 0603L020 SMD0603P020TF ASMD0603-025 - 0603L025 SMD0603P025TF ASMD0603-035 - 0603L035 SMD0603P035TF ASMD0603-050 - 0603L050 SMD0603P050TF ASMD0603-075 - - - ASMD0603-100 - - - “PolySwitch” is a registered trademark of Tyco Electronics. “POLY-FUSE” is a registered trademark of Littelfuse,Inc. “EVERFUSE” is a registered trademark of Polytronics Technology Corp. JDT FUSE Industrial Corp. www.jdtfuse.com Page 7/7
ASMD0603-020 价格&库存
很抱歉,暂时无法提供与“ASMD0603-020”相匹配的价格&库存,您可以联系我们找货
ASMD0603-020
    • 1+0.33660
    • 10+0.27700
    • 30+0.22780
    • 100+0.20520
    • 300+0.18700
    • 4000+0.17600
    库存:2849
    ASMD0603-020
    • 10+0.23249
    • 100+0.21749
    • 500+0.20249
    • 2000+0.18000
    • 5000+0.17250
    • 10000+0.16800
    库存:111
    ASMD0603-020
    • 10+0.28427
    • 100+0.22497
    • 300+0.19531
    • 1000+0.17307
    • 4000+0.15530
    • 8000+0.14637
    库存:8387
    ASMD0603-020
    • 20+0.53030
    • 100+0.31620
    • 1000+0.22140
    • 4000+0.15810
    • 8000+0.15020
    • 40000+0.13910
    库存:80534
