0603ESDA-XXN
ESD Protection Diode
»Features
0603inch/ 1608mm foot print
Ideal ESD protection for high frequency, low voltage
applications.
Exceeds testing requirements outlined in IEC 61000-4-2
Ultra low capacitance (1.5pF typ.)
Very low leakage current
Fast response time
Bi-directional
MSL 3
»Applications
High Speed Data Ports
( USB 2.0, IEEE 1394 )
Computers & Peripherals
( Cell phone, PDA, HDTV, DVD players )
»Mechanical Data
Surface mount
RoHS Compliant
»Schematic & PIN Configuration
Revision 2018
www.born-tw.com
1/6
0603ESDA-XXN
»Absolute Maximum Rating
Rating
Symbol
Value
Units
VESD
15
8
kV
Lead Soldering Temperature
TL
260(10seconds)
Operating Temperature
TO
-55 to + 125
Storage Temperature
Tstg
-40 to + 125
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
Conditions
»Electrical Characteristics
0603ESDA-05N
Parameter
Symbol
Conditions
Min
Typical
Continuous Operating Voltage
VDC
Trigger Voltage
VT
IEC61000-4-2 8KV
contact discharge
Leakage Current
IL
VDC=5V,T=25 ℃
Clamping Voltage
VC
IEC61000-4-2 8KV
contact discharge
65
Capacitance
CP
Measured at 10MHz
1.5
ESD Pulse Withstand
Pulses
IEC61000-4-2 8KV
contact discharge
Max
Units
5.0
V
140
V
500
nA
100
V
pF
1000
0603ESDA-09N
Parameter
Symbol
Conditions
Min
Typical
VDC
Trigger Voltage
VT
IEC61000-4-2 8KV
contact discharge
Leakage Current
IL
VDC=9V,T=25 ℃
Clamping Voltage
VC
IEC61000-4-2 8KV
contact discharge
65
Capacitance
CP
Measured at 10MHz
1.5
ESD Pulse Withstand
Revision 2018
Pulses
IEC61000-4-2 8KV
contact discharge
www.born-tw.com
Max
Units
9.0
V
140
V
500
nA
100
V
pF
1000
2/6
0603ESDA-XXN
0603ESDA-12N
Parameter
Symbol
Conditions
Min
Typical
VDC
Trigger Voltage
VT
IEC61000-4-2 8KV
contact discharge
Leakage Current
IL
VDC=12V,T=25 ℃
Clamping Voltage
VC
IEC61000-4-2 8KV
contact discharge
65
Capacitance
CP
Measured at 10MHz
1.5
ESD Pulse Withstand
Pulses
IEC61000-4-2 8KV
contact discharge
Max
Units
12.0
V
140
V
500
nA
100
V
pF
1000
0603ESDA-14N
Parameter
Symbol
Conditions
Min
Typical
VDC
Trigger Voltage
VT
IEC61000-4-2 8KV
contact discharge
Leakage Current
IL
VDC=14V,T=25 ℃
Clamping Voltage
VC
IEC61000-4-2 8KV
contact discharge
65
Capacitance
CP
Measured at 10MHz
1.5
ESD Pulse Withstand
Pulses
IEC61000-4-2 8KV
contact discharge
Max
Units
14.0
V
140
V
500
nA
100
V
pF
1000
0603ESDA-18N
Parameter
Symbol
Conditions
Min
Typical
VDC
Trigger Voltage
VT
IEC61000-4-2 8KV
contact discharge
Leakage Current
IL
VDC=18V,T=25 ℃
Clamping Voltage
VC
IEC61000-4-2 8KV
contact discharge
65
Capacitance
CP
Measured at 10MHz
1.5
ESD Pulse Withstand
Revision 2018
Pulses
IEC61000-4-2 8KV
contact discharge
www.born-tw.com
Max
Units
18.0
V
140
V
500
nA
100
V
pF
1000
3 /6
0603ESDA-XXN
0603ESDA-24N
Parameter
Symbol
Conditions
Min
Typical
VDC
Trigger Voltage
VT
IEC61000-4-2 8KV
contact discharge
Leakage Current
IL
VDC=24V,T=25 ℃
Clamping Voltage
VC
IEC61000-4-2 8KV
