RC0100FR-0722RL
RC0100FR-0722RL
    YAGEO(国巨)
    贴片电阻 01005 22Ω ±1% 30mW ±200ppm/℃
RC0100FR-0722RL 数据手册
DATA SHEET GENERAL PURPOSE CHIP RESISTORS RC_L series ±0.1%, ±0.5%, ±1%, ±5% Sizes 0075/0100/0201/0402/0603/0805/ 1206/1210/1218/2010/2512 Product specification – May 15, 2020 V.11 RoHS compliant & Halogen free Product specification Chip Resistor Surface Mount SCOPE This specification describes RC series chip resistors with lead free terminations made by thick film process. RC_L SERIES 2 10 0075 to 2512 ORDERING INFORMATION - GLOBAL PART NUMBER Global part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. GLOBAL PART NUMBER RC XXXX X X X XX XXXX L APPLICATIONS  All general purpose application (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0075/0100/0201/0402/0603/0805/1206/1210/1218/2010/2512 FEATURES  Halogen Free Epoxy  RoHS compliant  Products with lead free terminations meet RoHS requirements  Pb-glass contained in electrodes, resistors element and glass are exempted by RoHS  Reducing environmentally hazardous wastes  High component and equipment reliability  Saving of PCB space  None forbidden-materials used in products/production (2) TOLERANCE B = ± 0.1% D = ± 0.5% F = ± 1.0% J = ± 5.0% (for jumper ordering, use code of J) (3) PACKAGING TYPE R = Paper taping reel K = Embossed taping reel S = ESD safe reel (0075/0100 only) (4) TEMPERATURE COEFFICIENT OF RESISTANCE -= Based on spec. (5) TAPING REEL & POWER 07= 7 inch dia. Reel 10=10 inch dia. Reel 13=13 inch dia. Reel 7W = 7 inch dia. Reel & 2 x standard power 7N = 7 inch dia. Reel, ESD safe reel (0075/0100 only) 3W = 13 inch dia. Reel & 2 x standard power (6) RESISTANCE VALUE There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point Example: 97R6 = 97.6Ω 9K76 = 9760Ω 1M = 1,000,000Ω (7) DEFAULT CODE Letter L is the system default code for ordering only. (Note) ORDERING EXAMPLE The ordering code for a RC0402 0.0625W chip resistor value 100KΩwith ±5% tolerance, supplied in 7-inch tape reel of 10,000 units per reel is: RC0402JR-07100KL. NOTE 1. All our RSMD products meet RoHS compliant and Halogen Free. "LFP" of the internal 2D reel label mentions "Lead Free Process". 2. On customized label, "LFP" or specific symbol can be printed. www.yageo.com Jul. 7, 2020 V.11 Product specification Chip Resistor Surface Mount RC_L SERIES 3 10 0075 to 2512 MARKING RC0075 / RC0100 / RC0201 / RC0402 No Marking ynsc007 Fig. 1 RC0603 0 1%, 0.5%,E24 exception values 10/11/13/15/20/75 of E24 series YNSC037 Fig. 2 240 = 24 × 100 = 24 88 YNSC038 1%, 0.5%, E96 refer to EIA-96 marking method, including values 10/11/13/15/20/75 of E24 series Fig. 3 88A = 806 × 100 = 806 Ω 03 YNSC001 5%, E24 series : 3 digits First two digits for significant figure and 3rd digit for number of zeros Fig. 4 Value = 10 KΩ RC0805 / RC1206 / RC1210 / RC2010 / RC2512 00 YNSC004 1%, 0.5%, E24/E96 series : 4 digits First three digits for significant figure and 4th digit for number of zeros Fig. 5 Value = 10 KΩ 03 YNSC001 5%, E24 series : 3 digits First two digits for significant figure and 3rd digit for number of zeros Fig. 6 Value = 10 KΩ RC1218 E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros YNSC099 Fig. 7 Value = 10 KΩ 00 Both E-24 and E-96 series: 4 digits, ± 1% & ± 0.5% First three digits for significant figure and 4th digit for number of zeros YNSC103 Fig. 8 Value = 10 KΩ For further marking information, please see special data sheet "Chip resistors marking". www.yageo.com Jul. 7, 2020 V.11 Product specification Chip Resistor Surface Mount SERIES RC_L 4 10 0075 to 2512 Outlines CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environmental influences. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the two external terminations (matte tin on Ni-barrier) are added, as shown in Fig.9. For dimensions, please refer to Table 1 marking layer overcoat primary glass layer resistive layer (Jumper chip is a conductor) inner electrode termination(Ni/matte tin) inner electrode H ceramic substrate I2 overcoat I1 W YNSC086 L 9 Fig. 9 Chip resistor outlines DIMENSION Table 1 TYPE RC0075 L (mm) W (mm) H (mm) I1 (mm) I2 (mm) 0.30±0.01 0.15±0.01 0.13±0.01 0.08±0.03 0.08±0.03 RC0100 0.40±0.02 0.20±0.02 0.13±0.02 0.10±0.03 0.10±0.03 RC0201 RC0402 0.60±0.03 0.30±0.03 0.23±0.03 0.10±0.05 0.15±0.05 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.25±0.10 RC0603 RC0805 RC1206 1.60±0.10 0.80±0.10 0.45±0.10 0.25±0.15 0.25±0.15 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.35±0.20 3.10±0.10 1.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 RC1210 RC1218 3.10±0.10 2.60±0.15 0.55±0.10 0.45±0.15 0.50±0.20 3.10±0.10 4.60±0.10 0.55±0.10 0.45±0.20 0.40±0.20 RC2010 5.00±0.10 2.50±0.15 0.55±0.10 0.60±0.20 0.50±0.20 RC2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.20 0.50±0.20 ELECTRICAL CHARACTERISTICS Table 2 CHARACTERISTICS POWER OPERATING TEMPERATURE RANGE RC0075 -55℃ to 125℃ 1/50 outlines W Fig. 4 Chip resistor RC0100 1/32 W -55℃ to 125℃ MAXIMUM WORKING VOLTAGE 10V 15V MAXIMUM DIELECTRIC OVERLOAD WITHSTANDING VOLTAGE VOLTAGE 25V 30V 25V 30V RESISTANCE RANGE TEMPERATURE COEFFICIENT JUMPER CRITERIA 5% (E24) 10Ω≦R
RC0100FR-0722RL
物料型号:YAGEO RC_L系列芯片电阻器,提供不同的精度等级(±0.1%, ±0.5%, ±1%, ±5%)和尺寸(从0075到2512)。
器件简介:RC_L系列是使用厚膜工艺制造的无铅端子的芯片电阻器,符合RoHS标准,无卤素,旨在减少对环境有害的废物,提高组件和设备的可靠性,节省PCB空间。
引脚分配:文档中没有明确指出具体的引脚分配图,但通常芯片电阻器为两个端子的配置。
参数特性: - 电阻值范围:从几欧姆到几百兆欧姆。 - 温度系数:根据电阻值的不同,有不同的温度系数。 - 额定功率:不同尺寸的电阻器有不同的功率等级,如1/50W、1/20W、1/16W等。 - 最大工作电压和最大电压:根据尺寸和功率等级有所不同。
功能详解:RC_L系列电阻器广泛应用于各种通用目的,包括但不限于电子设备的信号处理、电源管理等。
应用信息:适用于所有通用目的的应用,包括需要高可靠性和节省空间的场合。
封装信息:提供多种尺寸的封装,从小型的0075到大型的2512,以适应不同的电路设计需求。
订购信息:全球零件编号由系列、尺寸、容差、包装类型、温度系数、胶带卷和电阻值等组成。
标记信息:电阻器的标记方法遵循特定的规则,包括EIA-96标记方法和E24系列值。
电气特性:详细列出了不同尺寸电阻器的电气特性,如功率、工作温度范围、最大工作电压、电阻范围和温度系数。
尺寸信息:提供了详细的尺寸表,包括长度、宽度、高度、内引线间距等。
测试和要求:包括温度系数、耐久性、高温暴露、耐湿性、湿热、热冲击、板弯曲、焊接性和耐焊接热等测试条件和要求。
修订历史:文档记录了自2014年12月首次发布以来的所有修订历史。
RC0100FR-0722RL 价格&库存
很抱歉,暂时无法提供与“RC0100FR-0722RL”相匹配的价格&库存,您可以联系我们找货
RC0100FR-0722RL
    • 1+0.27980
    • 100+0.17130
    • 1000+0.11000
    • 10000+0.07050
    • 20000+0.05020
    库存:99720
    RC0100FR-0722RL
      • 20000+0.1120020000+0.01460
      库存:16000
      RC0100FR-0722RL
        • 1+0.024781+0.00322
        • 10000+0.0247810000+0.00322
        • 20000+0.0165220000+0.00215
        • 30000+0.0165230000+0.00215
        • 40000+0.0165240000+0.00215
        库存:4692
        RC0100FR-0722RL
          RC0100FR-0722RL
          • 1+2.027741+0.26356
          • 10+1.0587010+0.13761
          • 25+0.8435425+0.10964
          • 50+0.7218850+0.09383
          • 100+0.62572100+0.08133
          • 250+0.52845250+0.06869
          • 500+0.47253500+0.06142
          • 1000+0.428041000+0.05564
          • 5000+0.357055000+0.04641
          库存:27045
          RC0100FR-0722RL
          • 20000+0.3391120000+0.04408
          • 40000+0.3252340000+0.04228
          • 60000+0.3184760000+0.04140
          • 100000+0.31112100000+0.04044
          • 140000+0.30692140000+0.03990
          • 200000+0.30295200000+0.03938
          库存:27045
