ESD5311N
ESD5311N
http//:www.willsemi.com
1-Line, Bi-directional, Ultra-low Capacitance
Transient Voltage Suppressors
Descriptions
The ESD5311N is an ultra-low capacitance TVS (Transient
Voltage Suppressor) designed to protect high speed data
interfaces. It has been specifically designed to protect
sensitive electronic components which are connected to data
DFN1006-2L (Bottom View)
and transmission lines from over-stress caused by ESD
(Electrostatic Discharge).
The ESD5311N incorporates one pair of ultra- low
capacitance steering diodes plus a TVS diode.
The ESD5311N may be used to provide ESD protection up to
±20kV (contact discharge) according to IEC61000-4-2, and
Pin2
Pin1
withstand peak pulse current up to 4A (8/20μs) according to
IEC61000-4-5.
The ESD5311N is available in DFN1006-2L package.
Standard products are Pb-free and Halogen-free.
Pin configuration
Features
Stand-off voltage: 5V Max
Transient protection for each line according to
Pin1
8*
Pin2
IEC61000-4-2 (ESD): ±20kV (contact discharge)
IEC61000-4-5 (surge): 4 A (8/20μs)
8 = Device code
Ultra-low capacitance: CJ = 0.25pF typ.
* = Month code ( A~Z)
Ultra-low leakage current: IR < 1nA typ.
Marking (Top View)
Low clamping voltage: VCL = 21V typ. @ IPP = 16A (TLP)
Solid-state silicon technology
Order information
Applications
Device
USB 2.0 and USB 3.0
HDMI 1.3 and HDMI 1.4
SATA and eSATA
DVI
IEEE 1394
PCI Express
Portable Electronics
Notebooks
Will Semiconductor Ltd.
Package
Shipping
ESD5311N-2/TR DFN1006-2L 10000/Tape&Reel
1
Revision 1.3, 2015/10/28
ESD5311N
Absolute maximum ratings
Parameter
Symbol
Rating
Unit
Peak pulse power (tp = 8/20μs)
Ppk
84
W
Peak pulse current (tp = 8/20μs)
IPP
4
A
ESD according to IEC61000-4-2 air discharge
±20
VESD
ESD according to IEC61000-4-2 contact discharge
Operation junction temperature
TJ
Lead temperature
TL
Storage temperature
kV
±20
TSTG
125
o
260
o
-55~150
o
C
C
C
Electrical characteristics (TA=25 oC, unless otherwise noted)
Parameter
Symbol
Reverse maximum working voltage
VRWM
Reverse leakage current
IR
Reverse breakdown voltage
Clamping voltage
1)
Dynamic resistance
1)
IT = 1mA
VCL
IPP = 16A, tp = 100ns
RDYN
2)
VCL
Clamping voltage
3)
VCL
CJ
Min.
VRWM = 5V
VBR
Clamping voltage
Junction capacitance
Condition
VESD = 8kV
7.5
Typ.
Max.
Unit
5.0
V
很抱歉,暂时无法提供与“ESD5311N-2/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.13811
- 1000+0.09148
- 4000+0.08148
- 10000+0.07286
- 国内价格
- 1+0.49610
- 500+0.16500
- 5000+0.11000
- 10000+0.09020
- 国内价格
- 20+0.15066
- 200+0.11794
- 600+0.09980
- 2000+0.08889
- 10000+0.07949
