6K632768F06UB
6K632768F06UB
    SJK(晶科鑫)
    DT-26
    无源晶振 50KΩ 6pF ±20ppm 206 -20℃~+70℃ 32.768KHz
6K632768F06UB 数据手册
CRYSTAL RESONANCER SERIES 6K6 / 2X6MM TUNING FORK WATCH CRYSTAL 深圳市晶科鑫实业有限公司 Shenzhen Crystal Technology Industrial Co., Ltd APPROVAL SHEET CUSTOMER P/N: TYPE: DESCRIPTION: P N/ SJK: CRYSTAL 圆柱 JU2*6 32.768KHZ MSL: -40~85℃ 6K632768F06UB ENVIRONMENTAL: ■RoHS REVISION: 12.5PF ±20PPM A1 ■REACH ■HF □PAHS 2015-4-8 □other MOQ:1000pcs/real Levels 1 SIGNATURE SUPPLIER Issue Check CUSTOMER Approve QA SJK Signature FAE_EMAIL Date Date Check Approve: □accept Approve □unaccepted Note: Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718 http://www.q-crystal.com ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen 1 /4 CRYSTAL RESONANCER SERIES 6K6 / 2X6MM TUNING FORK WATCH CRYSTAL 1. FEATURE Small size ⚫ 2. APPLICATIONS ⚫ ⚫ Microprocessor Systems Consumer Electronics 3. ELECTRICAL SPECIFICATIONS Frequency 32.768KHz Frequency Tolerance (at 25°C) ±20 ppm Load Capacitance(CL) 6.0PF ESR 35 KΩ Max Turnover Temperature 25 ± 2°C Frequency Temperature Curve -0.04ppm/°C² MAX Operating Temperature Range -40 °C to +85°C Storage Temperature Range -40 °C to +85 °C Shunt Capacitance (C0) 0.9pF Typ Dynamic Capacitance (C1) 2.0fF Typ Driver Level (Typical) 1 µW Max Insulation Resistance 100MΩ MIN at DC100V±15V Aging @25°C 1st year (Max) ±3ppm/year max REMARK: SPECIFICATIONS SUBJECT TO CHANGE WITHOUT PRIOR NOTICE. PLEASE CONFIRM WITH OUR SALES ENGINEER. Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718 http://www.q-crystal.com ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen 2 /4 CRYSTAL RESONANCER SERIES 6K6 / 2X6MM TUNING FORK WATCH CRYSTAL 4. FREQUENCY VS TEMPERATURE CURVE 5. PACKING AND DIMENSIONS (Units: mm) 6. OSCILLATION CIRCUIT Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718 http://www.q-crystal.com ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen 3 /4 CRYSTAL RESONANCER SERIES 6K6 / 2X6MM TUNING FORK WATCH CRYSTAL 7. Environment-proof ・Mechanical property No Item Specifications Conditions 1 High temperature storage △f/f =±5 × 10-6 After storage under 85℃ for 500 hrs, 1 measure at room temperature. 2 Low temperature storage △f/f =±5 × 10-6 3 High temperature and high △f/f =±5 × 10-6 humidity storage 4 Thermal shock resistance △f/f =±5 × 10-6 5 Mechanical shock resistance △f/f =±5 × 10-6 6 Vibration resistance △f/f =±5 × 10-6 7 Resistance to soldering heat △f/f =±5 × 10-6 8 Tensile strength of lead wire △f/f =±5 × 10-6 9 Bending strength of lead wire △f/f =±5 × 10-6 After storage under -40℃ for 500hrs, measure at room temperature After storage under 60 ℃ ±2 ℃ , 90 to95% RH for 500 hrs, measure at room temperature。 Measured at room temperature after20 cycles. -25℃⇔+80℃ for 30 minutes. Measure after free drop of the RESONATOR three times from the height of 75cm onto a wooden board. Amplitude 1.5mm and 10~60Hz with cycle time 2~3 minutes in 3 direction (X,Y,and Z axis)each for 2 hrs. Measured at room temperature after immersing the lead wire in a soldering bath of 300℃±10℃ for 5 seconds up to a position where it is2mm away from the root of the plug. Apply a load of 500g for 30 seconds in the lead wire's axial direction. Bending cycle : 0゜→ 45゜→ 0゜→ 45゜→ 0゜ Solderability of lead wire A minimum 95% Apply resin-flux contained-solder to a of the area to be soldering iron of 280 ℃ ±5 ℃ for 5 2 coated with seconds. solder 10 Note: 1. The adove tests no. 1 to 9 must be conducted independently (not series tests) 2. *1: Measure after 24 hours soak at room temperature . 3. *2: Measure after 2 hours soak at room temperature . 8. Precautions (1) Temperature for soldering the lead wire shall not exceed 300℃ and the soldering time shall be within 5 seconds. (2) Position to be soldered : Solder only the position where the lead wire is1.0mm away from the glass seal. Do not solder the case. (3) Cutting, bending and correction of lead wire: The glass seal shall be free of any crack or other damage which may deteriorate the characteristics of RESONATORS. Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718 http://www.q-crystal.com ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen 4 /4 1 1 1 2 2 1 2 2
6K632768F06UB
物料型号: - 型号:6K632768F06UB
器件简介: - 产品类型:音叉石英晶振 - 描述:圆柱形JU26 32.768KHZ - 环境要求:符合ROHS和REACH标准
引脚分配: - 该文档没有明确提供引脚分配的具体信息。
参数特性: - 频率:32.768KHz - 频率容差(25°C时):±20 ppm - 负载电容(CL):6.0PF - 等效串联电阻(ESR):最大35 K - 频率温度曲线:最大-0.04ppm/°C² - 工作温度范围:-40°C 至 +85°C - 存储温度范围:-40°C 至 +85°C - 并联电容(C0):典型值0.9pF - 动态电容(C1):典型值2.0fF - 驱动电平(典型值):最大1W - 绝缘电阻:最小100MΩ(DC100V±15V) - 老化(25°C 第一年最大):±3ppm/年
功能详解: - 产品特点:小尺寸 - 应用领域:微处理器系统、消费电子 - 振荡电路公式:C_{L}=\frac{C_{g} × Cd}{C_{g}+Cd}+Cs - 环境和机械特性测试:包括高温存储、低温存储、高温高湿存储、热冲击、机械冲击、振动、焊接热、引线拉伸强度、引线弯曲强度和引线可焊性测试。
应用信息: - 适用于微处理器系统和消费电子产品。
封装信息: - 封装类型:6K6,尺寸参数为A=2.0mm,B=6.0+0.3mm,C=7.0±0.3mm,D=0.7±0.2mm,E=0.2±0.1mm,F=2.0±0.1mm。
6K632768F06UB 价格&库存
很抱歉,暂时无法提供与“6K632768F06UB”相匹配的价格&库存,您可以联系我们找货
6K632768F06UB
  • 1+0.46410
  • 100+0.43435
  • 300+0.40460
  • 500+0.37485
  • 2000+0.35997
  • 5000+0.35105
库存:300
