1.25mm Pitch Miniature Crimping Connector (UL Listed)
DF13 Series
Right Angle Type
Apr.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Straight Type
Type
Mounting Type
Mounting Height(h)
DIP
5.3mm
SMT
5.8mm
DIP
3.6mm
SMT
■Features
Correspond to Automatic Mounting
1. Miniature Size
Secure the automatic plain area for the absorption
type automatic mounting machine.
Designed in the low profile at mounting height 5.8mm.
(SMT mounting straight type)
(For DIP type, the mounting height is to 5.3mm to the
straight and 3.6mm at the right angle)
Straight Type
Absorption area
2. Multi-contact
The double row type achieves the multi-contact up to 40
contacts, and secures 30% higher density in the mounting
area, compared with the single row type.
3. Correspond to Automatic Mounting
The header provides the grade with the vacuum absorption
area, and secures automatic mounting by the embossed
tape packaging.
In addition, the tube packaging can be selected. (Fig.1)
Metal fitting
4. Integral Basic Function Despite Miniature Size
The header is designed in a scoop-proof box structure, and
completely prevents mis-insertion.
In addition, the surface mounting (SMT) header is equipped
with the metal fitting to prevent solder peeling. (Fig.1)
Right Angle Type
Absorption area
5. UL Certifled
■Applications
Note PC, mobile terminal, miniature type business equipment,
and other various consumer equipment, including video
camera
Fig.1
2021.2②
1
DF13 Series●1.25mm Pitch Miniature Crimping Connector (UL Listed)
■Product Specifications
Specification
1A/pin
UL
Specification 150V AC/DC
Voltage rating
UL
29.9V AC/DC
Current rating
Rating
Item
Operating Temperature Range : -35 to +85ç (Note 1) Storage Temperature Range : -10 to +60ç (Note 2)
Operating Moisture Range : 20 to 80% (Note 3)
Storage Moisture Range : 40 to 70% (Note 2)
Specification
Condition
1.Insulation Resistance
500Mø min.
100V DC
2.Withstanding voltage
No flashover or insulation breakdown.
500V AC/1 minute
3.Contact Resistance
30mø max.
100mA
4.Vibration
No electrical discontinuity of 1μs or more
Frequency : 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions.
5.Humidity (Steady state) Contact resistance : 30mø max. Insulation resistance : 500Mø min.
96 hours at temperature of 40ç and humidity of 90% to 95%
6.Temperature Cycle
(-55ç : 30 minutes➝ 5 to 35ç : 10 minutes➝ 85ç : 30 minutes➝ 5 to 35ç : 10 minutes) 5 cycles
7.Durability (Mating/un-mating) Contact resistance : 30mø max.
Tin plating : 30 cycles
Gold plating : 50 cycles
No deformation of components affecting performance.
8.Resistance to Soldering heat
Flow : 250ç for 10 seconds
Manual soldering : 300ç for 3 seconds
Reflow : At the recommended temperature profile
●UL File No. and Recognition
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. No. UL : E52653
Operating Temperature Range and Humidity range covers non conducting condition of
installed connectors in storage, shipment or during transportation.
Note 3 : Use without condensation on parts.
Note 4 : Information contained in ths catalog represents general requirements for this Series.
Contact us for the drawings and specifications for a specific part number shown.
■Materials/Finish
Product
Crimping Socket
Crimping Contact for Socket
Pin Header (Through hole)
Pin Header (SMT Single row)
Pin Header (SMT Double row)
Part
Insulator
Contact
Insulator
Contact
Insulator
Contact
Metal Fitting
Insulator
Contact
Metal Fitting
Material
Polyamide
Phosphor copper
Polyamide
Brass
Polyamide
Brass
Phosphor copper
Polyamide
Brass
Phosphor copper
Finish
Beige
Tin plated or gold plated
Beige
Tin plated
Beige
Tin plated
Beige
Tin plated
Remarks
UL94V-0
UL94V-0
UL94V-0
UL94V-0
RoHS2
Yes
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Connector
DF13
q
# - * S - 1.25 C
w
e
r
t
y
q Series Name
: DF13
e Number of Contacts
t Contact Pitch : 1.25mm
w Style Symbol
: Blank : With boss
r Single row : 2 to 12, 14, 15
y Connection Form / Contact Style.
