PXXXXSX SERIES
Thyristor Surge Suppressors (TSS) Data Sheet
Description
DO-214AA Thyristor solid state protection thyristor protect
telecommunications equipment such as modems, line cards,
fax machines, and other CPE.
P Series devices are used to enable equipment to meet
various regulatory requirements including GR 1089, ITU
K.20, K.21 and K.45, IEC 60950, UL 60950, and TIA-968
(formerly known as FCC Part 68).
Features
Compared to surge suppression using other technologies, P Series devices offer absolute surge protection
regardless of the surge current available and the rate of applied voltage (dv/dt). P Series devices:
■ Cannot be damaged by voltage
■ Eliminate hysteresis and heat dissipation typically found with clamping devices
■ Eliminate voltage overshoot caused by fast-rising transients
■ Are non-degenerative
■ Will not fatigue
■ Have low capacitance, making them ideal for high-speed transmission equipment
■ Meets MSL level 1, per J-STD-020
■ Safety certification: UL: E244458
Electrical Parameters
Parameter
Definition
VDRM
Peak Off-state Voltage – maximum voltage that can be applied while maintaining off state
VS
Switching Voltage – maximum voltage prior to switching to on state
VT
On-state Voltage – maximum voltage measured at rated on-state current
IDRM
Leakage Current – maximum peak off-state current measured at VDRM
IS
Switching Current – maximum current required to switch to on state
IT
On-state Current – maximum rated continuous on-state current
IH
Holding Current – minimum current required to maintain on state
CO
Off-state Capacitance – typical capacitance measured in off state
VPP
Peak Pulse Voltage – maximum rated peak impulse voltage
IPP
Peak Pulse Current – maximum rated peak impulse current
Revision:16-Sep-14
www.brightking.com
PXXXXSX SERIES
Electrical Characteristics
Part
Number
VDRM
(V)
VS
(V)
VT
(V)
IDRM
(μA)
IS
(mA)
IT
(A)
IH
(mA)
CO
(pF)
VPP
10/700μs
(V)
IPP
10/1000μs
(A)
Marking
P0080SA
6
25
4
5
800
2.2
50
50
2000
45
P008A
P0080SB
6
25
4
5
800
2.2
50
70
4000
80
P008B
P0080SC
6
25
4
5
800
2.2
50
100
6000
100
P008C
P0300SA
25
40
4
5
800
2.2
50
70
2000
45
P03A
P0300SB
25
40
4
5
800
2.2
50
70
4000
80
P03B
P0300SC
25
40
4
5
800
2.2
50
100
6000
100
P03C
P0640SA
58
77
4
5
800
2.2
150
50
2000
45
P06A
P0640SB
58
77
4
5
800
2.2
150
60
4000
80
P06B
P0640SC
58
77
4
5
800
2.2
150
100
6000
100
P06C
P0720SA
65
88
4
5
800
2.2
150
50
2000
45
P07A
P0720SB
65
88
4
5
800
2.2
150
60
4000
80
P07B
P0720SC
65
88
4
5
800
2.2
150
100
6000
100
P07C
P0900SA
75
98
4
5
800
2.2
150
45
2000
45
P09A
P0900SB
75
98
4
5
800
2.2
150
55
4000
80
P09B
P0900SC
75
98
4
5
800
2.2
150
90
6000
100
P09C
P1100SA
90
130
4
5
800
2.2
150
45
2000
45
P11A
P1100SB
90
130
4
5
800
2.2
150
55
4000
80
P11B
P1100SC
90
130
4
5
800
2.2
150
90
6000
100
P11C
P1300SA
120
160
4
5
800
2.2
150
45
2000
45
P13A
P1300SB
120
160
4
5
800
2.2
150
55
4000
