Lead Type Disc High Voltage Ceramic Capacitors-HV Series (500VDC-6.3KVDC)
(500VDC-6.3KVDC) Data Sheet
Feature
■Wide capacitance range from 100pF to 100000pF
■Operating Temperature: -25℃~85℃
■Storage Temperature: 15℃~35℃
■The high voltage disc ceramic capacitors have feature of withstanding higher voltage
Applications
■These capacitors are used in bypass and coupling circuit, and those capacitors with low dissipation
factor are particularly suitat be used in cicuits such as line scanning in Tvset
Revision: 2018-04-29
1
Email: info@songtian.cn
Website: http://www.songtian-ste.com
Part Number Code
N
07
F
1
B
472
Pitch
A:2.5mm
B:5.0mm
E:7.5mm
D:10.0mm
Rated
Voltage
L: 500VDC
N: 1KVDC
R: 2KVDC
S: 3KVDC
T: 4KVDC
W: 5KVDC
A: 6KVDC
M
N0
B
Tolerance
C:±0.25pF
J±5%
:K:±10%
M:±20%
Foot Type
1:Long straight
2:Outside Crimped
3:Short Straight
4:Inner Crimped
8:Vertical Crimped
Temperature
Characteristic
A:NP0
S:SL
B:Y5P
E:Y5U
F:Y5V
S
Package
B: Bulk
T:Tape
N
Inner
Management
Environmental
Standard
0:RoHS
2:RoHS+Halogen-Free
Nominal capacitance
10:100pF
100:101pF
222:2200pF
103:10000pF
Core Diameter
04: 4.0mm
05: 5.0mm
16: 16.0mm
C0: 5.0mm
C4: 5.4mm
C6: 5.6mm
Lead Length
S0~S9:1.0~1.9mm
X0~X9:2.0~2.9mm
A0~A9:3.0~3.9mm
B0~B9:4.0~4.9mm
C0~C9:5.0~5.9mm
D0~D9:6.0~6.9mm
E0~E9:7.0~7.9mm
Lead Length
F0~F9:8.0~8.9mm
G0~G9:9.0~9.9mm
H0~H9:10.0~10.9mm
J0~J9:11.0~11.9mm
K0~K9:12.0~12.9mm
L0~L9:13.0~13.9mm
M0~M9:14.0~14.9mm
Lead Length
M0~M9:14.0~14.9mm
N0:16~27.0mm(Bulk)
Crimped Lead Taped
N0:H0=16.5mm
P0:H0=17.0mm
Q0:H0=19.0mm
Straight Lead
Q0:20.0mm
Specifications
Capacitance and Dissipation factor testing condition
Dissipation Factor(tanδ)
Rated Voltage
Withstand Voltage
SL/NP0:25℃、1±0.1MHz、1.0Vrms
Y5P/Y5U/Y5V:25℃、1±0.1MHz、1.0Vrms
SL/NPO:≤0.15%
Y5P/Y5U/Y5V:≤2.5%
500VDC、1000VDC、2000VDC、3000VDC、4000VDC、5000VDC、
6000VDC
1.5UR+500V(DC)
Insulation Resistance (I.R.)
SL/NP0:IR≥10000MΩ;Y5P/Y5U/Y5V:IR≥4000MΩ
Temperature Characteristic
SL、NP0、Y5P、Y5U、Y5V
2
Dimensions (mm)
Rated
Voltage
(VDC)
500
1000
2000
Temperature Coefficient Group
Y5P (B)
Y5U (E)
Dimension (mm)
Y5V (F)
SL
NP0
D±1
Lead Size (mm)
T±1
F
d±0.05
2.0
5.0±0.8
0.5
7.5±0.8
0.6
10.0±0.8
0.7
5.0±0.8
0.5
7.5±0.8
0.6
10.0±0.8
0.6/0.7
5.0±0.8
0.5
7.5±0.8
0.6
Nominal Capacitance(pF)
100-1500
1500-2200
3300-4700
20-150
0.5-22
5.5
3300-4700
6800
6.5
2200
5600-6800
6800-10000
7.5
3300
10000
9.5
4700
20000-22000
10.5
10000
14.5
47000
17.0
100000
20.0
100-820
20-100
0.5-22
5.5
1000
6.0
1500-3300
4700-6800
6.5
1500-1800
4700-5600
7.5
2200-2700
10000
8.5
6800
15000
9.5
3300
10000
10.5
4700
11.5
20000-22000
13.0
33000
15.0
10000
47000
17.5
100000
22.5
100-470
1000
1500-2200
6.0
560-820
3300
10-120
0.5-10
7.0
1000
2200
4700
68
8.0
1500
4700
6800
10.0
1800-2200
10000
11.0
2700
12.0
3300
13.0
