Crimp
2.5mm
RCY CONNECTOR
Disconnectable Crimp style Wire-to-wire connectors
pitch
Features ––––––––––––––––––––––––
• Use of a free spring contact for superb creep
characteristics
The contact section features a free spring contact construction,
which effectively minimizes stress (creep) caused by repeated
insertion and removal at high temperatures. Connector insertion
and removal is also smooth, ensuring stable connection
performance.
• Compact design
The RCY connector is designed to be compact. When mated,
its overall length is just 23.3mm and its thickness is 4.0mm.
• Housing lock
Because a lock is provided inside the housing, external force is
not applied to the lock.
The RCY connector is a compact, 2.5mm
pitch wire-to-wire connector for use with a
variety of circuits, from signal circuits to
power supply circuits, in electrical
equipment which is becoming more and
more compact. The employment of a free
spring contact method ensures stable
contact performance, and superb working
efficiency of insertion and removal.
Specifications –––––––––––––––––––
• Current rating: 3A AC, DC max.
• Voltage rating: 250V AC, DC max.
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/10m Ω max.
After environmental testing/20m Ω max.
• Insulation resistance: 500M Ω min.
• Withstanding voltage: 1,500V AC/minute
• Applicable wire: AWG #28 to #22
0.08 to 0.33mm2
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Note: The current rating varies depending on the wire size used
in each connector.
The table below lists the current rating as a function of the
wire size.
Current unit: A
Circuits
2
Wire size (AWG)
#22
#24
#26
#28
3
2
1
0.5
Standards ––––––––––––––––––––––
Recognized E60389
Certified LR20812
1
RCY
CONNECTOR
Contact––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Socket contact
1.1
1.7
Pin contact
11
15.8
1.8
2
2
1.7
0.64
1.7
Pin contact
SYM-001T-P0.6
Q´ty / reel
Applicable wire
Model No.
Socket contact
mm2
AWG #
Insulation O.D.
(mm)
SYF-001T-P0.6
0.08 to 0.33
28 to 22
1.2 to 1.8
Pin
contact
Socket
contact
8,500
7,500
Material and Finish
Phosphor bronze, tin-plated (reflow treatment)
RoHS compliance SYF-001T-P0.6 displays (LF)(SN) on a label.
Note: Contact JST for brass products.
Housing –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Plug housing
(for socket contact)
6.3
5.3
2.5
6.7
5.9
1
2
2.5
2
1
Receptacle housing
(for pin contact)
4.3
9.5
Model No.
Circuits
2
13
3.2
19
Q´ty / bag
Material
Receptacle housing
Plug housing
SYR-02T
SYP-02T-1
PA 66, UL94V-2, red
1,000
SYR-02TV
SYP-02TV-1
PA 66, UL94V-0, white (natural)
1,000
RoHS compliance
Assembly layout–––––––––––––––––––––
Crimping machine, Applicator –––––––––
Contact
23.3
Crimping
machine Crimp applicator
MKS-L, MSK-LS
SYM-001T-P0.6
4
AP-K2N
SYF-001T-P0.6
Note: *Strip-crimp applicator
2
Applicator
Dies
Crimp applicator with dies
MK/SYM-001-06 APLMK SYM001-06
*MKS-SC
SC/SYM-001-06
APLSC SYM001-06
MKS-L
MK/SYF-001-06
APLMK SYF001-06
很抱歉,暂时无法提供与“SYP-02TV-1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.51938
- 50+0.41829
- 150+0.36774
- 1000+0.31580
- 2000+0.28545
- 国内价格
- 10+0.47609
- 100+0.38343
- 200+0.33710
- 400+0.33204
- 1000+0.28948
- 5000+0.28659
