BAV21W
BAV21W
    SLKOR(萨科微)
    SOD-123
    开关二极管 VR=200V Ir=100nA SOD123
BAV21W 数据手册
BAV19W-BAV21W Surface mount switching diode FEATURES z Fast Switching Speed. z Surface Mount Package Ideally Suited For Automatic Insertion. z For General Purpose Switching Applications. APPLICATIONS SOD-123 z Surface mount fast switching diode. MAXIMUM RATING @ Ta=25℃ unless otherwise specified Characteristic Symbol BAV19W BAV20W BAV21W Unit Non-Repetitive Peak Reverse Voltage VRM 120 200 250 V Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Reverse Voltage VRRM VRWM VR 100 150 200 V RMS Reverse Voltage VR(RMS) 71 106 141 V Average Rectified Output Current Io 200 mA Non-Repetitive Peak Forward Surge Current @t=1.0 μs @t=1.0 s IFSM 2.5 0.5 A Power Dissipation Pd 250 mW Thermal Resistance Junction to Ambient Air RθJA 500 ℃/W Operating and Storage Temperature Rage Tj,TSTG -65 to +150 ℃ www.slkormicro.com 1 BAV19W-BAV21W PACKAGE OUTLINE Characteristic Symbol Reverse Breakdown Voltage BAV19W BAV20W BAV21W V(BR)R Maximum Forward Voltage VF1 VF2 Min Max 120 200 250 1.0 1.25 - Unit Test Condition V IR=100uA V IF=100mA IF=200mA IR - 0.1 μA VR=100V VR=150V VR=200V Junction Capacitance Cj - 5.0 pF VR=0,f=1.0MHz Reverse Recovery Time trr - 50 ns IF=IR=30mA, Irr=0.1×IR,RL=100Ω Reverse Current BAV19W BAV20W BAV21W TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified www.slkormicro.com 2 BAV19W-BAV21W PACKAGE OUTLINE Plastic surface mounted package SOD-123 K SOD-123 B C A D H E J Dim Min Max A 1.4 1.8 B 2.55 2.85 C 1.15 Typical D 0.55 Typical E 0.3 0.4 H 0.02 0.10 J K 0.1 Typical 3.55 3.85 All Dimensions in mm www.slkormicro.com 3
BAV21W 价格&库存
很抱歉,暂时无法提供与“BAV21W”相匹配的价格&库存,您可以联系我们找货
BAV21W
    • 1+0.05680
    库存:55
    BAV21W
    • 50+0.09742
    • 500+0.07701
    • 3000+0.06070
    • 6000+0.05390
    • 24000+0.04796
    • 51000+0.04482
    库存:47
    BAV21W
    • 3000+0.088173000+0.01145
    • 9000+0.071479000+0.00928
    库存:1024
    BAV21W
    • 1+0.886201+0.11502
    • 10+0.2914910+0.03783
    • 50+0.2067150+0.02683
    • 100+0.17831100+0.02314
    • 500+0.12680500+0.01646
    库存:1024
    BAV21W
    • 50+0.08930
    • 600+0.07059
    • 1200+0.06953
    • 3000+0.05564
    库存:2223
