SS54C
SS54C
    JINGDAO(晶导微电子)
    SMC(DO-214AB)
    肖特基二极管SMC(DO-214AB) 40V 5A 50mA
SS54C 数据手册
山东晶导微电子有限公司 SS52C THRU SS520C Jingdao Microelectronics Surface Mount Schottky Barrier Rectifier Reverse Voltage - 20 to 200V Forward Current - 5.0A PINNING PIN FEATURES • Metal silicon junction, majority carrier conduction • For surface mounted applications • Low power loss, high efficiency • High forward surge current capability • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications DESCRIPTION 1 Cathode 2 Anode 1 2 Top View Marking Code: SS52 ~ SS520 Simplified outline SMC and symbol MECHANICAL DATA • Case: SMC • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 0.22g / 0.0077oz Absolute Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load, for capacitive load, derate by 20 % Symbols Parameter SS52C SS54C SS56C SS58C SS510C SS512C SS515C SS520C Units Maximum Repetitive Peak Reverse Voltage V RRM 20 40 60 80 100 120 150 200 V Maximum RMS voltage V RMS 14 28 42 56 70 84 105 140 V Maximum DC Blocking Voltage V DC 20 40 60 80 100 120 150 200 V Maximum Average Forward Rectified Current I F(AV) Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) I FSM Max Instantaneous Forward Voltage at 5 A Maximum DC Reverse Current T a = 25°C at Rated DC Reverse Voltage T a =100°C Typical Junction Capacitance (1) Typical Thermal Resistance (2) Operating Junction Temperature Range Storage Temperature Range VF A 5.0 175 0.45 0.55 1.0 50 IR Cj 0.70 A 0.85 V mA 400 600 150 pF RθJA 35 °C/W Tj -55 ~ +150 °C T stg -55 ~ +150 °C (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. 2017.01 SMC-S-SS52C~SS520C-5A200V Page 1 of 3 山东晶导微电子有限公司 SS52C THRU SS520C Jingdao Microelectronics Fig.2 Typical Reverse Characteristics Average Forward Current (A) 6.0 5.0 4.0 3.0 2.0 1.0 0.0 25 50 75 100 125 150 Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve 10 4 T J =100°C 10 3 10 1 T J =25°C 10 0 0 Case Temperature (°C) 60 80 100 Fig.4 Typical Junction Capacitance T J =25°C Junction Capacitance ( pF) 20 10 1 SS52C SS54C SS56C/SS58C SS510C/SS520C 0.1 0 0.5 1.0 1.5 100 SS52C/SS54C SS54F/SS520F SS56C~SS520C 20 10 0.1 1 10 100 Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance SS52C~SS58C 175 SS510C~SS520C 150 125 100 75 50 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 500 Instaneous Forward Voltage (V) 180 25 1000 2.0 10 100 Transient Thermal Impedance( °C /W) Instaneous Forward Current (A) Peak Forward Surage Current (A) 40 20 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic 100 10 Number of Cycles at 60Hz 2017.01 T J =75°C 10 2 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) www.sdjingdao.com Page 2 of 3 山东晶导微电子有限公司 SS52C THRU SS520C Jingdao Microelectronics PACKAGE OUTLINE SMC Plastic surface mounted package; 2 leads E A A1 A C b D L E1 VM A SMC mechanical data A E D E1 A1 C L b max 2.62 7.0 6.2 8.0 0.21 0.31 1.6 3.25 min 2.00 6.5 5.6 7.6 0.05 0.15 0.9 2.75 max 103 276 244 315 8.3 12 63 128 min 79 256 220 299 2.0 5.9 35 108 UNIT mm mil Marking The recommended mounting pad size Type number 3.8 (150) 4.1 (160) 4.3 (170) 4.1 (160) mm Unit : (mil) 2017.01 702227B0 Marking code SS52C SS52 SS54C SS54 SS56C SS56 SS58C SS58 SS510C SS510 SS512C SS512 SS515C SS515 SS520C SS520 Page 3 of 3
SS54C 价格&库存
很抱歉,暂时无法提供与“SS54C”相匹配的价格&库存,您可以联系我们找货
SS54C
  • 1+0.46530
  • 200+0.30030
  • 1500+0.26070
  • 3000+0.23100
库存:23971
SS54C
  • 10+0.39917
  • 100+0.31987
  • 600+0.28017
  • 1200+0.27597
  • 3000+0.25037
  • 15000+0.24787
库存:27692
SS54C
  • 10+0.42770
  • 100+0.34260
  • 300+0.30000
  • 3000+0.26790
  • 6000+0.24240
库存:14630
SS54C
  • 20+0.75690
  • 100+0.45150
  • 800+0.31600
  • 3000+0.22570
  • 6000+0.21450
  • 30000+0.19860
库存:22034
SS54C
    • 1+0.42260
    库存:10
