LGA
LGA TYPE COLOR CODE INDUCTORS
HOW TO ORDER
FOR EXAMPLE
LGA
0307
A
B
220
K
P
52
C
D
E
F
A
B
Body Dimensions(mm)
Product type
LGA
Axial color code inductor
Type
Dmax
Lmax
0204
2.3
4.2
0307
2.8
7.0
0410
4.0
10.5
0510
5.0
10.5
C
Nominal lnductance(
H
D
Tolerance
The first two digits are significant,
and the third digit is number of zero
J
5%
K
10%
M
20%
For example
101=100
H
5R6=5.6
H
R22=0.22
H
F
Lead config uration
E
Tape&
reel
Packaging style
P
Tape&
reel
T
F
L
VK
52
Tape width
07
Reel
10
Formed
lead
Axial
12
Straight lead formed
15
Bent lead formed
K
Bent lead K formed
17
Bulk
V
Tape width
05
Ammo
26
26
52
5.08mm
Formed lead pitch
7.5mm
Formed lead pitch
10.0mm
Formed lead pitch
12.5mm
Formed lead pitch
15.0mm
Formed lead pitch
17.5mm
Formed lead pitch
20.0mm
Formed lead pitch
LGA
EXTERNAL DIMENSIONS
Dimensions (mm)
Type
D
L
t
d
LGA0204
2.3
4.2
t=5.08
t=7.50
0.6
0.6
0.50
0.05
LGA0307
2.8
7.0
t=10.0
t=12.5
0.6
0.6
0.50
0.05
H
LGA0410
4.0
10.5
t=12.5
t=15.0
t=17.5
t=20.0
0.6
0.6
0.6
0.6
0.60
0.05
10.5
t=15.0
t=17.5
t=20.0
0.6
0.6
0.6
0.60
0.05
44
LGA0510
5.0
157
5
(V type)
K
(VK type)
MARKING
Nominal inductance
Tolerance
1 colorzone
2 colorzone
3 colorzone
1 digit
2 digit
3 digit
x10 0 (1)
Black
Brown
1
1
1
x10 (10)
Red
2
2
2
x10 (100)
Orange
3
3
3
x10 (1000)
Yellow
4
4
4
x10 (10000)
Green
5
5
x10 5 (100000)
Blue
6
6
Purple
7
7
Gray
8
8
White
9
9
Gold
-1
x10 (0.1)
Silver
x10 -2 (0.01)
4 color zone
M
20%
J
5%
K
10%
For example:
22 H, 5%
If nominal inductance&tolerance is22 H, 5%,respectively,red+red+black+gold should be marked.
1.0 H, 10%
If nominal inductance&tolerance is1.0 H, 10%,respectively,brown+black+gold+silver should be marked.
0.22 H, 20%
If nominal inductance&tolerance is0.22 H, 20%,respectively,red+red+silver+black should be marked.
:LGA0204
NOTE:only the first three color zones are marked on the body of LGA0204,due to the small body size.
158
LGA
ELECTRICAL CHARACTERISTICS&TEST CONDITIONS
LGA0204
LGA0204 TYPE INDUCTORS ELECTRICAL CHARACTERISTICS&TEST CONDITIONS
LGA0204
Type
Nominal
Inductance
( H)
Tolerance
Q
(min)
RDC
max
Test frequency
(MHZ )
SRF
(MHZ )min
Rated current
I DC (mA)max
LGA0204-R22
0.22
0.40
400
LGA0204-R27
0.27
0.43
380
LGA0204-R33
0.33
0.48
370
LGA0204-R39
0.39
0.51
LGA0204-R47
0.47
0.56
LGA0204-R56
0.56
0.61
320
LGA0204-R68
0.68
0.67
310
LGA0204-R82
0.82
0.74
290
LGA0204-1R0
1.0
LGA0204-1R2
1.2
LGA0204-1R5
1.5
LGA0204-1R8
35
M
350
25.2
150
0.80
20%
330
270
0.90
11 0
260
1.0
80
250
1.8
1.1
60
240
LGA0204-2R2
2.2
2.2
45
230
LGA0204-2R7
2.7
1.3
40
220
LGA0204-3R3
3.3
1.4
38
210
LGA0204-3R9
3.9
1.6
35
200
LGA0204-4R7
4.7
1.7
32
190
LGA0204-5R6
5.6
1.9
30
180
LGA0204-6R8
6.8
2.0
28
175
LGA0204-8R2
8.2
2.2
26
165
LGA0204-100
10
2.5
24
160
LGA0204-120
12
2.5
22
150
LGA0204-150
15
2.8
LGA0204-180
18
3.1
18
140
LGA0204-220
22
3.4
17
130
LGA0204-270
27
4.3
16
80
LGA0204-330
33
4.7
14
76
LGA0204-390
39
5.2
13
74
LGA0204-470
47
5.8
12
70
LGA0204-560
56
6.4
11
68
LGA0204-680
68
7.2
10
64
LGA0204-820
82
11 . 0
9.5
46
LGA0204-101
100
12.0
9.0
44
LGA0204-121
120
13.0
8.0
42
LGA0204-151
150
16.0
6.0
39
LGA0204-181
180
18.0
5.5
37
LGA0204-221
220
20.0
5.0
35
Test equipment
Ambient
temperature
Ambient
humidity
HP4285A
K
10%
40
J
5%
( HP4286A, HP4287A )
HP4338B
18~25
45%~75%
The products can be customized according to customer requirement.
