DCL5R5105HF
DCL5R5105HF
    KORCHIP(高奇普)
    CAP_D19X6.5MM_TM
    超级电容器 CAP_D19X6.5MM_TM 1F -20~+80% 5.5V
DCL5R5105HF 数据手册
DCL series | Features | • Standard coin-type • Small-sized, large capacity • Wider temperature range(-25~70℃) than battery makes periodic change unnecessary | Applications | • Memory back-up for Video, Audio, Cameras, Camcorder, Telephones, Printer Car stereo, Computer, Notebook PC, Rice cooker, PLC, Set top box, Washing machine, DVD-RW, Home network etc. • Main power for Bicycle tail light, flash lights etc. V-TYPE H-TYPE C-TYPE | Specifications | Items Characteristics Rated working voltage 5.5VDC Operating temperature -25 to +70℃ Maximum surge voltage 6.3VDC Nominal Cap. range 1.0F / 1.5F Capacitance tolerance -20% to +80%(at 25℃) Low temperature(-25℃) characteristics Capacitance change : ≤ 50% of the initial value at +25℃ Internal resistance : Less than five times of the initial value at +25℃ After 1,000hours application of rated DC working voltage at +70℃, the capacitor shall meet the following limits. • Capacitance change : ±30% of the initial value • Internal resistance : Less than four times of the initial value Endurance After 1,000hours storage at +70℃ without load, the capacitor shall meet the specified limit for “Endurance” Shelf life | Dimensions in mm(not to scale) | H-TYPE V-TYPE C-TYPE 0,8±0,1 1,2±0,1 | Standard products | Part Number Operating Voltage (V) Capacitance (F) ESR (Ω, @1kHz) DCL 5R5 105 5.5 1.0 ≤ 30 DCL 5R5 155 5.5 1.5 ≤ 30 V type(mm) ΦD H H type(mm) P ΦD H 19.0 19.5 5.0 19.0 6.5 19.0 19.5 5.0 19.0 6.5 P C type(mm) ΦD H P 20.0 21.5 7.5 5.0 20.0 21.5 7.5 5.0 Note : It is not allowed to go through reflow (IR, Atmosphere heating methods etc.) process Homepage : http://www.korchip.com Head office : 82-31-361-8031~6 (Fax : 82-31-361-8080) E-mail : starcap@korchip.com
DCL5R5105HF 价格&库存
很抱歉,暂时无法提供与“DCL5R5105HF”相匹配的价格&库存,您可以联系我们找货
DCL5R5105HF
  • 1+5.40200
  • 30+5.21950
  • 100+4.85450
  • 500+4.48950
  • 1000+4.30700
  • 2000+4.12450
库存:450
