WR12X242JTL
WR12X242JTL
    WALSIN(华新科)
    贴片电阻 1206 2.4KΩ ±5% 1/4W ±100ppm/℃
WR12X242JTL 数据手册
Approval sheet WR12, WR08, WR06, WR04 ±1%, ±5% Thick Film General Purpose Chip Resistors Size 1206, 0805, 0603, 0402 *Contents in this sheet are subject to change without prior notice. Page 1 of 10 ASC_WR_V23 APR.- 2015 Approval sheet FEATURE 1. High reliability and stability 2. Reduced size of final equipment 3. Lower assembly costs 4. Higher component and equipment reliability 5. RoHS compliant and Lead free products APPLICATION • Consumer electrical equipment • EDP, Computer application • Telecom application DESCRIPTION The resistors are constructed in a high grade ceramic body (aluminum oxide). Internal metal electrodes are added at each end and connected by a resistive paste that is applied to the top surface of the substrate. The composition of the paste is adjusted to give the approximate resistance required and the value is trimmed to within tolerance by laser cutting of this resistive layer. The resistive layer is covered with a protective coat. Finally, the two external end terminations are added. For ease of soldering the outer layer of these end terminations is a Tin (lead free) alloy. Fig 1. Construction of Chip-R Page 2 of 10 ASC_WR_V23 APR.- 2015 Approval sheet QUICK REFERENCE DATA Item General Specification Series No. WR12 WR08 WR06 WR04 Size code 1206(3216) 0805(2012) 0603(1608) 0402(1005) Resistance Range 1Ω~10MΩ (±5% tolerance), Jumper 1Ω~10MΩ (±1% tolerance), Resistance Tolerance ±1% ±5% ±1% ±5% ±1% ±5% ±1% ±5% E96/E24 E24 E96/E24 E24 E96/E24 E24 E96/E24 E24 TCR (ppm/°C) 10MΩ ≥R>10Ω ≤ ± 100 R≤10Ω -200~+400 Max. dissipation @ Tamb=70°C 1/4 W 1/8 W 1/10 W 1/16 W Max. Operation Voltage (DC or RMS) 200V 150V 75V 50V Max. Overload Voltage (DC or RMS) 400V 300V 150V 100V Climatic category 55/155/56 Note : 1. This is the maximum voltage that may be continuously supplied to the resistor element, see “IEC publication 60115-8” 2. Max. Operation Voltage : So called RCWV (Rated Continuous Working Voltage) is determined by RCWV = Rated Power × Resistance Value or Max. RCWV listed above, whichever is lower. 3. The resistance of Jumper is defined 1MΩ B Jumper =000_ D : 7'' reel 20Kpcs only for 0402 (“_” means a blank) ±1%, E24+E96: 3 significant digits followed by no. of zeros 102Ω =1020 37.4KΩ =3742 : 7” Reeled taping : Bulk A : 7" reel 15Kpcs only for 0402 WR12, WR08, WR06: 1. Reeled tape packaging : 8mm width paper taping 5000pcs per 7” reel, 10kpcs per 10” reel, 20kpcs per 13” reel. 2. Bulk packaging Page 6 of 10 : 5000pcs per poly-bag ASC_WR_V23 APR.- 2015 Approval sheet WR04: 1. reel. 2. Reeled tape packaging : 8mm width paper taping 10,000pcs per 7” reel, 20,000pcs per 10” reel. 70,000pcs per 13” Bulk packaging Page 7 of 10 : 10,000pcs per poly-bag ASC_WR_V23 APR.- 2015 Approval sheet TEST AND REQUIREMENTS Essentially all tests are carried out according to the schedule of IEC publication 115-8, category LCT/UCT/56(rated temperature range : Lower Category Temperature, Upper Category Temperature; damp heat, long term, 56 days). The testing also meets the requirements specified by EIA, EIAJ and JIS. The tests are carried out in accordance with IEC publication 68, "Recommended basic climatic and mechanical robustness testing procedure for electronic components" and under standard atmospheric conditions according to IEC 60068-1, subclause 5.3. Unless otherwise specified, the following value supplied : Temperature: 15°C to 35°C. Relative humidity: 45% to 75%. Air pressure: 86kPa to 106 kPa (860 mbar to 1060 mbar). All soldering tests are performed with midly activated flux. TEST REQUIREMENT PROCEDURE / TEST METHOD 0Ω Ω Resistor Electrical - DC resistance values measurement Within the specified tolerance Characteristics - Temperature Coefficient of Resistance (T.C.R) Refer to “QUICK REFERENCE Natural resistance change per change in degree centigrade. DATA” R2 − R1 × 106 R1 (t2 − t1 ) JISC5201-1: 1998 Clause 4.8 (ppm/°C) t1 : 20°C+5°C-1°C; t 2
WR12X242JTL
1. 物料型号:WR12、WR08、WR06、WR04,分别对应不同的尺寸代码1206(3216)、0805(2012)、0603(1608)、0402(1005)。
2. 器件简介:这些电阻器具有高可靠性和稳定性,有助于减小最终设备的尺寸,降低组装成本,提高组件和设备的可靠性,并且符合RoHS标准,无铅产品。
3. 引脚分配:文档中没有明确提到引脚分配,但提到了电阻器的构造,包括激光修调保护层、电阻元件、标记、主要层、端子和氧化铝基板。
4. 参数特性:电阻范围、公差(±1%和±5%)、温度系数(TCR)、最大耗散功率、最大工作电压、最大过载电压、气候类别和尺寸信息。
5. 功能详解:电阻器采用高等级陶瓷体构造,内部金属电极通过电阻浆料连接,并通过激光切割修调至所需电阻值。电阻层被保护涂层覆盖,端子外部涂有锡(无铅)合金,便于焊接。
6. 应用信息:适用于消费电子设备、电子数据处理、计算机应用和电信应用。
7. 封装信息:提供了不同尺寸的电阻器的尺寸数据,包括长度、宽度、厚度等。
8. 标记:根据尺寸和公差,电阻器的保护涂层上有不同的标记方式,包括3位数字和4位数字的标记。
9. 功能描述:详细描述了产品特性、标准电阻值、降额使用、安装、存储和处理条件。
10. 焊接条件:提供了焊接条件的详细信息,包括焊接浴温度和时间。
11. 目录编号:列出了电阻器的目录编号系统,包括尺寸代码、类型代码、电阻代码、公差、包装代码和端子代码。
12. 测试和要求:根据IEC、EIA、EIAJ和JIS标准,列出了电阻器需要进行的测试和要求。
13. 包装:提供了不同系列电阻器的包装规格,包括纸带规格和卷轴尺寸。
WR12X242JTL 价格&库存
很抱歉,暂时无法提供与“WR12X242JTL”相匹配的价格&库存,您可以联系我们找货
WR12X242 JTL
  • 10+0.42163
  • 100+0.16745
  • 500+0.08552
  • 1000+0.06590
  • 2500+0.05700
  • 5000+0.04819
  • 10000+0.03952
  • 20000+0.03686
库存:3970
