6CS20000F20UCG
6CS20000F20UCG
    SJK(晶科鑫)
    HC-49S/SMD
    无源晶振 20MHz ±20ppm 20pF -40℃~+85℃
6CS20000F20UCG 数据手册
QUARTZ CRYSTAL UNIT SERIES 6CS/SS, Resistance Welded HC-49S/SSMD Package 深圳市晶科鑫实业有限公司 Shenzhen Crystal Technology Industrial Co., Ltd APPROVAL SHEET CUSTOMER P/N: TYPE: 49S CRYSTAL DESCRIPTION: 49SMD 20.000MHZ P N/ SJK: 6CS20000F20UCG ENVIRONMENTAL: ■RoHS REVISION: MSL: A1 20PF ±20PPM ■REACH ■HF -40~85℃ □PAHS 2014-6-10 □other MOQ: 1000pcs Levels 1 SIGNATURE SUPPLIER Issue Check CUSTOMER Approve QA SJK Signature FAE_EMAIL Date Date Check Approve: □accept Approve □unaccepted Note: Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718 http://www.q-crystal.com ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen 1 /4 QUARTZ CRYSTAL UNIT SERIES 6CS/SS, Resistance Welded HC-49S/SSMD Package 1. FEATURE      Leadless type High precision characteristic covering up to high frequency range Designed for automatic mounting and reflow soldering Embossed taping specification The best choice of Bluetooth wireless communication sets, DSN, PDA and mobile phone 2. ELECTRICAL SPECIFICATIONS Output Frequency Range 20.000000MHz Mode AT/Fundamental Frequency Tolerance ±20 ppm max Load Capacitance(C L ) 20.0 PF Frequency Stability Over Operating Temperature Characteristics (at 25°C) ±30ppm max Operating Temperature Range -40 °C to +85 °C Storage Temperature Range -40 °C to +125 °C Shunt Capacitance (C 0 ) 3.0 PF Max Driver Level (Typical) 100µW Equivalent Series Resistance(ESR) 40Ω Max Aging @25°C 1st year (Max) ±3ppm/year Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718 http://www.q-crystal.com ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen 2 /4 QUARTZ CRYSTAL UNIT SERIES 6CS/SS, Resistance Welded HC-49S/SSMD Package 3. DIMENSION (Units: mm) 4. MARKING 5. REFLOW CONDITION Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718 http://www.q-crystal.com ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen 3 /4 QUARTZ CRYSTAL UNIT SERIES 6CS/SS, Resistance Welded HC-49S/SSMD Package 6. RELIABILITY TEST SPECIFICATION 1.Mechanical Endurance No. Test Item Test Methods REF.DOC 1.1 Drop Test 150 cm height, 3 times on concrete floor. JIS C6701 1.2 Mechanical Shock 1.3 Vibration 1.4 Gross Leak Standard Sample For Automatic Detector, Test Pressure: 2Kg / cm2 1.5 Fine Leak Helium Bombing 4.5 Kg/ cm2 for 2 hr 1.6 Solder ability Device are shocked to half sine wave ( 1000 G ) three mutually perpendicular axes each 3 times. 0.5m sec. duration time Frequency range 10 ~ 2000 Hz Amplitude 1.52 mm/20G Sweep time 20 minute Perpendicular axes each test time 4 hours (Total test time 12 hours) Temperature Immersing depth Immersion time Flux Gross Leak 245 ℃ ± 5℃ 0.5 mm minimum 5 ± 1 seconds Rosin resin methyl alcohol solvent ( 1 : 4 ) MIL-STD-202F MIL-STD-883E MIL-STD-883E MIL-STD-883E MIL-STD-883E 2.Environmental Endurance No. Test Item Test Methods 2.1 Resistance To Soldering Heat Pre-heat temperature Pre-heat time 60 ~ Test temperature Test time 2.2 2.3 High Temp. Storage Low Temp. Storage REF.DOC 125 ℃ 120 sec. 260 ± 5 ℃ 10 ± 1 sec. MIL-STD-202F + 125 ℃ ± 3 ℃ for 500 ± 12 hours MIL-STD-883E - 40 ℃ ± 3 ℃ for 500 ± 12 hours MIL-STD-883E Total 100 cycles of the following temperature cycle 2.4 2.5 2.6 Thermal Shock High Temp &Humidity Pressure Cooker Storage MIL-STD-883E 85℃ ± 3℃, RH 85% , 500Hrs JIS C5023 121 ± 3℃ , RH100% , 2 bar , 240Hrs JIS C6701 Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718 http://www.q-crystal.com ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen 4 /4
6CS20000F20UCG
物料型号: - 类型:49S CRYSTAL - 型号:6CS20000F20UCG
器件简介: - 无铅型号 - 高精度特性,覆盖高频范围 - 适用于自动贴装和回流焊接 - 凸起胶带规格 - 适用于蓝牙无线通信设备、DSN、PDA和手机
引脚分配: - 该文档没有提供具体的引脚分配图,但提到了49SMD封装,通常49SMD封装具有两个引脚。
参数特性: - 输出频率范围:20.000000MHz - 模式:AT/基本模式 - 频率容差:±20 ppm 最大(25°C时) - 负载电容(CL):20.0 PF - 工作温度范围内的频率稳定性:±30ppm 最大 - 工作温度范围:-40 °C至+85°C - 存储温度范围:-40 °C至+125°C - 并联电容(Co):最大3.0 PF - 驱动电平(典型值):100W - 等效串联电阻(ESR):最大40
功能详解: - 该文档主要介绍了石英晶体单元的特性和电气规格,包括其高精度和适用于自动贴装的特性。
应用信息: - 该产品是蓝牙无线通信设备、DSN、PDA和手机的最佳选择。
封装信息: - 封装类型:SMD - 封装高度:4.0±0.2 mm - 其他尺寸信息:文档提供了侧视图和底部视图的尺寸数据。
可靠性测试规范: - 机械耐久性测试:包括跌落测试、机械冲击测试、振动测试、粗漏测试、细漏测试和焊接能力测试。 - 环境耐久性测试:包括耐焊热测试、高温存储、低温存储、热冲击、高温高湿、压力锅存储等。
回流条件: - 预热:160~180°C,120秒 - 主要加热:220°C,60秒 - 峰值:260°C,最多10秒
联系信息: - 电话:0755-88352810-837(Mr.huang) - 传真:0755-88353718 - 网站:http://www.q-crystal.com - 地址:深圳市龙岗区坂田天安云谷一期3C栋1204~1206室
6CS20000F20UCG 价格&库存
很抱歉,暂时无法提供与“6CS20000F20UCG”相匹配的价格&库存,您可以联系我们找货
6CS20000F20UCG
  • 5+0.86940
  • 50+0.69315
  • 150+0.60502
  • 1000+0.51084
  • 2000+0.45792
  • 5000+0.43146
库存:739
6CS20000F20UCG
  • 1+0.41777
  • 100+0.39099
  • 300+0.36421
  • 500+0.33743
  • 2000+0.32404
  • 5000+0.31600
库存:400