159
7.96
2.52
0.796
HM9461
HP42841A
LGA0307
LGA0307 TYPE INDUCTORS ELECTRICAL CHARACTERISTICS & TEST CONDITIONS
LGA0307
Type
Nominal
Inductance
( H)
LGA0307-R22
0.22
0.40
400
LGA0307-R27
0.27
0.43
380
LGA0307-R33
0.33
0.48
370
LGA0307-R39
0.39
0.51
LGA0307-R47
0.47
0.56
LGA0307-R56
0.56
0.61
320
LGA0307-R68
0.68
0.67
310
LGA0307-R82
0.82
0.74
290
LGA0307-1R0
1.0
0.80
LGA0307-1R2
1.2
0.90
144
260
LGA0307-1R5
1.5
1.0
131
250
LGA0307-1R8
1.8
1.1
121
240
LGA0307-2R2
2.2
1.2
11 0
230
LGA0307-2R7
2.7
1.3
100
220
LGA0307-3R3
3.3
1.4
94
210
LGA0307-3R9
3.9
1.6
65
200
LGA0307-4R7
4.7
1.7
56
190
LGA0307-5R6
5.6
1.9
48
180
LGA0307-6R8
6.8
2.0
37
175
LGA0307-8R2
8.2
2.2
25
165
LGA0307-100
10
2.5
21
160
LGA0307-120
12
2.5
19
150
LGA0307-150
15
2.8
17
145
LGA0307-180
18
3.1
13
140
LGA0307-220
22
3.4
9.6
130
LGA0307-270
27
3.8
7.2
125
LGA0307-330
33
4.1
6.3
120
LGA0307-390
39
4.5
6.3
11 5
LGA0307-470
47
4.9
6.3
11 0
LGA0307-560
56
5.3
6.2
105
LGA0307-680
68
5.8
5.7
100
LGA0307-820
82
6.3
5.3
95
LGA0307-101
100
7.0
4.8
90
LGA0307-121
120
13.0
3.8
90
LGA0307-151
150
15.0
3.5
85
LGA0307-181
180
16.0
3.3
80
LGA0307-221
220
17.0
3.0
75
LGA0307-271
270
19.0
2.8
65
LGA0307-331
330
20.0
2.6
60
LGA0307-391
390
22.0
2.4
55
LGA0307-471
470
24.0
2.25
55
LGA0307-561
560
26.0
2.10
50
LGA0307-681
680
28.0
1.95
45
LGA0307-821
820
30.0
1.85
40
LGA0307-102
1000
33.0
1.40
40
HM9461
HP42841A
Test equipment
Ambient
temperature
Ambient
humidity
HP4285A
Tolerance
Q
(min)
RDC
max
35
40
M
20%
35
K
10%
40
50
J
5%
50
HP4338B
18~25
45%~75%
160
Test frequency
(MHZ )
SRF
(MHZ )min
Rated current
I DC (mA)max
350
25.2
150
330
270
7.96
2.52
0.796
LGA
LGA0410
LGA0410 TYPE INDUCTORS ELECTRICAL CHARACTERISTICS & TEST CONDITIONS
LGA0410
Type
Nominal
Inductance
( H)
Tolerance
Q
(min)
RDC
max
Test frequency
(MHZ )
SRF
(MHZ )min
Rated current
I DC (mA)max
LGA0410-R22
0.22
45
0.10
300
1400
LGA0410-R27
0.27
45
0 . 11
270
1320
LGA0410-R33
0.33
45
0.12
250
1280
LGA0410-R39
0.39
45
0.13
230
1200
LGA0410-R47
0.47
45
0.14
220
11 5 0
LGA0410-R56
0.56
45
0.15
200
11 2 2
LGA0410-R68
0.68
45
0.16
190
1030
LGA0410-R82
0.82
45
10.17
172
980
LGA0410-1R0
1.0
45
0.19
157
920
LGA0410-1R2
1.2
50
0.21
144
880
LGA0410-1R5
1.5
50
0.23
131
830
LGA0410-1R8
1.8
55
0.25
121
790
LGA0410-2R2
2.2
55
0.28
11 0
750
LGA0410-2R7
2.7
60
0.30
100
720
LGA0410-3R3
3.3
65
0.34
94
670
LGA0410-3R9
3.9
65
0.37
65
640
LGA0410-4R7
4.7
70
0.39
56
620
LGA0410-5R6
5.6
70
0.43
48
590
LGA0410-6R8
6.8
75
0.48
37
550
LGA0410-8R2
8.2
80
0.52
25
530
LGA0410-100
10
65
0.58
