ESD5451X-2/TR
ESD5451X-2/TR
    WILLSEMI(韦尔)
    FBP-02C
    ESD抑制器/TVS二极管 双向 5V 8A 80W FBP-02C
ESD5451X-2/TR 数据手册
ESD5451X ESD5451X http//:www.sh-willsemi.com 1-Line, Bi-directional, Transient Voltage Suppressors Descriptions The ESD5451X is a bi-directional TVS (Transient Voltage Suppressor). It is specifically designed to protect sensitive electronic components which are connected to low speed data lines and control lines from over-stress caused by ESD (Electrostatic Discharge), EFT (Electrical Fast Transients) and Lightning. FBP-02C (Bottom View) The ESD5451X may be used to provide ESD protection up to ±30kV (contact and air discharge) according to IEC61000-4-2, and withstand peak pulse current up to 8A (8/20μs) according to IEC61000-4-5. The ESD5451X is available in FBP-02C package. Standard products are Pb-free and Halogen-free. Circuit diagram Features  Reverse stand-off voltage: ±5V Max  Transient protection for each line according to IEC61000-4-2 (ESD): ±30kV (contact and air discharge) IEC61000-4-4 (EFT): 40A (5/50ns) IEC61000-4-5 (surge): 8A (8/20μs) 5 = Device code  Capacitance: CJ = 17.5pF typ.  Low leakage current: IR < 1nA typ.  Low clamping voltage: VCL = 9V typ. @ IPP = 16A (TLP)  Solid-state silicon technology * = Month code ( A~Z) Marking (Top View) Order information Applications  Cellular handsets  Tablets  Laptops  Other portable devices  Network communication devices Will Semiconductor Ltd. 1 Device Package Shipping ESD5451X-2/TR FBP-02C 10000/Tape&Reel Revision 1.1, 2014/07/31 ESD5451X Absolute maximum ratings Parameter Symbol Rating Unit Peak pulse power (tp = 8/20μs) Ppk 80 W Peak pulse current (tp = 8/20μs) IPP 8 A ESD according to IEC61000-4-2 air discharge VESD ESD according to IEC61000-4-2 contact discharge Operation junction temperature Storage temperature kV ±30 125 o TL 260 o TSTG -55~150 o TJ Lead temperature ±30 C C C Electrical characteristics (TA=25 oC, unless otherwise noted) I VRWM Reverse stand-off voltage IR Reverse leakage current VCL Clamping voltage IPP Peak pulse current IPP IHOLD VCL VTRIG VHOLD VBR VRWM IBR ITRIG IR IR ITRIG IBR VRWM VBR VHOLD VTRIG VCL V IHOLD VTRIG Reverse trigger voltage ITRIG Reverse trigger current VBR Reverse breakdown voltage IBR Reverse breakdown current VHOLD Reverse holding voltage IPP IHOLD Reverse holding current Definitions of electrical characteristics Will Semiconductor Ltd. 2 Revision 1.1, 2014/07/31 ESD5451X o Electrical characteristics (TA=25 C, unless otherwise noted) Parameter Symbol Condition Min. Typ. Max. Unit ±5 V 100 nA Reverse stand-off voltage VRWM Reverse leakage current IR VRWM = 5V VBR IBR = 1mA 5.1 V IHOLD = 50mA 5.1 V Reverse breakdown voltage Reverse holding voltage VHOLD
ESD5451X-2/TR
物料型号:ESD5451X
器件简介: - ESD5451X是一款双向TVS(瞬态电压抑制器),专为保护连接到低速数据线和控制线的敏感电子元件而设计,以防止ESD(静电放电)、EFT(电快速瞬变)和雷击引起的过应力。
引脚分配: - PDF文档中没有明确指出具体的引脚分配,但通常双向TVS会有至少两个引脚,用于连接被保护的线路。
参数特性: - 反向承受电压:±5V - ESD保护:IEC61000-4-2标准下接触和空气放电可达±30kV - EFT保护:IEC61000-4-4标准下40A(5/50ns) - 浪涌保护:IEC61000-4-5标准下8A(8/20μs) - 电容:CJ = 17.5pF(典型值) - 漏电流:IR < 1nA(典型值) - 钳位电压:VCL = 9V(典型值,16A TLP测试)
功能详解: - ESD5451X用于保护电子设备免受静电放电和电快速瞬变的影响,能够承受高达30kV的ESD冲击,并在8/20μs的脉冲下承受高达8A的峰值脉冲电流。
应用信息: - 适用于手机、平板电脑、笔记本电脑、其他便携设备和网络通信设备。
封装信息: - ESD5451X采用FBP-02C封装,标准产品无铅无卤。
ESD5451X-2/TR 价格&库存
很抱歉,暂时无法提供与“ESD5451X-2/TR”相匹配的价格&库存,您可以联系我们找货
ESD5451X-2/TR
  • 20+0.28190
  • 100+0.16810
  • 1000+0.11760
  • 10000+0.08410
  • 20000+0.07990
  • 100000+0.07390
库存:209363
ESD5451X-2/TR
    • 1+0.35310
    • 500+0.11770
    • 5000+0.07854
    • 10000+0.06435
    库存:119363
    ESD5451X-2/TR
    • 50+0.09672
    • 2000+0.06702
    • 4000+0.06601
    • 10000+0.05752
    • 50000+0.04901
    • 100000+0.04852
    库存:103165
