SS12 THRU SS1200
Reverse Voltage - 20 to 200 Volts
Forward Current - 1.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
PINNING
PIN
The plastic package carries Underwriters Laboratory
DESCRIPTION
1
Cathode
2
Anode
Flammability Classification 94V-0
DO-214AC/SMA
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
2
1
250 °C/10 seconds at terminals
Mechanical Data
Unipolar
Ca s e : JEDEC DO-214AC/SMA molded plastic body
Termina ls : Solderable per MIL-STD-750,Method 2026
Po larity : Color band denotes cathode end Moun ting
Po s ition : Any
Weigh t : 0.002 ounce, 0.07 grams
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL(see fig.1)
SS1150
SS1200
UNITS
SYMBOLS SS12
SS13
SS14
SS15
SS16
SS18
SS110
VRRM
40
50
60
80
100
150
200
V
VRMS
VDC
14
30
28
40
35
50
42
60
56
80
70
100
105
150
140
200
V
V
I(AV)
1.0
A
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
30
A
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
TA=25℃
at rated DCblocking voltage
TA=125℃
VF
Peak forward surge current
Typical junction capacitance (NOTE 1)
CJ
RθJA
Operating junction temperature range
TJ
0.85
0.2
5.0
90
110
-50 to +150
TSTG
1
V
mA
pF
-50 to +150
-50 to +125
0.9
2.0
88.0
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
www.tw-gmc.com
0.70
0.5
10.0
IR
Typical thermal resistance (NOTE 2)
Storage temperature range
0.55
0.45
℃/W
SS12 THRU SS1200
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
Average Forward Current (A)
1.5
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
10 4
T J =75°C
10 2
SS12/SS14
SS16-SS120
10
1
T J =25°C
10 0
80
100
Percent of Rated Peak Reverse Voltage(%)
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
500
Junction Capacitance ( pF)
Instaneous Forward Current (A)
T J =100°C
10 3
Case Temperature (°C)
10
1.0
SS12/SS14
SS16/SS18
SS110/SS112
SS115/SS120
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
T J =25°C
200
100
50
SS12/SS14
SS16-SS120
10
1.8
0.1
Transient Thermal Impedance( °C /W)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
36
30
24
18
12
06
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles at 60Hz
www.tw-gmc.com
1
100
10
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.6- Typical Transient Thermal Impedance
100
10
1
0.01
0.1
1
10
t, Pulse Duration(sec)
2
100
SS12 THRU SS1200
PACKAGE OUTLINE
A
A
Plastic surface mounted package; 2 leads
c
a
VM
e
A
HE
g
e
E
A
D
E
HE
c
e
g
max
2.2
4.5
2.7
5.2
0.31
1.6
1.5
min
1.9
4.0
2.3
4.7
0.15
1.3
0.9
max
87
181
106
205
12
63
59
min
75
157
91
185
6
51
35
UNIT
mm
mil
g
e
A
D
The recommended mounting pad size
2.4
(94)
1.8
(71)
1.8
(71)
1.8
(71)
mm
Unit :
(mil)
www.tw-gmc.com
3
a
0.3
12
很抱歉,暂时无法提供与“SS12”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.09408
- 500+0.07306
- 2000+0.06156
- 4000+0.05459
- 24000+0.04854
- 50000+0.04526
- 国内价格
- 20+0.20240
- 100+0.12070
- 500+0.08450
- 2000+0.06040
- 4000+0.05740
- 20000+0.05310
- 国内价格
- 1+0.12210
- 50+0.06105
- 2000+0.04620
