14Φ SERIES
Metal Oxide Varistor (MOV) Data Sheet
Features
Wide operating voltage (V1mA) range from 18V to 1800V
Fast responding to transient over-voltage
Large absorbing transient energy capability
Low clamping ratio and no follow-on current
Meets MSL level 1, per J-STD-020
Operating Temperature:-40℃ ~ +85℃
Storage Temperature:-40℃ ~ +125℃
Safety certification: UL: E327997
CSA: 246579
VDE: 40027827
Applications
Transistor, diode, IC, thyristor or triac semiconductor protection
Surge protection in consumer electronics
Surge protection in industrial electronics
Surge protection in electronic home appliances, gas and petroleum appliances
Relay and electromagnetic valve surge absorption
Part Number Code
Revision:27-Dec-15
1 / 11
www.brightking.com
14Φ SERIES
Dimensions
Table 1
Table 2
Unit: mm
Unit: mm
Symbol
Dimension
Model
T
e
Model
T
e
H(±2.0)
17.5
180K
2.8
1.5
361K
4.1
2.7
H1(±2.0)
19.0
220K
2.9
1.6
391K
4.2
2.8
L(min.)
20.0
270K
3.1
1.8
431K
4.4
3.0
L1(min.)
15.0
330K
3.0
1.7
471K
4.6
3.2
D
14.0~16.5
390K
3.1
1.8
511K
4.8
3.4
F(±0.8)
7.5
470K
3.3
1.9
561K
5.0
3.6
T(±0.8)
Table 2
560K
3.5
2.1
621K
5.3
3.9
e(±0.8)
Table 2
680K
3.8
2.4
681K
5.6
4.2
d(±0.05)
0.8
820K
3.2
1.8
751K
5.7
4.3
d1(±0.4)
1.4
101K
3.4
2.0
781K
5.8
4.4
121K
3.6
2.2
821K
6.0
4.6
151K
3.2
1.8
911K
6.3
5.0
181K
3.3
1.9
102K
6.3
5.0
201K
3.4
2.0
112K
6.8
5.4
221K
3.5
2.1
122K
7.2
5.8
241K
3.6
2.2
142K
8.0
6.6
271K
3.8
2.4
162K
8.8
7.4
301K
3.9
2.5
182K
9.6
8.2
331K
3.9
2.5
Revision:27-Dec-15
2 / 11
www.brightking.com
14Φ SERIES
Electrical Characteristics
Maximum
Part
Allowable
Number
Standard
High
Surge
Voltage
VAC(V)
VDC(V)
Varistor
Voltage
V1mA(V)
Maximum
Withstanding
Maximum
Clamping
Surge
Energy
Voltage
Current
(10/1000μs)
IP(A)
VC(V)
I (A)
Standard
I (A)
High
Surge
(J)
Standard
Rated
Power
Typical
Capacitance
(Reference)
(J)
High
(W)
@1KHz (pf)
Surge
180KD14
180KD14J
11
14
18(15~21.6)
10
36
1000
2000
4.0
7.0
0.1
11100
220KD14
220KD14J
14
18
22(19.5~26)
10
43
1000
2000
5.0
8.0
0.1
9100
270KD14
270KD14J
17
22
27(24~31)
10
53
1000
2000
6.0
10.0
0.1
7400
330KD14
330KD14J
33(29.5~36.5)
10
65
1000
2000
7.5
12.0
0.1
6100
390KD14
390KD14J
25
31
39(35~43)
10
77
1000
2000
8.6
13.0
0.1
5100
470KD14
470KD14J
30
38
47(42~52)
10
93
1000
2000
10.0
17.0
0.1
4300
560KD14
560KD14J
35
45
56(50~62)
10
110
1000
2000
11.0
20.0
0.1
3600
680KD14
680KD14J
40
56
68(61~75)
10
135
1000
2000
14.0
24.0
0.1
2900
820KD14
820KD14J
50
65
82(74~90)
50
135
4500
6000
22.0
27.0
0.6
2400
101KD14
101KD14J
60
85
100(90~110)
50
165
4500
6000
28.0
33.0
0.6
2000
121KD14
121KD14J
75
100
120(108~132)
50
200
4500
6000
32.0
40.0
0.6
1700
151KD14
151KD14J
95
125
150(135~165)
50
250
4500
6000
40.0
53.0
0.6
1300
181KD14
181KD14J
115
150
180(162~198)
50
300
4500
6000
50.0
60.0
0.6
1100
201KD14
201KD14J
130
170
200(180~220)
50
340
4500
6000
57.0
70.0
0.6
1000
221KD14
221KD14J
140
180
220(198~242)
50
360
4500
6000
60.0
78.0
0.6
900
241KD14
241KD14J
150
200
240(216~264)
50
395
4500
6000
63.0
84.0
0.6
830
271KD14
271KD14J
175
225
270(243~297)
50
455
4500
6000
70.0
99.0
0.6
740
301KD14
301KD14J
190
250
300(270~330)
50
500
4500
6000
77.0
108
0.6
670
331KD14
331KD14J
210
275
330(297~363)
50
550
4500
6000
85.0
115
0.6
610
361KD14
361KD14J
230
300
360(324~396)
50
595
4500