80
P13B
P1300SC
120
160
4
5
800
2.2
150
90
6000
100
P13C
P1500SA
140
180
4
5
800
2.2
150
40
2000
45
P15A
P1500SB
140
180
4
5
800
2.2
150
60
4000
80
P15B
P1500SC
140
180
4
5
800
2.2
150
85
6000
100
P15C
P1800SA
170
220
4
5
800
2.2
150
40
2000
45
P18A
P1800SB
170
220
4
5
800
2.2
150
60
4000
80
P18B
P1800SC
170
220
4
5
800
2.2
150
85
6000
100
P18C
P2300SA
190
260
4
5
800
2.2
150
35
2000
45
P23A
P2300SB
190
260
4
5
800
2.2
150
55
4000
80
P23B
P2300SC
190
260
4
5
800
2.2
150
80
6000
100
P23C
Revision:16-Sep-14
www.brightking.com
PXXXXSX SERIES
Part
Number
VDRM
(V)
VS
(V)
VT
(V)
IDRM
(μA)
IS
(mA)
IT
(A)
IH
(mA)
CO
(pF)
VPP
10/700μs
(V)
IPP
10/1000μs
(A)
Marking
P2600SA
220
300
4
5
800
2.2
150
35
2000
45
P26A
P2600SB
220
300
4
5
800
2.2
150
50
4000
80
P26B
P2600SC
220
300
4
5
800
2.2
150
80
6000
100
P26C
P3100SA
275
350
4
5
800
2.2
150
30
2000
45
P31A
P3100SB
275
350
4
5
800
2.2
150
45
4000
80
P31B
P3100SC
275
350
4
5
800
2.2
150
65
6000
100
P31C
P3500SA
320
400
4
5
800
2.2
150
30
2000
45
P35A
P3500SB
320
400
4
5
800
2.2
150
40
4000
80
P35B
P3500SC
320
400
4
5
800
2.2
150
65
6000
100
P35C
Notes:
·All measurements are made at an ambient temperature of 25℃. IPP applies to -40℃ through +85℃ temperature range.
·Off-state capacitance(CO) is measured at 1 MHz with a 2V bias and is typical value.
Thermal Considerations
Package DO-214AA/SMB
Symbol
Parameter
Value
Unit
TJ
Operating Junction Temperature
-40 to +150
TS
Storage Temperature Range
-40 to +150
RθJA
Junction to Ambient on printed circuit
90
℃/W
Part Number Code and Marking
Revision:16-Sep-14
www.brightking.com
PXXXXSX SERIES
Characteristics Curves
Figure 1. V-I Characteristics
Figure 2. tr × td Pulse Wave-form
Figure 3. Normalized Vs Change versus Junction
Temperature
Figure 4. Normalized DC Holding Current versus
Case Temperature
Revision:16-Sep-14
www.brightking.com
PXXXXSX SERIES
Recommended Soldering Conditions
Reflow Soldering
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) ( tS)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
Time 25℃ to Peak Temperature
Revision:16-Sep-14
20-40 seconds
6℃/second max.
8 minutes max.
www.brightking.com
PXXXXSX SERIES
Dimensions (SMB/DO-214AA)
Symbol
Millimeters
Inches
Min.
Max.
Min.
Max.
L
4.06
4.70
0.160
0.185
D
3.30
3.94
0.130
0.155
D1
1.90
2.20
0.075
0.086
T
5.21
5.59
0.205
0.220
T1
0.76
1.52
0.030
0.060
d
0.203
0.008
H
1.95
2.65
0.077
0.104
Packaging
Tape
Reel
Symbol
Dimension (mm)
W
12.00±0.30
P0
4.00±0.10
P1
8.00±0.10
P2
2.00±0.10
D0
Φ1.55±0.05
D1
Φ1.55±0.05
E
1.75±0.10
F
5.50±0.10
A0
3.76±0.10
B0
5.69±0.10
K0
2.70±0.10
T
0.25±0.10
D2
Φ330.0±2.0
D3
Φ13.5±0.5
H
2.5±0.5
W1
16.0±1.0
Quantity: 2500PCS
P0080SB: 3000PCS
Revision:16-Sep-14
www.brightking.com
很抱歉,暂时无法提供与“P0080SB-3K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.52089
- 50+0.41462
- 150+0.36148
- 500+0.32163
- 国内价格
- 1+0.33330
- 3000+0.29480
