DATA SHEET
WIRELESS COMPONENTS
Ceramic Chip Antenna
ANT5320LL45R2400A
2.4 – 2.5 GHZ
Product Specification –March 27, 2013 V.0
5320 Series
Product specification
WIRELESS COMPONENTS
FEATURES
z Compact size
z Omni-directional radiation
z Tape & reel automatic
mounting
z Reflow process compatible
z RoHS compliant
ORDERING INFORMATION
APPLICATIONS
z 2.4 GHz WiFi device
z Bluetooth gadget
z Zigbee device
z ISM band equipment
(1) PRODUCT
2
6
All part numbers are identified by the series, packing type, material, size,
antenna type, working frequency and packing quantity.
PART NUMBER
ANT 5320 L L45 R 2400A
(1)
(2)
(3) (4)
(5)
(6)
ANT = Antenna
(2) SIZE
5320 = 5.3 × 2 mm
(3) ANTENNA TYPE
L,F,A = Chip Antenna
(4) SERIAL NO.
L45
(5) PACKING TYPE
R = Tape and Reel
(6) WORKING FREQUENCY
2400 = 2.4GHz
PHYCOMP CTC
CAN4311753452451K
12NC
431175345245
www.yageo.com
Mar. 27, 2013 V0
WIRELESS COMPONENTS
3
6
SPECIFICATION
Table 1
VALUE
DESCRIPTION
Centre Frequency
2.45 GHz
Bandwidth
240 MHz (Typ.)
Return Loss
10 dB min
Polarization
Linear
Azimuth Beamwidth
Omni-directional
Peak Gain
5.22 dBi (Typ.)
Impedance
50Ω
Operating Temperature
-40~105 ℃
Maximum Power
1W
Termination
Ni / Sn (Environmentally-Friendly Leadless)
Resistance to Soldering Heats
260℃ , 10sec.
NOTE
1. The specification is defined on Yageo evaluation board
DIMENSIONS
Table 2 Machinical Dimension
DIMENSION
L (mm)
5.30 ±0.20
W (mm)
2.00 ±0.20
T (mm)
1.30 ±0.20
C (mm)
0.30 ±0.20
OUTLINES
Top View
Side View
T
L
S1
W
S2
Table 3 Termination configuration
TERMINAL NAME
FUNCTION
Bottom View
S1
Feeding Point
C
S2
Soldering Point
YNH0022
Fig. 1 Antenna outlines
www.yageo.com
Mar. 27, 2013 V0
WIRELESS COMPONENTS
4
6
REFERENCE DESIGN OF EVALUATION BOARD
18
Unit : mm
Fig. 2 Outlook and dimension of evaluation board
Top Layer
Bottom Layer / GND
Unit : mm
2.0
0.5
Matching Circuit
5.5
2.2
5.5
YNH0023
Fig. 3 Details of soldering Pad
www.yageo.com
Mar. 27, 2013 V0
WIRELESS COMPONENTS
5
6
ELECTRICAL PERFORMANCES
Return loss
(dB)
50
YNH0024
30
10
−10
1
−30
3
2
−50
2.0 2.1 2.2 2.3 2.4 2.5 2.6 2.7 2.8 2.9 3.0
f (GHz)
Marker data
1. 2.33GHz, -10dB
2. 2.42GHz, -24dB
3. 2.57GHz, -10dB
Fig. 4 Return loss
Gain (dBi)
5.00 −
0.00 −
X
Y
− 5.00 −
− 10.00 −
Z
− 15.00 −
− 20.00 −
− 25.00 −
− 30.00 −
Evaluation board and XYZ direction
− 35.00 −
YNH0025
Frequency= 2.45 GHz
Max gain = 5.22 dBi, at (180, 0)
MEG (mean effective gain)= -0.83 dBi
Directivity (dB) = 7.40
Efficiency = -1.18 dB, 76.30 %
Fig. 5 Radiation pattern
www.yageo.com
Mar. 27, 2013 V0
WIRELESS COMPONENTS
6
6
REVISION HISTORY
REVISION DATE
CHANGE NOTIFICATION
Version 0
Mar. 27, 2013
DESCRIPTION
- New datasheet for Ceramic Chip Antenna, 2.4 - 2.5 GHz application,
5320 Series
www.yageo.com
Mar. 27, 2013 V0
很抱歉,暂时无法提供与“ANT5320LL45R2400A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1000+2.88670
- 2000+2.83759
- 3000+2.78608
- 5000+2.67589
- 国内价格
- 5+0.98464
- 50+0.78484
- 150+0.68494
- 1000+0.54670
- 2000+0.48676
- 5000+0.45684
- 国内价格
- 1+0.61490
- 100+0.57190
- 300+0.52890
- 500+0.48590
- 2000+0.46440
- 5000+0.45150
