Gas Discharge Tubes(GDT)
3RA-5S Series
Description
Gas discharge tubes (GDT) use noble gasses enclosed in
ceramic tubes to provide an alternate circuit path for voltage
spikes. The ceramic envelope and with nickel connectors
allow for high loads. 3RA-5S Gas Discharge Tubes (GDT)
series has a surge rating of 5kA, 8/20μs.Offered in a
Squared Surface Mount package, which helps to make pick
and place on PCB process easier.
This GDT series is perfectly suited for broadband
equipment applications. The GDT’s low off-state
capacitance is compatible with high bandwidth applications
and this capacitance loading value does not vary if the
voltage across the GDT changes.
Electrical symbol
3RA-5S Gas Discharge Tube (GDT) series are specifically
designed for protection of electrical, multimedia, and
communication equipment against over voltage transients
in surface mount assembly applications.
a
b
e
Features
Applications
l
l
l
l
l
l
l
l
l
l
l
l Communication
equipment
l CATV equipment
l Data lines
l Power supplies
l Telecom SLIC protection
l Broadband equipment
Excellent response to fast rising transients
Stable breakdown voltage
GHz working frequency
8/20μs Impulse current capability: 5KA
Non-Radioactive
Ultra Low capacitance (
很抱歉,暂时无法提供与“3R090A-5S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+1.71658
- 500+1.68103
- 国内价格
- 1+8.95180
- 10+5.09340
- 50+3.75310
- 100+3.17890
- 500+2.17220
- 1000+2.07090
- 国内价格
- 5+3.92958
- 50+3.09852
- 150+2.69838
- 1000+1.94940
- 2000+1.84680
- 5000+1.78524
- 国内价格
- 1+2.38650
- 50+1.83150
- 1000+1.69830
- 国内价格
- 1+3.60212
- 10+3.54809
- 200+2.47351
- 400+2.43641
- 1000+1.78695
