CRYSTAL RESONANCER
SERIES 6K6 / 2X6MM TUNING FORK WATCH CRYSTAL
深圳市晶科鑫实业有限公司
Shenzhen Crystal Technology Industrial Co., Ltd
APPROVAL SHEET
CUSTOMER P/N:
TYPE:
DESCRIPTION:
P N/ SJK:
CRYSTAL
圆柱 JU2*6 38.000KHZ
MSL:
-40~85℃
6K838000F12UB
ENVIRONMENTAL: ■RoHS
REVISION:
12.5PF ±20PPM
A1
■REACH
■HF
□PAHS
2015-4-8
□other
MOQ:1000pcs/real
Levels 1
SIGNATURE
SUPPLIER
Issue
Check
CUSTOMER
Approve
QA
SJK
Signature
FAE_EMAIL
Date
Date
Check
Approve: □accept
Approve
□unaccepted
Note:
Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718
http://www.q-crystal.com
ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen
1 /4
CRYSTAL RESONANCER
1. FEATURE
Small size
2. APPLICATIONS
Microprocessor Systems
Consumer Electronics
3. ELECTRICAL SPECIFICATIONS
Frequency
38.000KHz
Frequency Tolerance (at 25°C)
±20 ppm
Load Capacitance(CL)
12.5.0PF
ESR
35 KΩ Max
Turnover Temperature
25 ± 2°C
Frequency Temperature Curve
-0.04ppm/°C² MAX
Operating Temperature Range
-40 °C to +85°C
Storage Temperature Range
-40 °C to +85 °C
Shunt Capacitance (C0)
0.9pF Typ
Dynamic Capacitance (C1)
2.0fF Typ
Driver Level (Typical)
1 µW Max
Insulation Resistance
100MΩ MIN at DC100V±15V
Aging @25°C 1st year (Max)
±3ppm/year max
REMARK: SPECIFICATIONS SUBJECT TO CHANGE WITHOUT PRIOR NOTICE. PLEASE CONFIRM
WITH OUR SALES ENGINEER.
2 /4
CRYSTAL RESONANCER
4. FREQUENCY VS TEMPERATURE CURVE
5. PACKING AND DIMENSIONS
(Units: mm)
6. OSCILLATION CIRCUIT
3 /4
CRYSTAL RESONANCER
7. Environment-proof ・Mechanical property
No
Item
Specifications
Conditions
1
High temperature storage
△f/f =±5 × 10-6
After storage under 85℃ for 500 hrs,
1
measure at room temperature.
2
Low temperature storage
△f/f =±5 × 10-6
3
High temperature and high
△f/f =±5 × 10-6
humidity storage
4
Thermal shock resistance
△f/f =±5 × 10-6
5
Mechanical shock resistance
△f/f =±5 × 10-6
6
Vibration resistance
△f/f =±5 × 10-6
7
Resistance to soldering heat
△f/f =±5 × 10-6
8
Tensile strength of lead wire
△f/f =±5 × 10-6
9
Bending strength of lead wire
△f/f =±5 × 10-6
After storage under -40℃ for 500hrs,
After storage under 60 ℃ ±2 ℃ , 90
to95% RH for 500 hrs, measure at
room temperature。
Measured at room temperature after20
cycles. -25℃⇔+80℃ for 30 minutes.
Measure after free drop of the
RESONATOR three times from the
height of 75cm onto a wooden board.
Amplitude 1.5mm and 10~60Hz with
cycle time 2~3 minutes in 3 direction
(X,Y,and Z axis)each for 2 hrs.
immersing the lead wire in a soldering
bath of 300℃±10℃ for 5 seconds up
to a position where it is2mm away from
the root of the plug.
Apply a load of 500g for 30 seconds in
the lead wire's axial direction.
Bending cycle : 0゜→ 45゜→ 0゜→
45゜→ 0゜
Solderability of lead wire
A minimum 95% Apply resin-flux contained-solder to a
of the area to be
soldering iron of 280 ℃ ±5 ℃ for 5 2
coated
with
seconds.
solder
10
Note:
1. The adove tests no. 1 to 9 must be conducted independently (not series tests)
2. *1: Measure after 24 hours soak at room temperature .
3. *2: Measure after 2 hours soak at room temperature .
8. Precautions
(1) Temperature for soldering the lead wire shall not exceed 300℃ and the soldering time
shall be within 5 seconds.
(2) Position to be soldered : Solder only the position where the lead wire is1.0mm away from
the glass seal.
Do not solder the case.
(3) Cutting, bending and
correction of lead wire: The glass seal shall be free of any crack or other damage which may
deteriorate the characteristics
of RESONATORS.
4 /4
1
1
1
2
2
1
2
2
很抱歉,暂时无法提供与“6K838000F12UB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.53494
- 30+0.51662
- 100+0.49830
- 500+0.46166
- 1000+0.44334
- 2000+0.43235
