WR02X4700FAL
WR02X4700FAL
    WALSIN(华新科)
    贴片电阻 0201 470Ω ±1% 1/20W ±200ppm/℃
WR02X4700FAL 数据手册
Approval sheet WR02X(W) ±5%, ±1% Thick Film General purpose chip resistors Size 0201 *Contents in this sheet are subject to change without prior notice. Page 1 of 7 ASC_WR02X_V18 MAY - 2016 Approval sheet FEATURE 1. Small size and light weight 2. High reliability and stability 3. Reduced size of final equipment 4. Suitable for high density print circuit board assembly 5. Higher component and equipment reliability 6. Lead free product APPLICATION • Mobile phone • PDA • Camcorders • Palmtop computers • Hybrid module DESCRIPTION The resistors are constructed in a high grade ceramic body (aluminum oxide). Internal metal electrodes are added at each end and connected by a resistive paste that is applied to the top surface of the substrate. The composition of the paste is adjusted to give the approximate resistance required and the value is trimmed to nominated value within tolerance which controlled by laser trimming of this resistive layer. The resistive layer is covered with a protective coat. Finally, the two external end terminations are added. For ease of soldering the outer layer of these end terminations is a pure Tin. Fig 1. Construction of Chip-R WR02X Page 2 of 7 ASC_WR02X_V18 MAY - 2016 Approval sheet QUICK REFERENCE DATA Item General Specification Series No. WR02X(W) Size code 0201(0603) 1Ω~10MΩ ( ±5% tolerance ), Jumper Resistance Range 1Ω~ 10MΩ ( ±1% tolerance ) Resistance Tolerance ±1% ±5% E96/E24 E24 10Ω - 10MΩ, ≤±200 TCR (ppm/°C) 1 - 9.76Ω, +600~-200 Max. dissipation @ Tamb=70°C 1/20 W Max. Operation Voltage (DC or RMS) 25V Max. Overload Voltage (DC or RMS) 50V Operation temperature -55 ~ +125’C Note : 1. This is the maximum voltage that may be continuously supplied to the resistor element, see “IEC publication 60115-8” 2. Max. Operation Voltage : So called RCWV (Rated Continuous Working Voltage) is determined by RCWV = Rated Power × Resistance Value or Max. RCWV listed above, whichever is lower. DIMENSION(unit : mm) Protective c oat WR02X(W) L 0.60 ± 0.03 W 0.30 ± 0.03 T 0.23 ± 0.03 Tb 0.15 ± 0.05 Tt 0.10 ± 0.05 T End term ination Tb Resistive layer Tt Ceramic Substrate W T L MARKING WR02X(W) has no marking. Page 3 of 7 ASC_WR02X_V18 MAY - 2016 Approval sheet FUNCTIONAL DESCRIPTION Product characterization Standard values of nominal resistance are taken from the E24/E96 series for resistors with a tolerance of ±5% & ±1%. The values of the E24/E96 series are in accordance with “IEC publication 60063” Derating The power that the resistor can dissipate depends on the operating temperature; see Fig.2 Figure 2. Maximum dissipation in percentage of rated power As a function of the ambient temperature MOUNTING Due to their rectangular shapes and small tolerances, Surface Mountable Resistors are suitable for handling by automatic placement systems. Chip placement can be on ceramic substrates and printed-circuit boards (PCBs). Electrical connection to the circuit is by individual soldering condition. The end terminations guarantee a reliable contact. SOLDERING CONDITION The robust construction of chip resistors allows them to be completely immersed in a solder bath of 260°C for 10 seconds. Therefore, it is possible to mount Surface Mount Resistors on one side of a PCB and other discrete components on the reverse (mixed PCBs). Surface Mount Resistors are tested for solderability at 235°C during 2 seconds. The test condition for no leaching is 260°C for 30 seconds. Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 3. Fig 3. Infrared soldering profile for Chip Resistors WR02X(W) Page 4 of 7 ASC_WR02X_V18 MAY - 2016 Approval sheet CATALOGUE NUMBERS The resistors have a catalogue number starting with : WR02 X 472_ J A L Size code Type code Resistance code Tolerance Packaging code Termination code WR02 X : Normal 5%, E24: 2 significant digits followed by no. of zeros and a blank J : ±5% A : 7” Reeled taping (15Kpcs/Reel) L = Sn base (lead free) : 0201 W : 1% For 1MΩ 4.7Ω = 4R7_ 100Ω = 101_ 10KΩ F : ±1% P : Jumper T : 7” Reeled taping (10Kpcs/Reel) D : 7” Reeled taping (20Kpcs/Reel) = 103_ H : 13” Reeled taping 1%, E24+E96: 3 significant digits followed by no. of zeros 100Ω =1000 37.4KΩ =3742 (50Kpcs/Reel) G : 13” Reeled taping (70Kpcs/Reel) TEST CONDITION FOR JUMPER (0 Ω) Item Power Rating At 70°C Resistance Rated Current Peak Current within 5 sec Operating Temperature Page 5 of 7 WR02 1/20W MAX.50mΩ 1A 2.5A -55 ~ +125°C ASC_WR02X_V18 MAY - 2016 Approval sheet TEST AND REQUIREMENTS (JIS C 5201-1 : 1998) TEST Electrical Characteristics JISC5201-1: 1998 Clause 4.8 REQUIREMENT PROCEDURE / TEST METHOD 0Ω Ω Resistor - DC resistance values measurement Within the specified tolerance - Temperature Coefficient of Resistance (T.C.R) Refer to “QUICK Natural resistance centigrade. R2 − R1 × 106 R1 (t2 − t1 ) change (ppm/°C) per change in degree REFERENCE DATA”
WR02X4700FAL
- 物料型号:WR02X(W) 0201(0603) - 器件简介:该电阻器采用小型化设计,重量轻,可靠性高,稳定性好,适用于高密度印刷电路板组装。 - 引脚分配:文档中未明确提供引脚分配信息,但通常这类电阻器为表面贴装型,两端为引脚。 - 参数特性: - 电阻范围:1 ~ 10M,有±5%和±1%的容差选项。 - 温度系数(TCR):10ppm/°C至10M,+200ppm/°C。 - 最大功耗:在环境温度70°C时为1/20W。 - 最大工作电压:25V直流或RMS。 - 操作温度范围:-55°C至+125°C。 - 功能详解:电阻器由高等级陶瓷体(氧化铝)构成,两端添加内部金属电极,并通过涂覆在基板顶面上的电阻浆料连接。电阻层覆盖有保护层,外部端部终端添加了易于焊接的纯锡层。 - 应用信息:适用于手机、PDA、摄像机、掌上电脑、混合模块等。 - 封装信息:尺寸为0.60mm x 0.30mm x 0.23mm,标记为WR02X(W),无其他标记。
WR02X4700FAL 价格&库存
很抱歉,暂时无法提供与“WR02X4700FAL”相匹配的价格&库存,您可以联系我们找货
WR02X4700FAL
    • 15000+0.00260
    库存:30000
    WR02X4700FAL
    • 15000+0.0260915000+0.00327
    • 30000+0.0233330000+0.00292
    • 45000+0.0219945000+0.00276
    • 75000+0.0205475000+0.00257
    • 105000+0.01971105000+0.00247
    • 150000+0.01893150000+0.00237
    • 180000+0.01856180000+0.00233
    • 360000+0.01735360000+0.00218
    • 375000+0.01730375000+0.00217
    库存:21912
    WR02X4700FAL
      • 1+0.01221
      • 100+0.00715
      • 1000+0.00459
      • 7500+0.00323
      • 15000+0.00260
      库存:12000
      WR02X4700FAL
      • 100+0.00598
      • 3000+0.00377
      • 6000+0.00373
      库存:4050
      WR02X4700FAL
      • 1+0.901701+0.11284
      • 10+0.1890410+0.02366
      • 25+0.1329825+0.01664
      • 50+0.1077750+0.01349
      • 100+0.08626100+0.01080
      • 250+0.06614250+0.00828
      • 500+0.05480500+0.00686
      • 1000+0.045911000+0.00575
      • 5000+0.032025000+0.00401
      库存:21912
      WR02X4700FAL
        • 15000+0.00264
        库存:15000