A : Without boss
r Double row : 10, 20, 30, 40
C : Crimping socket / DSA : Straight through hole
C : Without boss
r Connector Type
DS : Right angle through hole / V : Straight SMT
t S : Single row socket / P : Single row pin header
H : Right angle SMT
t DS : Double row socket / DP : Double row pin header
●Contact
DF13 # - 2630 SCF A
q
w
e
r
q Style Symbol
Blank : Standard
w Applicable Cable Size 2630 : 26 to 30 AWG
3032 : 30 to 32 AWG
2
e Packaging Type SCF : Socket Contact/Reel
G : Low insertion / extraction r Plating Type
Blank : Tin plated
A : Gold plated
■Single Row Socket
Photo: Contact insertion
Part No.
HRS No. No. of Contacts
A
536-0001-4
1.25
DF13-2S-1.25C
2
536-0002-7
2.50
DF13-3S-1.25C
3
536-0003-0
3.75
DF13-4S-1.25C
4
536-0004-2
5.00
DF13-5S-1.25C
5
536-0005-5
6.25
DF13-6S-1.25C
6
536-0006-8
7.50
DF13-7S-1.25C
7
536-0007-0
8.75
DF13-8S-1.25C
8
Note 1 : The quantity is delivered per bag (100pcs.).
B
Part No.
4.15
536-0008-3
DF13- 9S-1.25C
9
536-0009-6
5.40
DF13-10S-1.25C
10
6.65
536-0010-5
DF13-11S-1.25C
11
7.90
536-0011-8
DF13-12S-1.25C
12
9.15
536-0012-0
DF13-13S-1.25C
13
10.40
536-0013-3
DF13-14S-1.25C
14
11.65
536-0014-6
DF13-15S-1.25C
15
If needed, please select and order the products per bag.
Unit : mm
A
B
10.00 12.90
11.25 14.15
12.50 15.40
13.75 16.65
15.00 17.90
16.25 19.15
17.50 20.40
■Double Row Socket
Photo: Contact insertion state
Part No.
DF13-10DS-1.25C
DF13-20DS-1.25C
DF13-30DS-1.25C
DF13-40DS-1.25C
Note : The quantity
Unit : mm
A
B
536-0550-2
10
10.40
5.00
536-0555-6
11.25
536-0560-6
30
22.90
17.50
536-0565-0
40
29.15
23.75
is delivered per bag (100pcs). If needed, please select and order the products per bag.
3
■Single Row Straight Pin Header (Through hole)
[Specific No.] (**), **
Blank : Tin plated
(75) : Tin plated, tube packaging
BTube Dimensions
10
5
●Board Through-hole Diameter : Ø0.6±0.03
Unit: mm
Part No.
HRS No. No. of Contacts A
B Tube Packaging Quantity
Part No.
115
37
DF13-2P-1.25DSA(**) 536-0101-9 **
2
1.25 4.15
DF13- 9P-1.25DSA(**) 536-0108-8 **
9
10.00 12.90
89
34
DF13-3P-1.25DSA(**) 536-0102-1 **
3
2.50 5.40
DF13-10P-1.25DSA(**) 536-0109-0 **
10
11.25 14.15
72
31
DF13-4P-1.25DSA(**) 536-0103-4 **
4
3.75 6.65
DF13-11P-1.25DSA(**) 536-0110-0 **
11
12.50 15.40
61
29
DF13-5P-1.25DSA(**) 536-0104-7 **
5
5.00 7.90
DF13-12P-1.25DSA(**) 536-0111-2 **
12
13.75 16.65
52
27
DF13-6P-1.25DSA(**) 536-0105-0 **
6
6.25 9.15
DF13-13P-1.25DSA(**) 536-0112-5 **
13
15.00 17.90
46
25
DF13-7P-1.25DSA(**) 536-0106-2 **
7
7.50 10.40
DF13-14P-1.25DSA(**) 536-0113-8 **
14
16.25 19.15
41
23
DF13-8P-1.25DSA(**) 536-0107-5 **
8
8.75 11.65
DF13-15P-1.25DSA(**) 536-0114-0 **
15
17.50 20.40
Note 1 : The quantity at the specific No."None" is delivered per bag (100pcs.). If needed, please select and order the products per bag.
Note 2 : Order the tube packaging product, multiplying the tube packaging quantity.
■Single Row Right Angle Pin Header (Through hole)
(20) : Tin plated tube packaging
BTube Dimensions
Part No.
DF13-2P-1.25DS(20)
DF13-3P-1.25DS(20)
DF13-4P-1.25DS(20)
DF13-5P-1.25DS(20)
DF13-6P-1.25DS(20)
DF13-7P-1.25DS(20)
DF13-8P-1.25DS(20)
Note 1 : Order the
4
Part No.