6000
93.0
130
0.6
560
391KD14
391KD14J
250
320
390(351~429)
50
650
4500
6000
100
140
0.6
510
431KD14
431KD14J
275
350
430(387~473)
50
710
4500
6000
115
155
0.6
460
471KD14
471KD14J
300
385
470(423~517)
50
775
4500
6000
125
175
0.6
430
511KD14
511KD14J
320
415
510(459~561)
50
845
4500
6000
125
180
0.6
390
561KD14
561KD14J
350
460
560(504~616)
50
925
4500
6000
125
185
0.6
360
621KD14
621KD14J
385
505
620(558~682)
50
1025
4500
6000
125
190
0.6
320
681KD14
681KD14J
420
560
680(612~748)
50
1120
4500
6000
130
200
0.6
290
751KD14
751KD14J
460
615
750(675~825)
50
1240
4500
6000
143
210
0.6
270
781KD14
781KD14J
485
640
780(702~858)
50
1290
4500
6000
148
220
0.6
260
821KD14
821KD14J
510
670
820(738~902)
50
1355
4500
6000
157
235
0.6
240
911KD14
911KD14J
550
745
910(819~1001)
50
1500
4500
6000
175
255
0.6
220
102KD14
102KD14J
625
825
1000(900~1100)
50
1650
4500
6000
190
280
0.6
200
112KD14
112KD14J
680
895
1100(990~1210)
50
1815
4500
6000
213
310
0.6
180
122KD14
122KD14J
750
990
1200(1080~1320)
50
1980
4500
6000
232
324
0.6
160
142KD14
142KD14J
880
1140
1400(1260~1540)
50
2310
4500
6000
238
327
0.6
150
162KD14
162KD14J
1000
1280
1600(1440~1760)
50
2640
4500
6000
243
331
0.6
140
182KD14
182KD14J
1100
1465
1800(1620~1980)
50
2970
4500
5000
250
335
0.6
130
Notes: 1. The tolerance of varistor voltage between 18V and 27V is more than 10%.
2. Varistor voltage≥1200V, structure diagram is F type.
3. Leakage Current (@83% of V1mA):IR≤50μA (180K~680K) ; IR≤25μA (820K~182K)
Revision:27-Dec-15
3 / 11
www.brightking.com
14Φ SERIES
Electrical Ratings
Items
Varistor Voltage
Maximum Allowable
Voltage
Test Condition/Description
Requirement
The voltage between two terminals with the specified measuring
current 1mA.DC applied is called Vb.
The recommended maximum sine wave voltage (RMS) or the
Maximum DC voltage can be applied continuously.
The maximum voltage between two terminals with the specification
standard impulse current.
Applied waveform: 8/20μs
Maximum Clamping
Voltage
To meet the
Specified value
Rated Wattage
The maximum average power that can be applied within the
specified ambient temperature.
Energy
The maximum energy within the varistor voltage change of ±10%
when one impulse of 10/1000μs or 2ms is applied.
Withstanding Surge
Current
The maximum current within the varistor voltage change of ±10%
with the standard impulse current (8/20μs) applied one time.
Varistor Voltage
Temp. Coefficient
Vb at 20℃ − Vb at 70℃ 1
× 100(%/℃)
50
Vb at 20℃
0.05%/℃ max
The change of Vb shall be measured after the impulse listed below
which is applied 10,000 times continuously with the interval of ten
seconds at room temperature.
Surge Life
14Φ series
Revision:27-Dec-15
180K to 680K
75A (8/20μs)
820K to 182K
150A (8/20μs)
4 / 11
∆Vb
≤ ±10%
Vb
www.brightking.com
14Φ SERIES
Soldering Recommendation
Wave Lead Free Soldering Recommendation
300
Preheating
Maximum Wave 265℃
Soldering
Cooling
250
200
150
100
50
1
1.5
2
2.5
3
3.5
4
Time (minutes)
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds (max.)
Soldering
1 time
Recommendation Reworking Conditions with Soldering Iron
Revision:27-Dec-15
Item
Conditions
Temperature of Soldering Iron-tip
360℃ (max.)
Soldering Time
3 seconds (max.)
Distance from Varistor
2mm (min.)
