CRYSTAL OSCILLATOR
YSO120TK
Applications
‧RTC Camera
Wide Voltage
Features
‧Frequency range:32.768KHz.
‧Ultra Small SMD seam sealed
‧Package Size: 1.6*1.2 , 2.0*1.6
2.5*2.0 , 3.2*2.5 , 5.0*3.2 , 7.0*5.0mm
crystal oscillator units.
Specifications
Frequency Range
32.768KHz
Parameter
1.8V~3.3V
Output Type
CMOS
Frequency Tolerance(at 25℃)
±10ppm,±20ppm,or specify
Output Load
15pF
Operating Temperature Range
-40~+85℃,-40~+125℃,or specify
Storage Temperature Range
-55~+125℃
Frequency Versus Temperature Characteristics
± 20ppm, ± 30ppm, ± 50ppm, or specify
Voltage Vol ( Max. ) / Vol ( Min. )
VOH = 90%Vdd/VOL = 10%Vdd
Duty Cycle
45~55%
Start-up Time
3ms Max.
Supply Current
See Below
Frequency Aging (at 25℃)
±3 ppm / year Max.
Current Consumption
32.768KHZ
Supply Voltage (V)
7050/5032/3225
2520/2016/1612
1.8V
0.2mA max
0.2mA max
2.5V
0.3mA max
0.3mA max
3.3V
0.5mA max
0.4mA max
Pin Dimension
Pin Assignments
Pin
#1
#2
#3
#4
FUNCTION
Tri-state
GND
OUTPUT
VDD
www.yxc.hk
第1页共4页
CRYSTAL OSCILLATOR
YSO120TK
Wide Voltage
Dimensions and Patterns [unit:mm]
Package Size – Dimensions (Unit: mm)
Recommended Land Pattern (Unit: mm)
#3
#2
#4
0.60max
#1
Bottom
View
#2
1.25±0.1
MARKING
#1
#3
0.57±0.1 0.7±0.1
0.775 0.5 0.775
0.6 0.2 0.6
1.65±0.1
#4
0.475±0.1 0.5±0.1 0.475±0.1
1.6*1.2mm
#3
#4
#2
0.775 0.5 0.775
2.5±0.1
0.9 0.95 0.9
#4
#3
0.95
0.8±0.1
0.8 0.65 0.8
0.65
MARKING
#2
2.0±0.1
#1
0.68
2.5*2.0mm
#3
0.1
0.57±0.1 0.7±0.1
0.85max
#1
#2
1.65±0.1
MARKING
#1
Bottom
View
0.675 0.3 0.675
2.05±0.1
#4
2.0*1.6mm
0.78
0.4
3.2*2.5mm
3.2±0.15
1.3 1.0
1.2
0.9
#3
0.9±0.1
#4
1.1 0.8 1.1
1.0
2.5±0.1
MARKING
1.3
#2
0.65
#1
www.yxc.hk
第2页共4页
CRYSTAL OSCILLATOR
YSO120TK
Wide Voltage
5.0*3.2mm
1.4
2.54±0.1
5.0±0.2
#2
2.2
1.0
MARKING
3.2±0.1
1.2
#1
#3
#4
1.2±0.1
1.2
2.54
7.0*5.0mm
7.00±0.15
2.0
#3
5.08±0.15
3.28
1.4±0.1
#4
2.2
2.6±0.1
MARKING
#2
5.0±0.1
#1
1.4±0.15
0.6±0.15
1.8
Notes:
1.A capacitor of value 0.01uf~0.1uf or higher between Vdd and GND is required.
Reflow Soldering Profile
Pre Heating Temperature
Tp1 ~ Tp2 = + 170 °C
Heating Temperature
TMlt = + 220 °C
Peek Temperature
TMax. = + 260 °C
Temperature
+260℃
TMax.
+220℃
Tmlt
Point of measuring
In case of Solder ability Terminal.
In case of Resistance to soldering heat Surface.
Tp2
Tp1
35s
100s
t(time)
www.yxc.hk
第3页共4页
CRYSTAL OSCILLATOR
YSO120TK
Wide Voltage
Test Circuit
Taping Specification(Unit: mm)
Size(OSC)
A
B
C
D
E
F
G
H
SMD-7050
180±2.0
16.0±0.3
7.50±0.1
5.50±0.1
8.0±0.1
2.00±0.1
61.0±1.0
16.0±1.0
SMD-5032
180±2.0
12.0±0.3
5.40±0.1
3.60±0.1
8.0±0.1
1.70±0.1
61.0±1.0
12.0±1.0
SMD-3225
180±2.0
8.0±0.3
3.40±0.1
2.70±0.1
4.0±0.1
1.50±0.1
61.0±1.0
8.0±1.0
SMD-2520
180±2.0
8.0±0.3
2.90±0.1
2.40±0.1
4.0±0.1
1.20±0.1
61.0±1.0
8.0±1.0
SMD-2016
180±2.0
8.0±0.3
2.30±0.1
1.90±0.1
4.0±0.1
0.95±0.1
61.0±1.0
8.0±1.0
SMD-1612
180±2.0
8.0±0.3
1.80±0.1
1.40±0.1
4.0±0.1
0.80±0.1
61.0±1.0
8.0±1.0
www.yxc.hk
第4页共4页
OK322532.768KJBA4SL 价格&库存
很抱歉,暂时无法提供与“OK322532.768KJBA4SL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.35880
- 10+3.01320
- 30+2.84040
- 100+2.66760
- 500+2.19240
- 1000+2.13840
- 国内价格
- 10+7.51850
- 100+4.48500
- 800+3.13950
- 3000+2.24250
- 6000+2.13040
- 30000+1.97340
- 国内价格
- 1+2.11344
- 30+2.03574
- 100+1.88034
- 500+1.72494
- 1000+1.64724
- 国内价格
- 1+2.92320
- 100+2.33400
- 750+2.08480
- 1500+1.97150
- 3000+1.86950
- 国内价格
- 1+3.24760
- 10+2.68210
- 50+2.28500
- 150+2.14080
- 500+2.01350
- 1000+1.90080
- 国内价格
- 50+1.98880
- 500+1.92963