21
500
LGA0410-120
12
50
0.63
19
480
LGA0410-150
15
50
0.72
17
460
LGA0410-180
18
50
0.77
13
430
LGA0410-220
22
50
0.84
9.6
410
LGA0410-270
27
55
0.94
7.2
390
LGA0410-330
33
55
1.03
6.3
370
LGA0410-390
39
50
1.12
6.3
350
LGA0410-470
47
45
1.22
6.3
340
LGA0410-560
56
40
1.34
6.2
320
LGA0410-680
68
40
1.47
5.7
305
LGA0410-820
82
35
1.62
5.3
290
LGA0410-101
100
30
1.80
4.8
275
LGA0410-121
120
55
3.70
3.8
185
LGA0410-151
150
45
4.20
3.5
175
LGA0410-181
180
50
4.60
3.3
165
LGA0410-221
220
55
5.10
3.0
155
LGA0410-271
270
65
5.80
2.8
145
LGA0410-331
330
65
6.40
2.6
137
LGA0410-391
390
65
7.00
2.4
133
LGA0410-471
470
60
7.70
2.25
126
LGA0410-561
560
60
8.85
2.10
120
LGA0410-681
680
55
9.40
1.95
11 3
LGA0410-821
820
55
10.50
1.85
105
LGA0410-102
1000
50
14.00
1.40
100
HP4338B
HM9461
HP42841A
Test equipment
Ambient
temperature
Ambient
humidity
HP4285A
M
20%
K
10%
J
5%
18~25
45%~75%
161
25.2
7.96
2.52
0.796
LGA0510
LGA0510 TYPE INDUCTORS ELECTRICAL CHARACTERISTICS & TEST CONDITIONS
LGA0510
Type
Nominal
Inductance
( H)
Tolerance
Q
(min)
RDC
)max
Test frequency
(MHZ )
SRF
(MHZ )min
Rated current
I DC (mA)max
1.9
126
1.8
120
9.00
1.5
113
45
10.5
1.2
105
45
14.0
1.0
100
LGA0510-471
470
60
7.70
LGA0510-561
560
50
8.50
LGA0510-681
680
55
LGA0510-821
820
0.796
M
20%
LGA0510-102
1000
LGA0510-122
1200
40
16.0
0.95
95
LGA0510-152
1500
40
21.6
0.90
90
LGA0510-182
1800
40
24.0
0.85
85
LGA0510-222
2200
40
34.7
0.80
80
K
10%
0.252
LGA0510-272
2700
40
40.0
0.75
75
LGA0510-332
3300
40
59.5
0.70
62
LGA0510-392
3900
40
66.0
0.65
59
J
5%
LGA0510-472
4700
40
74.0
0.60
55
LGA0510-562
5600
30
80.0
0.50
40
LGA0510-682
6800
30
85.0
0.45
35
LGA0510-822
8200
30
95.0
0.40
30
LGA0510-103
10000
0.35
25
Test equipment
HP4285A
HP4338B
Ambient
temperature
18~25
Ambient
humidity
45%~75%
162
0.0796
HM9461
HP42841A
LGA
PACKAGING STYLE
TAPING DIMENSIONS
Unit: mm
6
0.5
:26
Tape width
Z
L
Tape style
26
1.0
L1-L2
0.8 Max
1.0 Max
:52
Tape width
+2.0
1.2 Max
52 -1.0
163
VERTICAL TAPING DIMENSIONS
Unit: mm
Codel
Dim.
Tol.
P0
P1
P2
d
12.7
12.7
3.85
6.35
0.6
1.0
0.2
0.7
0.4
P
0.1
W
W0
W1
W2
18.5
12
9
1.5
h
1.0
1.0
TAPE&REEL PACKAGING DIMENSIONS
164
1.0
1.5
H0
H1
15-20 32.25
0.5
Max
D0
I
F
4.0
1.4
5
Max
0.8
0.2
LGA
AMMO PACKAGING DIMENSIONS
DIMENSIONS OF BOX
Unit: mm
PACKAGING QUANTITY
Unit: Pcs
Packaging according to customer's requirement
165
很抱歉,暂时无法提供与“LGA0410-1R0KP52E”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.16741
- 200+0.13217
- 800+0.13085
- 2000+0.12823
- 国内价格
- 20+0.18274
- 200+0.14429
- 600+0.12291