2
1.25 4.15
115
536-0151-7 20
DF13- 9P-1.25DS(20)
3
2.50 5.40
89
536-0152-0 20
DF13-10P-1.25DS(20)
4
3.75 6.65
72
536-0153-2 20
DF13-11P-1.25DS(20)
5
5.00 7.90
61
536-0154-5 20
DF13-12P-1.25DS(20)
6
6.25 9.15
52
536-0155-8 20
DF13-14P-1.25DS(20)
7
7.50 10.40
46
536-0156-0 20
DF13-15P-1.25DS(20)
8
8.75 11.65
41
536-0157-3 20
9
536-0158-6 20
10
536-0159-9 20
11
536-0160-8 20
12
536-0161-0 20
14
536-0163-6 20
15
536-0164-9 20
Unit : mm
A
10.00 12.90
37
11.25 14.15
34
12.50 15.40
31
13.75 16.65
29
16.25 19.15
25
17.50 20.40
23
■Single Row Straight Pin Header (SMT)
■(Three-Wall/Correspond to Vacuum Absorption)
1.8
BPCB mounting pattern
Note 1.Shaded area must be free of any
electrically conductive traces to
avoid contact with soldered pin
header terminations.
This pin header is a three-wall type, header has sufficiently large flat areas to allow
pick-up with vacuum nozzles of automatic placement equipment.
(21) : Tin plated embossed tape packaging
(51) : Gold plated embossed tape packaging
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
D
E
F
1.25 4.15 7.15 5.65 1.95 2.20
2
536-0401-2 **
DF13C- 2P-1.25V(**)
2.50 5.40 8.40 6.90 3.20 3.45
3
536-0402-5 **
DF13C- 3P-1.25V(**)
3.75 6.65 9.65 8.15 4.45 3.10
4
536-0403-8 **
DF13C- 4P-1.25V(**)
5.00 7.90 10.90 9.40 5.70 4.35
5
536-0404-0 **
DF13C- 5P-1.25V(**)
6.25 9.15 12.15 10.65 6.95 5.60
6
536-0405-3 **
DF13C- 6P-1.25V(**)
7.50 10.40 13.40 11.90 8.20 6.85
7
536-0406-6 **
DF13C- 7P-1.25V(**)
8.75 11.65 14.65 13.15 9.45 8.10
8
536-0407-9 **
DF13C- 8P-1.25V(**)
10.00 12.90 15.90 14.40 10.70 9.35
9
536-0408-1 **
DF13C- 9P-1.25V(**)
11.25 14.15 17.15 15.65 11.95 10.60
10
536-0409-4 **
DF13C-10P-1.25V(**)
12.50 15.40 18.40 16.90 13.20 11.85
11
536-0410-3 **
DF13C-11P-1.25V(**)
13.75 16.65 19.65 18.15 14.45 13.10
12
536-0411-6 **
DF13C-12P-1.25V(**)
16.25 19.15 22.15 20.65 16.95 15.60
14
536-0413-1 **
DF13C-14P-1.25V(**)
17.50 20.40 23.40 21.90 18.20 16.85
15
536-0414-4 **
DF13C-15P-1.25V(**)
Note 1 : Please order the embossed tape packaging product according to reel number. (1000pcs/reel)
Emboss
Width
16
16
24
24
24
24
24
24
24
32
32
32
44
5
■Single Row Right Angle Pin Header (SMT)
■(Four-Wall/Correspond to Vacuum Absorption)
1.8
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
D
Emboss
Width
1.25 4.15 7.15 5.65
16
2
536-0301-8 **
DF13A- 2P-1.25H(**)
2.50 5.40 8.40 6.90
16
3
536-0302-0 **
DF13A- 3P-1.25H(**)
3.75 6.65 9.65 8.15
24
4
536-0303-3 **
DF13A- 4P-1.25H(**)
24
5
536-0304-6 **
DF13A- 5P-1.25H(**)
24
6
536-0305-9 **
DF13A- 6P-1.25H(**)
24
7
536-0306-1 **
DF13A- 7P-1.25H(**)
24
536-0307-4 **
8
DF13A- 8P-1.25H(**)
24
9
536-0308-7 **
DF13A- 9P-1.25H(**)
24
10
536-0309-0 **
DF13A-10P-1.25H(**)
32
11
536-0310-9 **
DF13A-11P-1.25H(**)
32
12
536-0311-1 **
DF13A-12P-1.25H(**)
32
14
536-0313-7 **
DF13A-14P-1.25H(**)
44
15
536-0314-0 **
DF13A-15P-1.25H(**)
6
■Double Row Straight Pin Header (SMT)
Note 1. Shaded area must be free of any electrically
conductive traces to avoid contact with soldered
pin header terminations.