contact discharge
65
Capacitance
CP
Measured at 10MHz
1.5
ESD Pulse Withstand
Revision 2018
Pulses
IEC61000-4-2 8KV
contact discharge
www.born-tw.com
Max
Units
24.0
V
140
V
500
nA
100
V
pF
1000
4 /6
0603ESDA-XXN
»ESD Wave From
IPP
100%
90%
SEVERITY LEVEL
AIR DIRCHARGE
DIRECT
DISCHARGE
1
2KV
2KV
2
4KV
4KV
3
8KV
6KV
4
15KV
8KV
IEC61000-4-2 compliant ESD current pulse waveform
10%
tr = 0.7 ns to 1ns
t
30 ns
60 ns
»Environment Reliability Test
Characteristic
Test Method and Description
High Temperature
Storage
The specimen shall be subjected to 125±2℃ for 1000±2 hours without load and then
stored at room temperature and normal humidity for one or two hours. The change of
varistor voltage shall be within 10%.
Temperature Cycle
The temperature cycle of specified
temperature shall be repeated five times and
then stored at room temperature and normal
varistor voltage shall be within 10% and
mechanical damage shall be examined.
High Temperature
Load
Damp Heat Load/
Humidity Load
Low Temperature
Storage
Revision 2018
Step
Temperature
Period
1
-40±3℃
30±3min
2
room temperature
1 hour
3
125±3℃
30±3min
4
room temperature
1 hour
After being continuously applied the maximum allowable voltage at 85±2℃ for
1000±2 hours, the specimen shall be stored at room temperature and normal
humidity for one or two hours. The change of varistor voltage shall be within 10%.
The specimen should be subjected to 40±2℃ and 90~95% RH, the maximum
allowable voltage applied for 1000±2 hours and then stored at room temperature and
normal humidity for one or two hours. The change of varistor voltage shall be within
10%.
The specimen should be subjected to -40±2℃ for 1000±2 hours without load and
then stored at room temperature and normal humidity for one or two hours. The
www.born-tw.com
5 /6
0603ESDA-XXN
»Soldering Parameters
Peak Temp 260℃(3~10sec)
250
Peak Temp 245 ℃
(10~20sec)
Temperature ( ℃ )
225
200
175
150
125
100
Pre-Heat 175 ℃
(60~120sec)
75
25
01:00:00
02:00:00
03:00:00
04:00:00
Time (min)
☆ IR reflow Pb free process suggestion profile
(1) The solder recommend is Sn96.5/Ag3.5 and thickness recommend as shown in table 5.3
(2) Ramp-up rate (217℃ to peak) +3℃/second max.
(3) Temp. maintain at 175±25℃ 180 seconds max.
(4) Temp. maintain above 217℃ 60~150 seconds
»Outline Drawing-0603
L
Unit: Millimeters
Dimension
Min.
Typ.
Max.
L
1.45
1.60
1.75
W
0.70
0.80
0.90
P
0.20
0.30
0.40
W
P
Bottom view
H
0.90
H
Side view
»Ordering information
Order code
0603ESDA-XXN
Revision 2018
Package
0603
Base qty
4k
www.born-tw.com
Delivery mode
Tape and reel
6/6
很抱歉,暂时无法提供与“0603ESDA-05N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.15002
- 500+0.12086
- 1500+0.10790
- 4000+0.08025
- 24000+0.07636
- 48000+0.07366
- 国内价格
- 20+0.13751
- 400+0.11078
- 1600+0.09890
- 4000+0.07356
- 20000+0.06999
- 40000+0.06752
- 国内价格
- 1+0.08930
- 4000+0.07090
