SL2301
SL2301
    SLKOR(萨科微)
    SOT-23
    类型:P沟道 漏源电压(Vdss):20V 连续漏极电流(Id):2.8A 功率(Pd):400mW 导通电阻(RDS(on)@Vgs,Id):112mΩ@4.5V,2.8A 阈值电压(Vgs(th)...
SL2301 数据手册
SL2301 P-Channel Power MOSFET D General Features G ● VDS = -20V,ID = -2.4A RDS(ON) < 200mΩ@ VGS=-2.5V RDS(ON) < 140mΩ@ VGS=-4.5V S Schematic diagram ● High power and current handing capability ● Lead free product is acquired ● Surface mount package Application ● PWM applications Marking and Pin Assignment ● Load switch ● Power management SOT-23 top view MAXIMUM RATINGS Characteristic Symbol Max Unit BVDSS -20 V VGS +8 V ID -2.4 A IDM -10 A TA=25℃ PD 900 mW Junction TJ 150 ℃ Storage Temperature Tstg -55to+150 ℃ Drain-Source Voltage Gate- Source Voltage Drain Current (continuous) Drain Current (pulsed) Total Device Dissipation www.slkormicro.com 1 SL2301 ELECTRICAL CHARACTERISTICS (TA=25℃ unless otherwise noted ) Characteristic Symbol Min Typ Max Unit Drain-Source Breakdown Voltage (ID = -250uA,VGS=0V) BVDSS -20 — — V Gate Threshold Voltage (ID = -250uA,VGS= VDS) VGS(th) -0.4 — -1.5 V Diode Forward Voltage Drop (IS= -0.75A,VGS=0V) VSD — — -1.5 V Zero Gate Voltage Drain Current (VGS=0V, VDS= -16V, TA=55℃) IDSS — — -1 -10 uA Gate Body Leakage (VGS=+8V, VDS=0V) IGSS — — +100 nA Static Drain-Source On-State Resistance (ID= -2.4A,VGS= -4.5V) RDS(ON) — — 140 mΩ Static Drain-Source On-State Resistance (ID= -2A,VGS= -2.5V) RDS(ON) — — 200 mΩ Input Capacitance (VGS=0V, VDS= -10V,f=1MHz) CISS — 600 — pF Output Capacitance (VGS=0V, VDS= -10V,f=1MHz) COSS — 120 — pF Turn-ON Time (VDS= -10V, ID= -2.4A, RGEN=6Ω) t(on) — 8 — ns Turn-OFF Time (VDS= -10V, ID= -2.4A, RGEN=6Ω) t(off) — 60 — ns Pulse Width
SL2301 价格&库存
很抱歉,暂时无法提供与“SL2301”相匹配的价格&库存,您可以联系我们找货
SL2301
  • 1+0.39930
  • 200+0.25740
  • 1500+0.22330
  • 3000+0.19800
库存:19
SL2301
  • 3000+0.155043000+0.02013
  • 9000+0.127169000+0.01651
库存:5377
SL2301
  • 20+0.22162
  • 200+0.17678
  • 600+0.15185
  • 3000+0.13687
  • 9000+0.12394
  • 21000+0.11697
库存:2276
SL2301
  • 1+0.885961+0.11502
  • 10+0.5027610+0.06527
  • 50+0.3548150+0.04606
  • 100+0.30635100+0.03977
  • 500+0.21981500+0.02854
库存:5377
