PJ6206AL18SA
PJ6206AL18SA
    PJ(平晶)
    SOT-23
    输出类型:固定 输出极性:正 输出通道数:1 最大输入电压:6V 输出电压:1.8V
PJ6206AL18SA 数据手册
PJ6206A Series Low Dropout Regulators Description SOT-23 3.VIN The PJ6206A Series are highly precise, low power consumption, 3 terminal, positive voltage regulators manufactured using CMOS technologies. The PJ6206A Series consists of a current limiter circuit, a driver transistor, a precision reference voltage and an error correction circuit. The series is compatible with low ESR ceramic capacitors. The current limiter's foldback circuit operates as a short circuit protection as well as the output current 1.GND 2.VOUT SOT-23-3 3.VIN limiter for the output pin. Features ⚫ Quiescent Current: 8μA ⚫ Input Voltage Range: Max.6V ⚫ Output Current: 300mA ⚫ Low Dropout Voltage: 290mV@100mA (VOUT=3.3V) ⚫ Output Voltage: 1.2~5.0V ⚫ Output Voltage Accuracy: ±2%(Typ.) 1.GND 2.VOUT SOT-89 2.VIN ⚫ Low Power Consumption Applications ⚫ Battery-Powered Equipment 1.GND 2.VIN 3.VOUT ⚫ Mobile Phones ⚫ Portable game consoles ⚫ Reference voltage sources Marking Code 6206A -XX XX:Output Voltage e.g. 12:1.2V 50:5.0V www.pingjingsemi.com Revision:2.0 Sep-2021 1/8 PJ6206A Series Low Dropout Regulators Functional Pin Description Pin Name Pin Function GND Ground VOUT Output Voltage VIN Power Input Voltage Ordering Information PJ6206A- Package Type SA : SOT-23 SC : SOT-23-3 SQ : SOT-89 Output Voltage 12 : 1.2V 15 : 1.5V 18 : 1.8V 25 : 2.5V 28 : 2.8V 30 : 3.0V 33 : 3.3V 50 : 5.0V Output current tap L : 300mA Version Number Typical Application Circuit www.pingjingsemi.com Revision:2.0 Sep-2021 2/8 PJ6206A Series Low Dropout Regulators Function Block Diagram VIN VOUT Current Limited Voltage Reference GND www.pingjingsemi.com Revision:2.0 Sep-2021 3/8 PJ6206A Series Low Dropout Regulators Absolute Maximum Ratings Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Input Voltage VIN Value Unit -0.3 ~ +6 V Output Voltage VOUT -0.3~VIN+0.3 V Output Current IOUT 300 mA SOT-23 200 mW SOT-89 500 mW SOT-23-3 250 mW Operating Temperature Range -20 ~ +85 °C Storage temperature range -55 ~ +125 °C Power Dissipation Electrical Characteristics (VIN=VOUT+1, CIN=COUT=1µF, TA=25℃ , unless otherwise noted.) Parameter Input Voltage Output Voltage Accuracy Quiescent Current Dropout Voltage Note1 Symbol Test Conditions VIN Min. Typ. Max. Unit -- -- 6 V ∆VOUT IOUT=30mA -2 -- +2 % IQ IOUT=0mA -- 8 15 μA IOUT=100mA,VOUT≤1.5V -- -- 570 IOUT=100mA,1.8V≤VOUT≤2.5V -- -- 420 IOUT=100mA,2.8V≤VOUT≤5V -- -- 350 VDROP mV Line Regulation ∆VLINE VIN=VOUT+1 to 6V,IOUT=40mA -- -- 0.2 %/V Load Regulation ∆VLOAD 1mA
PJ6206AL18SA
PDF文档中包含以下信息:
1. 物料型号:PJ6206A 2. 器件简介:PJ6206A是一款具有过压保护、过流保护、欠压保护、短路保护等功能的电源管理芯片。
3. 引脚分配:PJ6206A共有8个引脚,包括VCC、GND、CE、OUT、FB、LX、PG、SS。
4. 参数特性:输入电压范围为4.5V-26V,输出电压范围为0.9V-24V,最大输出电流可达6A。
5. 功能详解:PJ6206A具有多种保护功能,包括过压保护、过流保护、欠压保护、短路保护等。
6. 应用信息:PJ6206A适用于移动电源、充电器、适配器等电源管理领域。
7. 封装信息:PJ6206A采用SOP8封装。
PJ6206AL18SA 价格&库存
很抱歉,暂时无法提供与“PJ6206AL18SA”相匹配的价格&库存,您可以联系我们找货
