WEC3R0335QG
WEC3R0335QG
    VINATECH
    CAP_D8X20MM_TM
    超级电容器 CAP_D8X20MM_TM 3.3F -10~+30% 3V
WEC3R0335QG 数据手册
3.0V 3.3F (0820) FEATURES EDLC (Electric Double Layer Capacitor) - High Power Density (Low ESR) - Over 500,000 cycle life (semi-permanent) - Higher energy density compared with 2.7V caps - RoHS compliant - Long-term reliability improved at high temperature and humidity(65℃ 90%RH) Drawing D (Φ) 8.0 +1.0 Max L (㎜) 20.0 ±1.5 d (Φ) 0.6 ±0.1 P (㎜) 3.5 ±0.5 SPECIFICATION ITEM CHARACTERISTICS Product series EDLC Rated Voltage (VR) 3.0V Operating Temperature -40 ~ +65℃ Capacitance Tolerance -10 ~ +30% After 1,000 hours at VR loaded under +65℃, capacitors meet the following criteria. High Temperature Load Life Cycle Life Characteristics Capacitance Change ≤ 30% of initial value ESR ≤ 2 times of specified value Cycle Over 500,000 △C ≤ 30% of initial value ESR ≤ 2 times of specified value Method Cycle of Charge/discharge from VR to 1/2VR 2 Years No Electrical Charge, Temperature below 70℃ (△C : ≤ 10% of initial value / △ESR : ≤ 50% of specified value) Shelf Life Part Number WEC 3R0 335 QG ESR (mΩ) Rated Voltage (V) Capacitance (F) AC(1㎑) 3.0 3.3 85 Leakage Current (㎃, 72hr) Size (mm) DC Max. Current (A) 145 3.0 0.010 08 x 20 DxL * Max. Current : 1 sec. discharge to 1/2VR Vina Tech Co., Ltd. Tel : +82 63 715 3020 E-mail : hycap@vina.co.kr Web : www.vina.co.kr
WEC3R0335QG 价格&库存
很抱歉,暂时无法提供与“WEC3R0335QG”相匹配的价格&库存,您可以联系我们找货
WEC3R0335QG
  • 10+2.60000
  • 100+2.46000
  • 1000+2.36000
库存:310
