MBRF30100CT
MBRF30100CT
    SLKOR(萨科微)
    TO-220F(TO-220IS)
    肖特基
MBRF30100CT 数据手册
MBRF30100CT Schottky Diodes ●Features: ■Common Cathode Structure ■Low Power Loss and High Efficiency ■Low Forward Voltage Drop ■High Surge Capability ●Application: ■ High Frequency Switch ■ Free Wheeling,and Polarity Protection Applications Absolute Maximum Ratings(Tc=25C unless otherwise noted) Symbol Parameter Value Unit VRRM Maximum Repetitive Reverse Voltage 100 V VR Maximum DC Reverse Voltage IF(AV) IFSM 100 15(Per Leg) Average Rectified Forward Current, Tc=120C 30(Per Device) Peak Forward Surge Current,8.3ms Half Sine wave 250 V A A Tj Operating Junction Temperature 150 C Tstg Storage Temperature Range -55 to+150 C Thermal Characteristics(Tc=25C unless otherwise noted) Symbol Parameter Max Unit RθJC Thermal Resistance,Junction to Case Per Leg 3.2 C /W Electrical Characteristics(Tc=25C unless otherwise noted) Symbol VRRM Parameter Maximum Repetitive Reverse Voltage IR Reverse Current VF Forward Voltage www.slkormicro.com Test Conditons Min IR=100μA 100 VR =100V Tc=25C VR =100V Tc=125C IF=15A Tc=25C IF=15A Tc=125C IF=30A Tc=25C IF=30A Tc=125C 1 Max Unit V 0.1 5 0.88 0.78 1.05 0.95 mA V MBRF30100CT Typical Performance Characteristics Figure 1. Forward Current Characteristics Figure 2. Reverse Leakage Current Figure 3. Junction Capacitance Figure 4. Power Derating www.slkormicro.com 2 MBRF30100CT TO-220F Package Dimensions SYMBOL A A1 A2 A3 B1 B2 B3 C C1 C2 www.slkormicro.com min 9.80 2.90 9.10 15.40 4.35 6.00 3.00 15.00 8.80 nom 7.00 max 10.60 SYMBOL D D1 D2 D3 E E1 E2 E3 E4 α(度) 3.40 9.90 16.40 4.95 7.40 3.70 17.00 10.80 3 min 1.15 0.60 0.20 2.24 nom 2.54 0.70 UNIT:mm max 1.55 1.00 0.50 2.84 1.0×45° 0.35 2.30 30° 0.65 3.30
MBRF30100CT
1. 物料型号:MBRF30100CT 2. 器件简介:文档中没有提供具体的器件简介,但根据标题“MBRF30100CT Schottky Diodes”,可以推断这是一个肖特基二极管。 3. 引脚分配:文档中没有明确提供引脚分配的详细信息。 4. 参数特性: - 绝对最大额定值:包括最大重复反向电压(VRRM)为100V,最大直流反向电压(VR)为100V,平均整流前向电流(IF(AV))在120°C时每腿15A,每器件30A,峰值前向浪涌电流(IFSM)为250A,工作结温(Tj)为150°C,存储温度范围(Tstg)为-55至+150°C。 - 热特性:结到外壳的热阻(RθJC)每腿最大为3.2°C/W。 - 电气特性:包括最大重复反向电压(VRRM)在100μA时为100V,反向电流(IR)在25°C和125°C时的值,以及在不同条件下的前向电压(VF)。 5. 功能详解:文档提供了正向电流特性图、反向漏电流特性图、结电容特性图和功率降额图。 6. 应用信息:适用于高频开关、自由轮和极性保护应用。 7. 封装信息:提供了TO-220F封装的尺寸信息。
MBRF30100CT 价格&库存
很抱歉,暂时无法提供与“MBRF30100CT”相匹配的价格&库存,您可以联系我们找货
