SJD12A(C)XXL01 SERIES
Electrostatic Discharged Protection Devices (ESD) Data Sheet
Description
The SJD12A(C)XXL01 series are designed to protect voltage
sensitive components from high voltage, high energy transients.
Excellent clamping capability, high surge capability, low zener
impedance and fast response time. Because of its small size,
it is ideal for use in cellular phones, portable device, business
machines, power supplies and many other industrial/consumer
applications.
Features
IEC61000-4-2 ESD 15KV Air, 8KV contact compliance
SOD-123S surface mount package
Protects one I/O line
Peak power dissipation of 1000W under 8/20μs waveform
Working voltage: 5V~170V
Low leakage current
Solid-state silicon avalanche technology
Lead Free/RoHS compliant
Solder reflow temperature: Pure Tin-Sn, 260~270℃
Flammability rating UL 94V-0
Meets MSL level 1, per J-STD-020
SJD12AXXL01
Applications
Personal digital assistants (PDA)
Cellular handsets & Accessories
Portable devices
Portable instrumentation
Handhelds and notebooks
Digital cameras
SJD12CXXL01
Pin Configuration
Maximum Ratings
Rating
Symbol
Value
Unit
Peak pulse power (tp=10/1000μs waveform)
PPP
200
W
Peak pulse power (tp=8/20μs waveform)
PPP
1000
W
ESD voltage (Contact discharge)
ESD voltage (Air discharge)
Storage & operating temperature range
Revision:20-Nov-15
VESD
TSTG ,TJ
±8
±15
-55~+150
kV
www.brightking.com
Electrical Characteristics (TJ=25℃)
Part
Number
Device
Marking
Code
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
UNI
BI
VRWM(V)
VBR MIN.(V)
VBR MAX.(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SJD12A(C)05L01
KE
AE
5.0
6.40
7.00
10
9.2
21.8
800
SJD12A(C)06L01
KG
AG
6.0
6.67
7.37
10
10.3
19.4
800
SJD12A(C)6.5L01
KK
AK
6.5
7.22
7.98
10
11.2
17.9
500
SJD12A(C)07L01
KM
AM
7.0
7.78
8.60
10
12.0
16.7
200
SJD12A(C)7.5L01
KP
AP
7.5
8.33
9.21
1
12.9
15.5
100
SJD12A(C)08L01
KR
AR
8.0
8.89
9.83
1
13.6
14.7
50
SJD12A(C)8.5L01
KT
AT
8.5
9.44
10.40
1
14.4
13.9
SJD12A(C)09L01
KV
AV
9.0
10.00
11.10
1
15.4
13.0
10
SJD12A(C)10L01
KX
AX
10.0
11.10
12.30
1
17.0
11.8
5
SJD12A(C)11L01
KZ
AZ
11.0
12.20
13.50
1
18.2
11.0
3
SJD12A(C)12L01
LE
BE
12.0
13.30
14.70
1
19.9
10.1
1
SJD12A(C)13L01
LG
BG
13.0
14.40
15.90
1
21.5
9.3
1
SJD12A(C)14L01
LK
BK
14.0
15.60
17.20
1
23.2
8.6
1
SJD12A(C)15L01
LM
BM
15.0
16.70
18.50
1
24.4
8.2
1
SJD12A(C)16L01
LP
BP
16.0
17.80
19.70
1
26.0
7.7
1
SJD12A(C)17L01
LR
BR
17.0
18.90
20.90
1
27.6
7.3
1
SJD12A(C)18L01
LT
BT
18.0
20.00
22.10
1
29.2
6.9
1
SJD12A(C)20L01
LV
BV
20.0
22.20
24.50
1
32.4
6.2
1
SJD12A(C)22L01
LX
BX
22.0
24.40
26.90
1
35.5
5.7
1
SJD12A(C)24L01
LZ
BZ
24.0
26.70
29.50
1
38.9
5.2
1
SJD12A(C)26L01
ME
CE
26.0
28.90
31.90
1
42.1
4.8
1
SJD12A(C)28L01
MG
CG
28.0
31.10
34.40
1
45.4
4.4
1
SJD12A(C)30L01
MK
CK
30.0
33.30
36.80
1
48.4