(22) : Tin plated embossed tape packaging
(52) : Gold plated embossed tape packaging
Unit : mm
Spec No. Spec No. Emboss
Part No.
HRS No.
No. of Contacts
A
B
C
(21)
(51)
Width
DF13EA-10DP-1.25V(**)
536-0570-0
10
12.10
5.00
8.70
24
DF13EA-20DP-1.25V(**)
536-0571-0
18.35 11.25 14.95
32
44
44
DF13EA-30DP-1.25V(**)
536-0572-0
30
24.60 17.50 21.20
DF13EA-40DP-1.25V(**)
536-0573-0
40
30.85 23.75 27.45
Note 2 : The absorption cap is attached to the embossed tape packaging product.
7
■Crimping Contact
Reel Contact (1Reel, 10,000reel contacts)
Part No.
KDF13
HRS No.
Finish
Applicable Cable (Tin Plated Annealing Copper Wire) (Note 1)
Wire size Stranded wire conductor Calcuated coss-section Jacket Diameter
UL
26 AWG 7Pieces /φ0.16mm 0.141mm2
28 AWG 7Pieces /φ0.127mm 0.089mm2 0.56 to
Tin plated
30 AWG 7Pieces /φ0.1mm 0055mm2 1.0mm
1061
30 AWG 7Pieces /φ0.1mm 0.055mm2 0.52 to
DF13-3032SCF 536-0299-8
1571 32 AWG 7Pieces /φ0.08mm 0.035mm2 0.8mm
2
1061 26 AWG 7Pieces /φ0.16mm 0.141mm2 0.56 to
28
AWG
DF13-2630SCFA(04) 536-0298-5 04
7Pieces
/φ0.127mm
0.089mm
1571
Au plated
30 AWG 7Pieces /φ0.1mm 0.055mm2 1.0mm
1061
DF13-3032SCFA 536-0641-6
2
DF13G-2630SCF
(Low insertion/extraction) 536-0643-1 Tin plated 1571 28 AWG 7Pieces /φ0.127mm 0.089mm2 1.0mm
1061
DF13G-2630SCFA
0.56 to
2
536-0642-9
Au
plated
Note 1 : Please contact your local Hirose sales REP if you plan on using wires other than those listed above.
DF13-2630SCF
1061
1571
536-0300-5
BApplicable Crimping Tool
KDF13G
1
0.15
0.5
7.2
2
0.9
3.7
3.3
0.8
1.5
■Crimp contact with cable
BProduct Number Structure
DF13-2630S 1 - 26 A 9 - 300
1
1 Part No. of adopted crimping contact
DF13-2630S : DF13-2630SCF
2 Wire type
1 : UL1571
Part No.
DF13-2630S1-26A9-300(05)
2
4
5
HRS No.
Quantity
536-9001-0 05
100pcs/Pack
Note 1 : Bag packaging (100pcs/pack). Order by number of packs.
8
3
3 Wire size
26 : 26AWG
4 Crimp position / End processing
A : Both end crimped
6
5 Wire color
9 : White
6 Wire length
300 : 300mm
Finish
Tin plating
BApplication Pattern
Through hole
(Single Row Product)
SMT
(Double Row Product)
Right Angle
SMT
Straight
9
BEmbossed Carrier Tape Dimensions
5.2±0.15
A−A
(1.4)
C±0.1
Product name label
Ø370±2
B±0.1
A±0.3
Ø21±0.8
A
A
2±0.5
0.4±0.1
(Ø80)
4±0.1
12±0.1
A
1.75±0.1
Ø5.25 +0.1
2±0.1(A<44mm)
2±0.15(A≧44mm)
Ø1
3±
0.2
KDF13C-*P-1.25V (**)
+2
D 0
(D+6)MAX
A
DIRECTION OF UNREELING
0.2
A−A
(1.1)
2±0.5
3±
4.1±0.15
0.3±0.1
Ø1
Ø21±
(Ø80)
A
C±0.1
B±0.1
A±0.3
Product name label
Ø330±2
2±0.1(A
很抱歉,暂时无法提供与“DF13A-2P-1.25H(21)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.46902
- 10+1.18779
- 30+1.06726
- 100+0.91692
- 500+0.84996
