SYF-001T-P0.6(LF)(SN) 数据手册
VYH CONNECTOR
6.5mm pitch/Disconnectable Crimp style connectors
Specifications –––––––––––––––––––
• Current rating: 15 A AC, DC (2 circuits/ AWG #14)
• Voltage rating: 300 V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 10 mΩ max.
After environmental tests/ 20 mΩ max.
• Insulation resistance: 1,000 MΩ min.
• Withstanding voltage: 1,500 VAC/minute
• Applicable wire: AWG #26 to #14
• Applicable PC board thickness: 1.6 mm
Note: The current rating differs depending on the number of circuits and the
wire size used in each connector. The table below lists the current rating
as a function of the number of circuits and the wire size.
Current unit:A
Circuits
2
3
4
6
This VYH connector is designed for wireto-board 6.5 mm pitch connector
corresponding to large current. Secondary
retainer, which prevents from insufficient
insertion of contact and coming off
contact, may use and large current circuit
can be connected certainly and safely.
#14
#16
#18
15
14
13
12
10
9
9
8
7
6
6
5
Wire size(AWG)
#20
#22
5
4
4
3
#24
4
4
4
3
#26
3
3
3
2
2
2
2
2
Note: Do not branch in parallel current which exceeds the rated current (e.g.
more than 15 A in the case of 2 circuits with AWG #14). If branched in
parallel, current imbalance or other problems may develop.
If it is absolutely necessary to branch such a large current in parallel,
design the circuits without causing any imbalance and provide an extra
margin for each circuit.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
* Compliant with RoHS.
Standards ––––––––––––––––––––––
• Corresponding to large current
• Misinsertion prevention
• Housing lance for contact retention
• Secondary retainer
0 Recognized E60389
1
Certified LR70035705
2R50036139
PC board layout and Assembly layout
Double-row type
Single-row type
(10.8)
(16.95)
φ1.4 +0.1
(φ3.3)
(Land)
Connector outline
Circuit No.1
φ1.4 +0.1
(24)
8.4
±0.05
2
8.4
Connector outline
Circuit No.1
6.5
2 ±0.05
4.5
(φ3.3)
(Land)
(3.2)
(16.4)
±0.05
6.5 ±0.05(3.6)
±0.05
±0.05
4.5 ±0.05
(2.9)
6.5
(4.5)
(3.2)
φ1.4 +0.1
A
φ1.4 +0.1
±0.05
(2.9)
(25.8)
A ±0.05
Note: 1. The above figure is the figure viewed from the connector mounting side .
2. Tolerances are non-cumulative: ±0.05 mm for all centers.
3. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details.
1
VYH CONNECTOR
Contact
SVYF type
2.8
2.8
14.2
2.4
SYF-01T-P0.5A
SYF-41T-P0.5A
SYF-61T-P0.5A
*SVYF-41T-P0.5A-13.5
*SVYF-61T-P0.5A
Insulation O.D.
(mm)
Q't y/
reel
0.13∼0.5
26∼20
1.3∼2.5
4,000
0.5∼1.25
20∼16
2.0∼3.4
4,000
0.75∼2.0
18∼14
2.1∼3.4
2,000
0.5∼1.25
20∼16
2.0∼3.4
4,000
0.75∼2.0
18∼14
2.1∼3.6
2,000
Material and Finish
2
Copper alloy, tin-plated (reflow treatment)
1.8
1.8
2.4
Crimping
machine Crimp applicator
*MKS-SC-YL
SC/SYF/M-01-05
APLSC SYF/M01-05
MK/SYF/M-61-05 APLMK SYF/M61-05
MKS-L
SVYF-61T-P0.5A
Crimp applicator with dies
MKS-L
AP-K2N
Applicator
Dies
MK/SYF/M-01-05 APLMK SYF/M01-05
MKS-L
SYF-01T-P0.5A
SYF-61T-P0.5A
AWG#
14.2
2
Contact
Applicable wire
mm2
Model No.
RoHS compliance
Note: 1. SVYF type contact was developed only for VYH connector in order to
improve the prevention of prying.
2. Retainer cannot be used when using 41 type contact AWG#16 and
61 type contact.
3. *Marked product is not TÜV approved.
Crimping
Contact
MKS-L
SYF-41T-P0.5A
AP-K2N
*MKS-SC-YL
MKS-L
SVYF-41T-P0.5A-13.5
Applicator
Dies
MK/SYF/M-41-05 APLMK SYF/M41-05
SC/SYF/M-41-05
APLSC SYF/M41-05
MK/SVYF-41-05-13.5 APLMK SVYF41-05-13.5
Note: *Strip-crimp applicator
Housing
Single-row type
Type
B
A
9.4
6.5
1
Singlerow type
Circuits
Model No.
2
VYHP-02V
VYHP-03V
VYHP-04V
VYHP-04VD
VYHP-06VD
3
4
Doublerow type
4
6
Dimensions (mm) Q’ty/
bag
A
B
6.5
12.3
400
13.0
18.8
300
19.5
25.3
200
6.5
12.3
200
13.0
18.8
150
20.4
Material
PA 66, UL94V-0, natural (white)
RoHS compliance
Double-row type
16.4
B
A
20.4
6.5
2
VYH CONNECTOR
Shrouded header
Single-row type
Type
10.8
B
B02B-VYHSK-1
B03B-VYHSK-1
B04B-VYHSK-1
B04B-VYHSK-D-1
B06B-VYHSK-D-1
2
Singlerow type
A
6.5
3
4
4
6
15.5
Doublerow type
Type
B
300
19.5
25.3
200
6.5
12.3
200
13.0
18.8
150
box
A
B
Model No.
Circuits
16.4
B02B-VYHSK-M-1
B03B-VYHSK-M-1
B04B-VYHSK-M-1
B04B-VYHSK-DM-1
B06B-VYHSK-DM-1
2
A
Singlerow type
6.5
3
4
15.5
Doublerow type
4
6
6.5
12.3
400
13.0
18.8
300
19.5
25.3
200
6.5
12.3
200
13.0
18.8
150
1.5
Material and Finish
Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment)
Wafer: Glass-filled PA66, UL94V-0, natural (ivory)
3.8
2
400
18.8
RoHS compliance This product displays (LF)(SN) on a label.
4.5
Double-row type
1.2
12.3
Material and Finish
1.5
2
6.5
13.0
Wafer: Glass-filled PBT, UL94V-0, natural (white)
3.8
1.2
box
A
B
Model No.
Circuits
4.5
6.5
6.5
Retainer
Circuits
Model No.
2
VYHS-02V-S
VYHS-03V-S
VYHS-04V-S
3
4
6.5
10.3
4,000
16.8
3,000
19.5
23.3
2,000
A
L JST
Material
B
Q'ty/
bag
13.0
RoHS compliance
¨ V approved.
Note: Not TU
3
Dimensions (mm)
A
B
SYF-001T-P0.6(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“SYF-001T-P0.6(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+0.4802810+0.06215
- 100+0.37287100+0.04826
- 1000+0.313491000+0.04057
- 7500+0.251497500+0.03255
- 国内价格 香港价格
- 1+0.323101+0.04181
- 10+0.2619710+0.03390
- 50+0.2095850+0.02712
- 100+0.18338100+0.02373
- 500+0.16592500+0.02147
- 1000+0.165921000+0.02147
- 2000+0.157182000+0.02034