4.2
1
SJD12A(C)33L01
MM
CM
33.0
36.70
40.60
1
53.3
3.8
1
SJD12A(C)36L01
MP
CP
36.0
40.00
44.20
1
58.1
3.5
1
SJD12A(C)40L01
MR
CR
40.0
44.40
49.10
1
64.5
3.1
1
SJD12A(C)43L01
MT
CT
43.0
47.80
52.80
1
69.4
2.9
1
Revision:20-Nov-15
www.brightking.com
Part
Number
Device
Marking
Code
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
UNI
BI
VRWM(V)
VBR MIN.(V)
VBR MAX.(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SJD12A(C)45L01
MV
CV
45.0
50.00
55.30
1
72.7
2.8
1
SJD12A(C)48L01
MX
CX
48.0
53.30
58.90
1
77.4
2.6
1
SJD12A(C)51L01
MZ
CZ
51.0
56.70
62.70
1
82.4
2.5
1
SJD12A(C)54L01
NE
DE
54.0
60.00
66.30
1
87.1
2.3
1
SJD12A(C)58L01
NG
DG
58.0
64.40
71.20
1
93.6
2.3
1
SJD12A(C)60L01
NK
DK
60.0
66.70
73.70
1
96.8
2.1
1
SJD12A(C)64L01
NM
DM
64.0
71.10
78.60
1
103.0
2.0
1
SJD12A(C)70L01
NP
DP
70.0
77.80
86.00
1
113.0
1.8
1
SJD12A(C)75L01
NR
DR
75.0
83.30
92.10
1
121.0
1.7
1
SJD12A(C)78L01
NT
DT
78.0
86.70
95.80
1
126.0
1.6
1
SJD12A(C)85L01
NV
DV
85.0
94.40
104.00
1
137.0
1.5
1
SJD12A(C)90L01
NX
DX
90.0
100.00
111.00
1
146.0
1.4
1
SJD12A(C)100L01
NZ
DZ
100.0
111.00
123.00
1
162.0
1.3
1
SJD12A(C)110L01
PE
EE
110.0
122.00
135.00
1
177.0
1.2
1
SJD12A(C)120L01
PG
EG
120.0
133.00
147.00
1
193.0
1.1
1
SJD12A(C)130L01
PK
EK
130.0
144.00
159.00
1
209.0
1.0
1
SJD12A(C)150L01
PM
EM
150.0
167.00
185.00
1
243.0
0.8
1
SJD12A(C)160L01
PP
EP
160.0
178.00
197.00
1
259.0
0.8
1
SJD12A(C)170L01
PR
ER
170.0
189.00
209.00
1
275.0
0.8
1
Revision:20-Nov-15
www.brightking.com
Typical Characteristics Curves
Figure 1. Peak Pulse Power Rating Curve
Figure 2. 10/1000μs Pulse Waveforms
Figure 3. 8/20μs Pulse Waveforms
Figure 4. Power Derating Curve
tr
Peak value Ipp
Waveform
Parameters:
tr=8µs
td=20µs
90
80
Peak Power Dissipation (%)
110
100
70
60
50
40
30
td=t|IPP/2
10
15
30
t-Time (μs)
Figure 5. Capacitance vs. Reverse Voltage
Revision:20-Nov-15
www.brightking.com
Recommended Soldering Conditions
Reflow Soldering
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
Time 25℃ to Peak Temperature
Revision:20-Nov-15
20-40 seconds
6℃/second max.
8 minutes max.
www.brightking.com
Dimensions (SOD-123S)
Dimension
Symbol
Millimeters
Inches
Min.
Max.
Min.
Max.
A
3.50
3.90
0.138
0.154
B
2.60
3.00
0.102
0.118
C
0.75
1.10
0.030
0.043
D
1.60
2.00
0.063
0.079
E
0.80Typ.
0.031Typ.
F
0.90
1.40
0.035
0.055
G
0.12
0.22
0.005
0.009
Packaging
B
Reel
W
F
E
Tape
Symbol
Dimension (mm)
W
8.00±0.30
P0
4.00±0.10
P1
4.00±0.10
P2
2.00±0.10
D0
Φ1.50±0.10
D1
Φ1.00±0.05
E
1.75±0.10
F
3.50±0.10
A
2.00±0.10
B
3.95±0.10
K
1.40±0.12
t
0.23±0.10
D
Φ178.0±2.0
D2
Φ13.0
W1
9.5
Quantity: 3000PCS
Revision:20-Nov-15
www.brightking.com
很抱歉,暂时无法提供与“SJD12A24L01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.18750
- 100+0.17500
- 300+0.16250
- 500+0.15000
- 2000+0.14375
- 5000+0.14000
