DSK14
DSK14
    YENJI(台湾元基)
    SMF(SOD-123FL)
    肖特基二极管 Single VR=40V IF=1A SOD123FL
DSK14 数据手册
DSK12~DSK120 1.0Amp Surface Mounted Schottky Barrier Rectifiers SOD123FL Features The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 For surface mounted applications Built-in strain relief,ideal for automated placement Low reverse leakage High forward surge current capability High temperature soldering guaranteed 250 C/10 seconds at terminals Mechanical Data Case : Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.0007 ounce, 0.02 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load, for capacitive load current derate by 20%. Parameter SYMBOLS DSK12 DSK14 DSK16 DSK18 DSK110 DSK115 DSK120 UNITS Maximum repetitive peak reverse voltage VRRM 20 40 60 80 100 150 200 V Maximum RMS voltage VRMS 14 28 42 56 70 105 140 V Maximum DC blocking voltage VDC 20 40 60 80 100 150 200 V Maximum average forward rectified current at TL =100 C I(AV) 1.0 A Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load IFSM 30.0 A Maximum instantaneous forward voltage at 1.0A VF Maximum DC reverse current T A =25 C at rated DC blocking voltage TA=125 C Typical thermal resistance Operating junction temperature range Storage temperature range 0.70 0.55 0.85 0.5 50 IR 0.95 0.05 10 85.0 RqJA -55 to +150 TSTG 1/3 mA C/W -55 to +150 -55 to +125 TJ V C C DSK12~DSK120 1.0Amp Surface Mounted Schottky Barrier Rectifiers Ratings And Characteristic Curves FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT PERLEG 35 Peak Forward Surage Current Amperes 1.0 0.9 0.8 Amperes Average Forward Rectified Current FIG. 1- DERATING CURVE OUTPUT RECTIFIED CURRENT 0.7 0.6 0.5 0.4 K12-K16 K18-K120 0.3 0.2 0 20 40 60 80 100 120 140 30 25 20 15 f=60Hz 10 5 1Cycle 0 160 1 10 100 Lead Temperature Number of cycles FIG. 3-TYPICAL FORWARD VOLTAGE CHARACTERISTICS FIG. 4-TYPICAL REVERSE LEAKAGE CHARACTERISTICS 50 100 TJ=25 C INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES K12-K16 K18-K120 10.0 1 0.1 K12-K14 K16 K18-K110 K115-K120 0.01 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 INSTANTANEOUS FORWARD VOLTAGE, VOLTS 10 TJ=100 C 1 0.1 0.01 0.001 0 TJ=25 C 20 40 60 80 100 PERCENT OF PEAK REVERSE VOLTAGE,% Suggested Pad Layout 2/3 Symbol Unit (mm) Unit (inch) A 1.2 0.048 B 1.15 0.045 C 3.10 0.122 D 1.95 0.077 E 4.25 0.167 DSK12~DSK120 1.0Amp Surface Mounted Schottky Barrier Rectifiers Suggested Soldering Temperature Profile Note R ecom m ended reflow m ethods: IR , vap or phase ov en, hot air oven, w ave solder. Th e dev ice can b e exp osed to a m axim um tem p erature of 265 °C for 10 second s. D evices can b e cleaned using standa rd industry m ethods and solvents. If reflow tem peratures exceed the re c o m m e n d e d p ro file , d e v ic e s m a y n o t m e e t th e p e rfo rm a n c e re q u ire m e n ts . Package Information Carrier Dimension(mm) A0 B0 K0 D0 E F 2.15 3.95 1.35 1.55 1.75 3.50 P0 P1 P2 T W Tolerance 4.0 4.0 2.0 0.25 8 0.1 Package Specifications Package Reel Size SOD123FL 7' Reel DIA. (mm) Q'TY/Reel (Kpcs) Box Size (mm) QTY/Box (Kpcs) Carton Size (mm) Q'TY/Carton (Kpcs) 178 3 180 15 380*200*200 150 3/3
DSK14 价格&库存
很抱歉,暂时无法提供与“DSK14”相匹配的价格&库存,您可以联系我们找货
DSK14
  • 50+0.08500
  • 500+0.08000
  • 2000+0.07000
  • 5000+0.06500
  • 15000+0.06000
  • 30000+0.05750
库存:4755
