PJ72AL33SA
PJ72AL33SA
    PJ(平晶)
    SOT-23
    3.3V 200MA 30V
PJ72AL33SA 数据手册
PJ72A Series Low Dropout Regulators Description SOT-23 3.GND The PJ72A series is manufactured using CMOS technology with a maximum input voltage of 24V. This series is a high-voltage linear regulator with multiple fixed output voltages. 1.VOUT Features 2.VIN SOT-23-3 ⚫ High Input Voltage Rating:Up to 24V 3.GND ⚫ Maximum Output Current: 150mA ⚫ Low Dropout : 500mV @ 100mA ⚫ Fixed Output Voltages:3V,3.3V,4V,5V ⚫ Current Limiting Protection ⚫ Thermal Shutdown Protection 1.VOUT ⚫ Available Packages:SOT-23、SOT-23-3、SOT-89、SOT-23-5 2.VIN SOT-89 2.GND Applications ⚫ Battery-Powered Equipment ⚫ Communication device ⚫ Security monitoring equipment 1.VOUT 2.GND 3.VIN SOT-23-5 4. NC 5. NC 1.GND 2.VIN 3.VOUT Functional Pin Description Pin Name NC Pin Function NO Connected GND Ground VOUT Output Voltage VIN www.pingjingsemi.com Revision:2.0 Sep-2021 Power Input Voltage 1/9 PJ72A Series Low Dropout Regulators Ordering Information PJ72- Package Type SA:SOT-23 SC:SOT-23-3 SQ:SOT-89 SE:SOT-23-5 Pin arrangement version number: A Output Voltage 30 : 3.0V 33 : 3.3V 40 : 4.0V 50 : 5.0V Output current tap L : 150mA A:Revision NO. Series NO. Marking Code Note Output Voltage Package Marking Code 3V~5V SOT-23 72XXA 3V~5V SOT-23-3 72XXCA 3V~5V SOT-23-5 72XXEA 3V~5V SOT-89 72XXA Note . XX : Output Voltage Typical Application Circuit PJ72A Series www.pingjingsemi.com Revision:2.0 Sep-2021 2/9 PJ72A Series Low Dropout Regulators Function Block Diagram VIN VOUT Current Limit and Thermal Shutdown Gate Driver R2 + - 1.2V R1 GND Absolute Maximum Ratings Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Value Unit VIN to GND Voltage 30 V VOUT to GND Voltage 15 V Internally limited -- SOT-23 260 mW SOT-23-3 330 mW SOT-23-5 330 mW SOT-89 550 mW SOT-23 380 °C/W SOT-23-3 300 °C/W SOT-23-5 300 °C/W SOT-89 180 °C/W -20 ~ +70 °C 260 °C -50 ~ +125 °C ESD(HBM) 4 KV ESD(CDM) 100 V Output Current Power Dissipation Thermal Resistance,Junction-to-Ambient Operating Ambient Temperature Welding temperature Storage temperature range www.pingjingsemi.com Revision:2.0 Sep-2021 3/9 PJ72A Series Low Dropout Regulators Electrical Characteristics (VIN=VOUT+2, CIN=10µF, COUT=10µF, TA=25℃ , unless otherwise noted.) Parameter Input Voltage Output Current Min. Typ. Max. Unit 3 -- 24 V ∆VOUT -2 -- +2 % -- 150 -- mA IOUT=0mA -- -- 3 μA VOUT=3V, IOUT=100mA -- 500 600 VOUT=3.3V, IOUT=100mA -- 500 700 VOUT=5V, IOUT=100mA -- 500 700 VOUT=3V, IOUT=150mA -- 700 900 VOUT=3.3V, IOUT=150mA -- 800 990 VOUT=5V, IOUT=150mA -- 800 990 IOUT=10mA IOUT Quiescent Current Dropout Voltage Test Conditions VIN Output Voltage Accuracy Dropout Voltage Symbol Note1 Note1 IQ VDROP VDROP mV mV Line Regulation ∆VLINE VIN=VOUT+2 to24V,IOUT=10mA -- 0.15 -- %/V Load Regulation ∆VLOAD 1mA
PJ72AL33SA 价格&库存
很抱歉,暂时无法提供与“PJ72AL33SA”相匹配的价格&库存,您可以联系我们找货
