ESD5411N
ESD5411N
1-Line, Bi-directional, Transient Voltage Suppressors
http//:www.sh-willsemi.com
Descriptions
The ESD5411N is a bi-directional TVS (Transient Voltage
Suppressor). It is specifically designed to protect sensitive
electronic components which are connected to low speed
data lines and control lines from over-stress caused by ESD
(Electrostatic Discharge), EFT (Electrical Fast Transients)
DFN1006-2L (Bottom View)
and Lightning.
The ESD5411N may be used to provide ESD protection up to
±30kV
(contact
and
air
discharge)
according
to
IEC61000-4-2, and withstand peak pulse current up to 6A
(8/20μs) according to IEC61000-4-5.
The ESD5411N is available in DFN1006-2L package.
Pin1
Pin2
Standard products are Pb-free and Halogen-free.
Features
Pin configuration
Stand-off voltage: 7V Max.
Transient protection for each line according to
IEC61000-4-2 (ESD): ±30kV (contact discharge)
Pin1
IEC61000-4-5 (surge): 6 A (8/20μs)
G*
Capacitance: CJ = 17.5pF typ.
Ultra-low leakage current: IR < 5nA typ.
Low clamping voltage: VCL = 12V typ. @ IPP = 16A (TLP)
G = Device code
Solid-state silicon technology
* = Month code (A~Z)
Pin2
Marking (Top View)
Applications
Cellular handsets
Tablets
Laptops
Other portable devices
Network communication devices
Will Semiconductor Ltd.
Order information
Device
Package
Shipping
ESD5411N-2/TR DFN1006-2L 10000/Tape&Reel
1
Revision 1.1, 2018/04/23
ESD5411N
Absolute maximum ratings
Parameter
Symbol
Rating
Unit
Peak pulse power (tp = 8/20μs)
Ppk
70
W
Peak pulse current (tp = 8/20μs)
IPP
6
A
ESD according to IEC61000-4-2 air discharge
VESD
ESD according to IEC61000-4-2 contact discharge
Junction temperature
TJ
Operating temperature
TOP
Lead temperature
TL
Storage temperature
TSTG
±30
kV
±30
125
o
-40~85
o
260
o
-55~150
o
C
C
C
C
Electrical characteristics (TA=25 oC, unless otherwise noted)
VRWM Reverse stand-off voltage
IR
Reverse leakage current
VCL
Clamping voltage
IPP
Peak pulse current
IPP
IHOLD
VCL
VTRIG VHOLD
VBR VRWM
IBR
ITRIG
IR
IR
ITRIG
IBR
VRWM VBR
VHOLD VTRIG
VCL
V
IHOLD
VTRIG Reverse trigger voltage
ITRIG
Reverse trigger current
VBR
Reverse breakdown voltage
IBR
Reverse breakdown current
VHOLD Reverse holding voltage
IPP
IHOLD Reverse holding current
Definitions of electrical characteristics
2
ESD5411N
o
Electrical characteristics (TA=25 C, unless otherwise noted)
Parameter
Symbol
Reverse maximum working voltage
VRWM
IR
Clamping voltage
VBR
VHOLD
1)
Dynamic resistance
VCL
1)
2)
VCL
Clamping voltage
3)
VCL
Min.
VRWM = 7V
Typ.
很抱歉,暂时无法提供与“ESD5411N-2/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.11068
- 1000+0.09692