5 / 11
www.brightking.com
14Φ SERIES
Maximum Surge Current Derating Curve
820KD14 to 751KD14
180KD14 to 680KD14
10000
10000
1
2
1000
100
1
2
10
1023
104
10
105
106
1000
10
100
102
103
104
105
106
10
10
1
1
0.1
10
100
1000
0.1
10
10000
Td (μs)
Revision:27-Dec-15
100
1000
10000
Td (μs)
6 / 11
www.brightking.com
14Φ SERIES
Maximum Leakage Current and Maximum Clamping Voltage Curve
180KD14 to 680KD14
1000
680KD14
560KD14
470KD14
390KD14
330KD14
270KD14
220KD14
180KD14
Voltage (V)
100
10
1
10-6
-5
10
-4
-3
10
-2
10
-1
10
10
1
2
10
3
10
4
10
10
Current (A)
820KD14 to 471KD14
10000
471KD14
431KD14
391KD14
361KD14
331KD14
301KD14
271KD14
241KD14
221KD14
201KD14
181KD14
151KD14
121KD14
101KD14
820KD14
Voltage (V)
1000
100
10
10-6
-5
10
-4
10
-3
10
-2
10
-1
10
1
10
2
10
3
10
4
10
5
10
Current (A)
Revision:27-Dec-15
7 / 11
www.brightking.com
14Φ SERIES
511KD14 to 182KD14
10000
182KD14
162KD14
142KD14
122KD14
112KD14
102KD14
911KD14
821KD14
781KD14
751KD14
681KD14
621KD14
561KD14
511KD14
Voltage (V)
1000
100
10-6
-5
10
-4
-3
10
-2
10
-1
10
10
1
2
10
10
3
10
4
10
5
10
Current (A)
180KD14J to 680KD14J
1000
680KD14J
560KD14J
470KD14J
390KD14J
330KD14J
270KD14J
220KD14J
180KD14J
Voltage (V)
100
10
1
10-6
-5
10
-4
10
-3
10
-2
10
-1
10
1
10
2
10
3
10
4
10
Current (A)
Revision:27-Dec-15
8 / 11
www.brightking.com
14Φ SERIES
820KD14J to 751KD14J
10000
751KD14J
681KD14J
621KD14J
561KD14J
511KD14J
471KD14J
431KD14J
391KD14J
361KD14J
331KD14J
301KD14J
271KD14J
241KD14J
221KD14J
201KD14J
181KD14J
151KD14J
121KD14J
101KD14J
820KD14J
Voltage (V)
1000
100
10
10-6
10-5
10-4
10-3
10-2
10-1
1
10
102
103
104
105
Current (A)
781KD14J to 182KD14J
10000
182KD14J
162KD14J
142KD14J
122KD14J
112KD14J
102KD14J
911KD14J
821KD14J
781KD14J
Voltage (V)
1000
100
10-6
-5
10
-4
10
-3
10
-2
10
-1
10
1
10
2
10
3
10
4
10
5
10
Current (A)
Revision:27-Dec-15
9 / 11
www.brightking.com
14Φ SERIES
Marking Code
① Brightking Logo
② Varistor Voltage
③ UL Accreditation Logo
①
XXXKDXXX
②
③
④
⑤
XXX H
Y
VDE
X
④ CSA Accreditation Logo
⑥
⑦
⑤ VDE Accreditation Logo
⑥“J”is High Surge Code, no“J”is Standard Surge
⑧
⑨
⑦ Disk Size
⑧“H”is Halogen Free Code, no“H”is Halogen
⑩
⑨ Date Code
⑩ Product Line Code (“Y”may be A thru Z or blank)
W0
W
Taping Dimensions
Revision:27-Dec-15
10 / 11
Symbol
Dimensions (mm)
P
25.4±1.0
P0
12.7±1.0
P1
8.95±0.7
P2
12.7±1.3
F
7.5±0.8
h
0±4
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H
20.0±2.0
I
1.0max
D0
4.0±0.2
t
0.6±0.3
B
40max
www.brightking.com
14Φ SERIES
Quantity
Packaging Dimensions (Unit: mm)
Quantity
Bulk
400pcs/bag
2bags/box
(180K~331K)
300pcs/bag
2bags/box
(361K~621K)
250pcs/bag
2bags/box
(681K~112K)
150pcs/bag
2bags/box
(122K~182K)
Tape & Box
750pcs/box
(180K~331K)
500pcs/box
(361K~621K)
400pcs/box
(681K~751K)
Tape & Reel
1000pcs/reel
(180K~331K)
750pcs/reel
(361K~621K)
500pcs/reel
(681K~751K)
Revision:27-Dec-15
11 / 11
www.brightking.com
很抱歉,暂时无法提供与“471KD14”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+1.34950
- 50+0.80500
- 150+0.56350
- 300+0.40250
- 600+0.38240
- 3000+0.35420
- 国内价格
- 5+0.75017
- 50+0.61074
- 300+0.51192
- 600+0.45965
- 2400+0.41786
- 5100+0.39690
- 国内价格
- 5+0.73710
- 50+0.60010
- 300+0.50210
- 600+0.45060
- 2400+0.40960
- 5100+0.38910
