BK1 SERIES
Spark Gap (SPG) Data Sheet
Features
Approximately zero leaking current before clamping voltage
Less decay at on/off state.
High capability to withstand repeated lightning strikes.
Low electrode capacitance(≤0.8pF) and high isolation(≥100MΩ).
RoHS compliant.
Bilateral symmetrical.
Temperature, humidity and lightness insensitive.
Operating temperature: -40℃ ~ +85℃
Storage temperature: -40℃ ~ +125℃
Meets MSL level 1, per J-STD-020
Safety certification: UL: E244458
Applications
Power Supplies
Motor sparks eliminating
Relay switching spark absorbing
Data line pulse guarding
Electronic devices requiring UL497A and UL497B compliant
Telephone/Fax/Modem
High frequency signal transmitters/receivers
Satellite antenna
Radio amplifiers
Alarm systems
Cathode ray tubes in Monitors/TVs
Dimensions
Color code 1
Color code 2
Color code 3
L1
D
L
Revision:SPG-BK1 SERIES-001(A2)
d
Symbol
Dimension (mm)
L
4.0±0.5
L1
28.0±3.0
D
Φ3.1±0.5
d
Φ0.5±0.05
L1
1/5
http://brightking.pulseelectronics.com
BK1 SERIES
Electrical Characteristics
DC
Spark-over
Voltage
Minimum
Insulation
Resistance
Maximum
Capacitance
(1KHz-6VMAX)
Surge Life
Test
Vs(V)
Test
Voltage(V)
IROHM(MΩ)
C(pf)
Surge
Current
Capacity
(8/20μs)
BK1XX00702
140
50
100
0.8
3000A
250 times
BK1XX01002
200
100
100
0.8
3000A
250 times
BK1XX01502
300
100
100
0.8
3000A
250 times
BK1XX02002
400
250
100
0.8
3000A
250 times
BK1XX02502
500
250
100
0.8
3000A
250 times
BK1XX03002
600
250
100
0.8
3000A
250 times
BK1XX03502
700
250
100
0.8
3000A
250 times
Part Number
①
8/20μs,100A
Note:① Vs±XX%
Color Code
Part Number
Color Code 1
Color Code 2
Color Code 3
BK1XX00702
Black
Yellow
BK1XX01002
Red
BK1XX01502
Orange
BK1XX02002
Yellow
BK1XX02502
Green
BK1XX03002
Blue
BK1XX03502
Purple
2/5
BK1 SERIES
Test Methods and Results
Items
Test Method
Standard
DC Spark-over
Voltage
Measure starting discharge voltage (Vs) by
gradually increasing applied DC voltage. Test
current is 0.5mA max. And the DC voltage
ascends up within 100V/second.
Insulation
Resistance
Measure the insulation resistance across the
terminal at regular voltage. But the test voltage
doesn’t over the DC spark-over voltage.
Capacitance
Measure the electrostatic capacitance by
applying a voltage of less than 6V (at 1KHz)
between terminals.
Static Life
10KV with 1500pf condenser is discharged
through 0Ω resistor. 200 times at an interval of
10sec.
∣△ Vs/Vs∣≤30%
Characteristics of other items must
meet the specified value.
Surge Current
Capacity
1.2/50μs & 8/20μs, 3000A, electrically
connected with a resistor (1~2 Ω), ±5 times,
each time interval 60 seconds. Thereafter,
outer appearance shall be visually examined.
No crack and no failures
Cold Resistance
Measurement after -40℃/1000 HRS & normal
temperature/2 HRS.
Heat Resistance
Measurement after 125℃/1000 HRS & normal
temperature/2 HRS.
Humidity Resistance
Measurement after humidity 90~95℃(45℃)
/1000 HRS & normal temperature/2 HRS.
Temperature Cycle
10 times repetition of cycle -40℃/30min
→normal, temp/2 min →125℃/30min,
measurement after normal temp/2 HRS.
Solder Ability
Apply flux and immerse in molten solder
230±5℃ for 3sec up to the point of 1.5mm from
body. Check for solder adhesion.
Lead wire is evenly covered by solder.
Solder Heat
Measurement after lead wire is dipped up to
the point of 1.5mm from body into 260±5℃
solder for 10sec.
Conformed to rated spec.
Pull Strength
Apply 0.5kg load for 10sec.
Flexural Strength
Bend lead wire at the point of 2mm from body
under 0.25 load and back to its original point.
Repeat 1 time.
3/5
Meet specified value.
Features are conformed to rated
spec.
Lead shall not pull out to snap.
BK1 SERIES
Recommended Soldering Conditions
Flow Soldering Conditions
Air Priheat
Soldering
Reflow Soldering Conditions
Air Priheat
Cooling
Soldering
Cooling
260℃
260℃
250
250
△T
Temperature (℃)
Temperature (℃)
△T
200
150
150~180℃
200
150
150~180℃
100
100
50
50
60~120 sec
60~120 sec
3~4 sec
10 sec. or less
60 sec. or less
1) Time shown in the above figures is measured from the point when chip surface reaches temperature.
2) Temperature difference in high temperature part should be within 110℃.
3) After soldering, do not force cool, allow the parts to cool gradually.
Hand Soldering
Solder iron temperature: 350±5℃
Heating time: 3 seconds max.
General attention to soldering
● High soldering temperatures and long soldering times can cause leaching of the termination, decrease in
adherence strength, and the change of characteristic may occur.
● For soldering, please refer to the soldering curves above. However, please keep exposures to temperatures
exceeding 200℃ to fewer than 50 seconds.
● Please use a mild flux (containing less than 0.2wt% CI). Also, if the flux is water soluble, be sure to wash
thoroughly to remove any residue from the underside of components that could affect resistance.
Cleaning
When using ultrasonic cleaning, the board may resonate if the output power is too high. Since this vibration can
cause cracking or a decrease in the adherence of the termination, we recommend that you use the conditions
below.
Frequency: 40kHz max.
Output power: 20W/liter
Cleaning time: 5 minutes max.
4/5
BK1 SERIES
Packaging
Tape
L
D1
R
D
P
Z
t
L1
S
L2
T
T
S
Symbol
Dimension (mm)
W
52.0±1.5
P
5.0±0.5
L1-L2
1.0max.
T
6.0±1.0
Z
1.2max.
R
Terminals must not project from tape.
t
3.2max.
S
0.8max.
D
Φ3.6max.
D1
Φ0.5±0.05
L
4.5max.
A
74.0±5.0
B
77.0±5.0
C
252.0±5.0
W
Inner Box
B
C
A
Quantity: 1500PCS
5/5
很抱歉,暂时无法提供与“BK12001502”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.65000
- 50+0.50000
- 150+0.45000
- 1500+0.40000
- 3000+0.37500
- 国内价格
- 1+0.79200
- 50+0.52690
- 1500+0.47740
- 国内价格
- 5+0.76076
- 50+0.60005
- 150+0.51981
- 1500+0.45954
- 3000+0.41138
- 4500+0.38729
