CRYSTAL OSCILLATOR
SERIES 2N, SEAM SEALED CERAMIC 2.5X2.0MM SURFACE MOUNT PACKAGE
深圳市晶科鑫实业有限公司
Shenzhen Crystal Technology Industrial Co., Ltd
APPROVAL SHEE
CUSTOMER P/N:
TYPE:
DESCRIPTION:
P N/ SJK:
SMD CRYSTAL
SMD2520 OSC 32.768KHZ 3.3V
2N000032G33YC
ENVIRONMENTAL: ■RoHS
REVISION:
MSL:
LVCMOS -40~85℃
A1
■REACH
■HF
□PAHS
□other
2017-5-10
Levels 1
SIGNATURE
SUPPLIER
Issue
Check
CUSTOMER
Approve
QA
SJK
Signature
FAE_EMAIL
Date
Date
Check
Approve: □accept
Approve
□unaccepted
Note:
Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718
http://www.q-crystal.com
ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen
1 /5
CRYSTAL OSCILLATOR
1. ELECTRICAL SPECIFICATIONS
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement
and tests are as follow:
Ambient temperature : 25±5℃
Relative humidity : 40%~70%
If there is any doubt about the results, measurement shall be made within the following limits:
Ambient temperature : 25±3℃
Measure equipment
Electrical characteristics measured by MD 37WX-05M or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
Parameters
1
2
SYM
Electrical Spec.
MIN
Nominal Frequency
Frequency
Stability
TYPE
MAX
Notes
UNITS
0.032768
MHZ
AT 25℃
±10
PPM
Over Operating
Temperature range
±20
PPM
3
Operating Temperature
Topr
-40
25
85
4
Storage Temperature
Tstg
-55
125
5
Supply Voltage
VDD
6
Input Current
Icc
7
Enable Control
8
Output Load : CMOS
3.3 / ±10%
V
5
即:32.768KHZ
1.62~3.63
available
uA
Yes
CL
Pad1
15
pF
90%
Vdd
9
Output Voltage High
VoH
10
Output Voltage Low
VoL
10%
Vdd
V
11
Rise Time
Tr
5
ns
12
Fall Time
Tf
5
ns
13
Symmetry (Duty ratio)
TH/T
55
14
Start-up Time
Tosc
10
ms
15
Enable Voltage High
Vhi
16
Disable Voltage Low
Vlo
17
Aging
18
Output Disable Delay Time
T off
150
us
19
Output Enable Delay Time
T on
150
us
Phase Jitter (12KHZ~20MHZ)
1.0
ps
45
V
70%
Vdd
10%→90%VDD
Level
90%→10%VDD
Level
V
30%
Vdd
±3
0.5
V
ppm/yr.
1st. Year at 25℃
2 /5
CRYSTAL OSCILLATOR
2. DIMENSIONS
(Units :mm)
3. MARKING
4. TEST CIRCUIT
Control input (output
enable/disable)
Logic 1 or open on pad 1:
Oscillator output
Logic 0 on pad 1 : Disable
output to high impedance
3 /5
CRYSTAL OSCILLATOR
5. WAVEFORM CONDITIONS
Waveform measurement
system should
have a min. bandwidth of 5
times the
frequency being tested.
6. OUTPUT ENABLE / DISABLE DELAY
The following figure shows the oscillator timing during normal operation . Note that when the device is in
standby,
the oscillator stops. When standby is released, the oscillator starts and stable oscillator output occurs after a
short delay
7. SUGGESTED REFLOW PROFILE
Total time : 200 sec. Max / Solder melting point :220 ℃
4 /5
CRYSTAL OSCILLATOR
8. RELIABILITY TEST SPECIFICATION
1.Mechanical Endurance
No.
Test Item
Test Methods
REF. DOC
1
Drop Test
75 cm height,3 times on concrete floor .
JIS C6701
Device are shocked to half sine wave ( 1000
G ) three mutually
perpendicular axes each 3 times. 0.5m sec.
duration time
Frequency range 10 ~ 2000 Hz
Amplitude 1.52 mm/20G
Sweep time 20 minutes
Perpendicular axes each test time 4 Hrs
(Total test time 12 Hrs)
Standard Sample For Automatic Gross Leak
Detector, Test Pressure: 2kg / cm2
2
Mechanical Shock
3
Vibration
4
Gross Leak
5
Fine Leak
Helium Bomging 4.5 kgf / cm 2 for 2 Hrs
Solderability
Temperature 245 ℃ ± 5℃
Immersing depth 0.5 mm minimum
Immersion time 5 ± 1 seconds
Flux Rosin resin methyl alcohol
solvent ( 1 : 4 )
6
MIL-STD-202F
MIL-STD-883E
MIL-STD-883E
MIL-STD-883E
2.Environmental Endurance
No.
Test Item
1
Resistance To
Soldering Heat
2
3
High Temp.
Storage
Low Temp.
Storage
Test Methods
Pre-heat temperature 125 ℃
Pre-heat time 60 ~ 120 sec.
Test temperature 260 ± 5 ℃
Test time 10 ± 1 sec.
REF. DOC
MIL-STD-202F
+ 125 ℃ ± 3 ℃ for 1000 ± 12 Hrs
MIL-STD-883E
- 40 ℃ ± 3 ℃ for 1000 ± 12 Hrs
Total 100 cycles of the following temperature cycle
4
5
6
Thermal Shock
Pressure Cooker
Storage
High Temp&
Humidity
MIL-STD-883E
121 ± 3℃ , RH100% , 2 bar , 240 Hrs
JIS C6701
85℃ ± 3℃, RH 85% , 1000 Hrs
JIS C5023
备注
5 /5
很抱歉,暂时无法提供与“2N00032G33YC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.58830
- 10+2.85120
- 30+2.48670
- 100+2.12220
- 500+1.90350
- 1000+1.79010
- 国内价格
- 1+4.49820
- 10+3.60640
- 600+2.32260