2200
14.0
4700
10000
20000-22000
14.5
3
2.5
2.5
2.5/3.0
3.0
Rated
Voltage
(VDC)
3000
3150
4000
5000
Y5P(B)
Y5U(E)
Dimension (mm)
Y5V(F)
SL
NPO
D±1
T±1
3.0/3.5
Lead Size (mm)
F
d±0.05
7.5±0.8
0.6
100-470
680-1000
1500
27-68
3-22
6.0
270-680
2200
7.0
1500
3300
82
8.0
1000
2200
4700
9.0
3300
6800-10000
11.0
4700
10000
13.0
10000
17.5
20000-22000
20.5
100-470
1000
1500
10-39
6.0
680
2200
47-68
7.0
1500
3300
82
8.0
1000
2200
4700
9.0
1500
3200
11.0
2200
4700
13.0
10000
14.0
10.0
10000
17.5
±0.8
100-470
680-1000
1500
10-68
3-22
6.0
270-680
2200
7.0
1500
3300
82
8.0
1000
2200
4700
9.0
3300
6800-10000
11.0
4700
10000
13.0
10000
17.5
20000-22000
20.5
100-220
330-470
1000
10-39
6.0
330
560-1000
1500
47-56
7.0
470
2200
68-82
8.0
560-680
1500
9.0
2200
3300
10.0
1000
4700
11.0
3300
13.5
4700
16.5
4
3.5
10.0
±0.8
7.5±0.8
0.6/0.7
0.6
3.5
0.7
3.0/3.5
7.5±0.8
0.6
3.5
10.0
±0.8
0.6/0.7
3.5/4.5
10.0
4.5
±0.8
0.6/0.7
Rated
Voltage
(VDC)
6000
6300
Y5P(B)
Y5U(E)
Dimension (mm)
Y5V(F)
SL
NPO
D±1
T±1
3.5/4.5
Lead Size (mm)
F
d±0.05
100-220
330-470
1000
10-39
6.0
330
560-1000
1500
47-56
7.0
470
2200
68-82
8.0
560-680
1500
9.0
2200
3300
10.0
1000
4700
11.0
3300
13.5
4700
16.5
100-220
1000
10-39
6.0
330
47-68
7.0
470
2200
82
8.0
10.0
680
9.0
±0.8
1000
2200
3300
10.0
4700
11.0
5
10.0
4.5
±0.8
0.6/0.7
3.5/4.5
4.5
0.6/0.7
Lead Configuration
Lead Style
Lead Length
L (mm)
Drawing
Long Straight
16.0 min
Coating Lead Length
C (mm)
①C≤2.5mm
(Product diameter﹤12mm)
②C≤3.0mm
(Product diameter≥12mm)
①[2.5≤L<6.0]+/-0.5;
②[6.0≤L≤10]+/-1.0
Short Straight
①C≤2.5mm
②C≤3.0mm
Outside Crimped
①[2.5≤L<6.0]+/-0.5;
②[6.0≤L≤10]+/-1.0
Not exceed the bend point
Inner Crimped
①[2.5≤L<6.0]+/-0.5;
②[6.0≤L≤10]+/-1.0
Vertical Crimped
①[2.5≤L<6.0]+/-0.5;
②[6.0≤L≤10]+/-1.0
6
Taping And Dimensions (mm)
Fig.1
Fig.2
Figure
Fig.1 (P=5.0)
Symbol
P=5.0
P=7.5
P=10.0
Po
12.7±0.3
12.7±0.3
12.7±0.3
P
12.7±1.0
25.4±1.0
25.4±1.0
P1
3.85±0.7
8.95±0.7
7.7±0.7
P2
6.35±1.3
12.7±1.3
12.7±1.3
F
5±0.8
7.5±0.8
10.0±0.8
Δh
0±2.0
0±2.0
0±2.0
W
18.0+1.5/-1.0
18.0 +1.5/-1.0
18.0 +1.5/-1.0
Wo
10.5 Max
10.5 Max
10.5 Max
W1
9.0+0.75/-0.5
9.0+0.75/-0.5
9.0+0.75/-0.5
W2
3.0 Max
3.0 Max
3.0 Max
Do
4.0±0.2
4.0±0.2
4.0±0.2
H
20+1.5/-1.0
20+1.5/-1.0
20+1.5/-1.0
16.5&17.0&19.0
16.5&17.0&19.0
16.5&17.0&19.0
Ho
+1.5/-1.0
+1.5/-1.0
+1.5/-1.0
Straight
Lead
Crimped
Lead
Straight
Lead
Crimped
Lead
Straight
Lead
Crimped
Lead
11.0
Max
9.0
Max
11.0
Max
9.0
Max
11.0
Max
9.0
Max
L
Fig.2 (P=7.5 & 10)
t1
0.5±0.2
0.5±0.2
0.5±0.2
t2
1.7 Max
1.7 Max
1.7 Max
7
很抱歉,暂时无法提供与“R11F1E103MN0B0S0N0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+0.49500
- 200+0.44000
- 300+0.42900
- 400+0.41800
- 国内价格
- 10+0.50771
- 100+0.40922
- 500+0.34020
- 1000+0.30327
- 5000+0.27368
- 10000+0.25888
- 国内价格
- 10+0.46070
- 100+0.37132
