SS52
SS52
    TWGMC(迪嘉)
    SMA(DO-214AC)
    SMA SMT 20V 5A
SS52 数据手册
SS52 THRU SS5200 Reverse Voltage - 20 to 200 Volts Forward Current - 5.0 Ampere SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER Features PINNING PIN  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 DESCRIPTION 1 Cathode 2 Anode  For surface mounted applications  Metal silicon junction,majority carrier conduction  Low power loss,high efficiency DO-214AC/SMA  Built-in strain relief,ideal for automated placement  High forward surge current capability  High temperature soldering guaranteed: 2 1 250 °C/10 seconds at terminals Mechanical Data      Unipolar Case : JEDEC DO-214AC/SMA molded plastic body Terminals: Solderable per MIL-STD-750,Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight : 0.002 ounce, 0.07 grams Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage SYMBOLS SS52 SS53 SS54 SS55 SS56 SS58 SS510 SS5150 SS5200 UNITS VRRM 20 14 20 30 21 30 40 28 40 50 35 50 60 42 60 80 56 80 100 70 100 150 105 150 200 140 200 V V V VRMS VDC Maximum average forward rectified current at TL(see fig.1) I(AV) 5.0 A Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) IFSM 125 A Maximum instantaneous forward voltage at 5.0A VF Maximum DC reverse current at rated DCblocking voltage TA=25℃ TA=125℃ Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) Operating junction temperature range TJ 20 0.85 10 1 mA ℃/W -50 to +150 -50 to +150 TSTG V pF 50.0 -50 to +125 0.95 0.2 2.0 200 Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas www.tw-gmc.com 0.70 0.5 IR CJ RJA Storage temperature range 0.55 ℃ ℃ SS52 THRU SS5200 Reverse Voltage - 20 to 200 Volts Fig.2 Typical Reverse Characteristics Instaneous Reverse Current ( μA) Average Forward Current (A) Fig.1 Forward Current Derating Curve 6.0 5.0 4.0 3.0 2.0 1.0 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 10 4 T J =75°C 10 2 10 1 T J =25°C 10 0 0 40 20 60 Fig.4 Typical Junction Capacitance T J =25°C Junction Capacitance ( pF) 20 10 1 SS52/SS54 SS56/SS58 SS510/SS520 0.1 0 0.5 1.0 1.5 1000 500 100 SS52/SS54 20 SS56~SS520 10 2.0 0.1 Transient Thermal Impedance( °C /W) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 160 140 120 100 80 60 40 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 10 1 100 Reverse Voltage (V) Instaneous Forward Voltage (V) 100 Number of Cycles at 60Hz www.tw-gmc.com 100 80 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic Instaneous Forward Current (A) T J =100°C 10 3 Case Temperature (°C) Peak Forward Surage Current (A) Forward Current - 5.0 Ampere Fig.6- Typical Transient Thermal Impedance 100 10 1 0.01 0.1 1 10 t, Pulse Duration(sec) 2 100 SS52 THRU SS5200 Reverse Voltage - 20 to 200 Volts PACKAGE OUTLINE A A Plastic surface mounted package; 2 leads c a VM e A HE g e E A D E HE c e g max 2.2 4.5 2.7 5.2 0.31 1.6 1.5 min 1.9 4.0 2.3 4.7 0.15 1.3 0.9 max 87 181 106 205 12 63 59 min 75 157 91 185 6 51 35 UNIT mm mil g e A D The recommended mounting pad size 2.4 (94) 1.8 (71) 1.8 (71) 1.8 (71) mm Unit : (mil) www.tw-gmc.com 3 a 0.3 12 Forward Current - 5.0 Ampere
SS52
物料型号: SS52, SS53, SS54, SS55, SS56, SS58, SS510, SS5150, SS5200
器件简介: - 这些是单极性表面安装肖特基势垒整流器。 - 塑料封装符合UL94V-0可燃性等级。 - 金属硅结,主要载流子导电。 - 低功耗,高效率。 - 内置应变缓解,适合自动化放置。 - 高前向浪涌电流能力。 - 保证高温焊接:250°C/10秒在端子。
引脚分配: - PIN 1: 阴极 - PIN 2: 阳极
参数特性: - 最大重复峰值反向电压 (VRRM): 20V 到 200V - 最大RMS电压 (VRMS): 14V 到 140V - 最大直流阻断电压 (Voc): 与最大重复峰值反向电压相同 - 最大平均前向整流电流 (IF(AV)): 5.0A - 峰值前向浪涌电流 (IFSM): 125A (SS53) - 最大瞬时前向电压 (VF): 0.55V 到 0.95V 在5.0A时 - 最大直流反向电流 (Ir): 0.5mA 到 2.0mA - 典型结电容 (CJ): 200pF - 典型热阻 (ROJA): 50.0°C/W - 工作结温范围 (TJ): -50°C 到 +125°C 或 +150°C - 存储温度范围 (TSTG): -50°C 到 +150°C
功能详解: - 提供了前向电流降额曲线、典型反向特性、典型前向特性、典型结电容、最大非重复峰值前向浪涌电流和典型瞬态热阻的图表。
应用信息: - 适用于单相半波60Hz的电阻性或感性负载,对于电容性负载电流需要降额20%。
封装信息: - 塑料表面安装封装,2引线。 - 推荐安装垫尺寸为1.8mm。
很抱歉,暂时无法提供与“SS52”相匹配的价格&库存,您可以联系我们找货
SS52
    • 10+0.27585
    • 100+0.22559
    • 1000+0.18087
    库存:1601
    SS52
    • 1+0.35420
    • 500+0.23650
    • 2500+0.20460
    • 5000+0.18700
    库存:7074
