SL54F-SMAF
SL54F-SMAF
    MDD(辰达半导体)
    SMAF
    VR=40V IF=5A 200pF
SL54F-SMAF 数据手册
SL32F THRU SL310F Reverse Voltage - 40 to 60 Volts Forward Current - 2.0 Ampere SURFACE MOUNT SCHOTTKY BARRIER DIODES Features SMAF  7KHSODVWLFSDFNDJHFDUULHV8QGHUZULWHUV/DERUDWRU\ )ODPPDELOLW\&ODVVLILFDWLRQ95R+6FRPSOLDQW 0.106(2.70) 0.094(2.40) 0.063 (1.60) 0.051 (1.30)  , GHDIRUSULQWHGFLUFXLWERDUG  2SHQ-XQFWLRQFKLS  /RZUHYHUVHOHDNDJH +LJKIRUZDUGVXUJHFXUUHQW 0.146(3.70) 0.130(3.30)  FDSDELOLW\ +LJKWHPSHUDWXUHVROGHULQJJXDUDQWHHG  ℃VHFRQGVDWWHUPLQDOV 0.047(1.20) 0.035(0.90) Mechanical Data 0.008(0.20) 0.005(0.12) 0.047(1.20) 0.031(0.80) 0.193(4.90) 0.173(4.40) Case: 60$) molded plastic body Terminals: Solderable per MIL-STD-750,Method 2026 Polarity: Polarity symbol marking on body Mounting Position: Any Weight : 0.0014 ounce, 0.038 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter SL32F SL34F SL36F SL38F SL310F MDD SL32F MDD SL34F MDD SL36F MDD SL38F MDD SL310F VRRM 14 28 42 56 70 VRMS VDC 20 40 60 80 100 20 40 60 80 100 SYMBOLS Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage UNITS V V Maximum average forward rectified current at TL(see fig.1) I(AV) 3.0 A Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) IFSM 70 A Maximum instantaneous forward voltage at 2.0A Maximum DC reverse current at rated DCblocking voltage TA=25℃ TA=125℃ VF CJ RθJA Operating junction temperature range TJ TSTG 0.5 500 mA -55 to +150 ℃/W ℃ 300 88.0 -55 to +125 -55 to +150 V 0.7 0.2 5.0 0.5 10.0 IR Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) Storage temperature range 0.45 pF ℃ Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas DN:T20515A0 http://www.microdiode.com Rev:2020A0 Page :1 SL32F THRU SL310F Reverse Voltage - 40 to 60 Volts Forward Current - 2.0 Ampere FIG. 1- FORWARD CURRENT DERATING CURVE 3.0 P.C.B mounted on 0.2*0.2"(5.0*5.0mm) copper pad areas 2.4 Single Phase Half Wave 60Hz Resistive or inductive Load 1.8 1.2 SL32F-SL36F SL38F-SL310F 0.6 0 0 25 50 75 100 125 150 PEAK FORWARD SURGE CURRENT, AMPERES AVERAGE FORWARD RECTIFIED CURRENT, AMPERES Typical Characterisitics FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 70 56 42 28 14 175 0 8.3ms SINGLE HALF SINE-WAVE 1 10 LEAD TEMPERATURE, C INSTANTANEOUS FORWARD CURRENT,AMPERES TJ=25 C 10.0 1 SL32F-SL34F SL35F-SL36F SL38F-SL310F FIG. 4-TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, MILLIAMPERES FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 50 0.1 100 10 TJ=100 C 1 TJ=75 C 0.1 0.01 TJ=25 C 0.001 0.01 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 100 NUMBER OF CYCLES AT 60 Hz 0 20 40 60 80 100 PERCENT OF PEAK REVERSE VOLTAGE,% 0.9 JUNCTION CAPACITANCE, pF FIG. 5-TYPICAL JUNCTION CAPACITANCE 2000 1000 TJ=25 C 100 SL32F-SL34F SL35F-SL310F TRANSIENT THERMAL IMPEDANCE, C/W INSTANTANEOUS FORWARD VOLEAGE, VOLTS FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE 100 10 1 0.1 0.01 0.1 1 10 100 10 0.1 1.0 10 100 REVERSE VOLTAGE,VOLTS t,PULSE DURATION,sec. The curve above is for reference only. http://www.microdiode.com Rev:2020A0 Page :2 SL32F THRU SL310F Reverse Voltage - 40 to 60 Volts Forward Current - 2.0 Ampere Packing information unit:mm P0 P1 d Item Symbol Tolerance A B C d D D1 D2 E F P P0 P1 T W W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 SMAF D1 E Carrier width Carrier length Carrier depth Sprocket hole 7" Reel outside diameter 7" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width Reel width F B W W1 A P D2 T C D 2.80 4.75 1.42 1.50 178.00 54.40 13.00 1.75 5.05 4.00 4.00 2.00 0.30 8.00 12.30 Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE SMAF REEL SIZE 7" REEL (pcs) COMPONENT SPACING (m/m) BOX (pcs) INNER BOX (m/m) REEL DIA, (m/m) CARTON SIZE (m/m) CARTON (pcs) APPROX. GROSS WEIGHT (kg) 3,000 4.0 6,000 210*208*203 178 400*265*400 120,000 10.0 Suggested Pad Layout Symbol Unit (mm) Unit (inch) A 1.8 0.071 B 0.063 C 1.6 3.8 D 2.2 0.087 E 5.4 0.213 0.150 Important Notice and Disclaimer Microdiode Electronics (Jiangsu) reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,purchase or use. Microdiode Electronics (Jiangsu) makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Microdiode Electronics (Jiangsu) assume any liability for application assistance or customer product design. Microdiode Electronics (Jiangsu) does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Jiangsu). Microdiode Electronics (Jiangsu) products are not authorized for use as critical components in life support devices or systems without express written approval of Microdiode Electronics (Jiangsu). http://www.microdiode.com Rev:2020A0 Page :3
SL54F-SMAF 价格&库存
很抱歉,暂时无法提供与“SL54F-SMAF”相匹配的价格&库存,您可以联系我们找货
SL54F-SMAF
    • 1+0.31720
    • 10+0.30420
