A30-300
A30-300
    JDTFUSE(集电通)
    PTC_11.4X3MM_TM
    PTC自恢复保险丝 PTC_11.4X3MM_TM 30V 3A
A30-300 数据手册
PRODUCT DATASHEET A30 Series PTC Devices A30 Series PTC Devices Description The JDTFUSE A30 Series radial leaded device is designed to provide overcurrent protection for low voltage (≤30V) applications where space is not a concern and resettable protection is preferred. Features ● Cured, flame retardant epoxy polymer insulating material meets UL 94V-0 requirements ● Fast time-to-trip ● RoHS compliant, Lead-Free and Halogen-Free* Agency Approvals Agency Applications File Number E472196 pending Regulation ● USB hubs, ports and peripherals ● Computers & peripherals ● Motor protection ● General electronics ● Automotive applications Standard 2002/95/EC EN14582 JDT FUSE Industrial Corp. www.jdtfuse.com Page 1/6 A30 Series PTC Devices Performance Specification Model V max (V dc) I max (A) I hold I trip Maximum Time To Trip Pd @25°C (A) @25°C (A) Typ. (W) Resistance Current (A) Time (Sec) R i min R1max (Ω) (Ω) A30-030 30 40 0.30 0.60 0.44 8.00 0.3 0.370 1.080 A30-040 30 40 0.40 0.80 0.45 8.00 0.3 0.250 0.645 A30-050 30 40 0.50 1.00 0.46 8.00 0.3 0.150 0.600 A30-065 30 40 0.65 1.30 0.47 8.00 0.4 0.180 0.450 A30-075 30 40 0.75 1.50 0.48 8.0 0.4 0.100 0.375 A30-090 30 40 0.90 1.80 0.6 4.50 5.9 0.070 0.200 A30-110 30 40 1.10 2.20 0.7 5.50 6.6 0.050 0.170 A30-135 30 40 1.35 2.70 0.8 6.75 7.3 0.070 0.220 A30-160 30 40 1.60 3.20 0.9 8.00 8.0 0.030 0.110 A30-185 30 40 1.85 3.70 1.0 9.25 8.7 0.030 0.090 A30-250 30 40 2.50 5.00 1.2 12.5 10.3 0.020 0.070 A30-300 30 40 3.00 6.00 2.0 15.0 10.8 0.020 0.080 A30-400 30 40 4.00 8.00 2.5 20.0 12.7 0.010 0.050 A30-500 30 40 5.00 10.00 3.0 25.0 14.5 0.010 0.050 A30-600 30 40 6.00 12.00 3.5 30.0 16.0 0.005 0.040 A30-700 30 40 7.00 14.00 3.8 35.0 17.5 0.005 0.030 A30-800 30 40 8.00 16.00 4.0 40.0 18.8 0.005 0.020 A30-900 30 40 9.00 18.00 4.2 40.0 20.0 0.005 0.020 I hold = Hold Current. Maximum current device will not trip in 25°C still air. I trip = Trip Current. Minimum current at which the device will always trip in 25°C still air. V max = Maximum operating voltage device can withstand without damage at rated current (Imax). I max = Maximum fault current device can withstand without damage at rated voltage (V max). Pd = Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage. Ri min/max = Minimum/Maximum device resistance prior to tripping at 25°C. R1max = Maximum device resistance is measured one hour post reflow. CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame. Environmental Specifications Conditions Test Passive aging Humidity aging Thermal shock       Resistance to solvent   Vibration   Resistance change   +85°C, 1000 hrs. ±5% typical   +85°C, 85% R.H. , 168 hours ±5% typical   +85°C to -40°C, 20 times ±33% typical   MIL-STD-202,Method 215 No change MIL-STD-202,Method 201 No change   Ambient operating conditions : - 40 °C to +85 °C Maximum surface temperature of the device in the tripped state is 125 °C JDT FUSE Industrial Corp. www.jdtfuse.com Page 2/6 A30 Series PTC Devices Thermal Derating Curve Derating Curves for A30 Series 180 Percentage of Rated Current 160 140 120 100 80 60 40 20 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 Temperature (°C ) Average Time-Current Curve 1000 TIME IN SECOND 100 10 1 0.1 0.01 1 10 100 0.90A 1.10A 1.35A 1.60A 1.85A 2.50A 3.00A 4.00A 5.00A 6.00A 7.00A 8.00A 9.00A 0.75A 0.65A 0.50A 0.40A 0.30A CURRENT IN AMPERES JDT FUSE Industrial Corp. www.jdtfuse.com Page 3/6 A30 Series PTC Devices Ihold Versus Temperature Maximum ambient operating temperature (Tmao) vs. hold current (Ihold) Model - 40°C - 20°C 0°C 25°C 40°C 50°C 60°C 70°C 85°C A30-030 0.44 0.39 0.35 0.30 0.25 0.23 0.20 0.18 0.16 A30-040 0.58 0.52 0.46 0.40 0.33 0.31 0.27 0.24 0.21 A30-050 0.73 0.65 0.58 0.50 0.42 0.38 0.34 0.31 0.26 A30-065 0.95 0.85 0.75 0.65 0.54 0.50 0.44 0.40 0.34 A30-075 0.00 0.00 0.00 0.75 0.00 0.00 0.00 0.00 0.00 A30-090 1.31 1.17 1.04 0.90 0.75 0.69 0.61 0.55 0.47 A30-110 1.60 1.43 1.27 1.10 0.91 0.85 0.75 0.67 0.57 A30-135 1.96 1.76 1.55 1.35 1.12 1.04 0.92 0.82 0.70 A30-160 2.32 2.08 1.84 1.60 1.33 1.23 1.09 0.98 0.83 A30-185 2.68 2.41 2.13 1.85 1.54 1.42 1.26 1.13 0.96 A30-250 3.63 3.25 2.88 2.50 2.08 1.93 1.70 1.53 1.30 A30-300 4.35 3.90 3.45 3.00 2.49 2.31 2.04 1.83 1.56 A30-400 5.80 5.20 4.60 4.00 3.32 3.08 2.72 2.44 2.08 A30-500 7.25 6.50 5.75 5.00 4.15 3.85 3.40 3.05 2.60 A30-600 8.70 7.80 6.90 6.00 4.98 4.62 4.08 3.66 3.12 A30-700 10.15 9.10 8.05 7.00 5.81 5.39 4.76 4.27 3.64 A30-800 11.60 10.40 9.20 8.00 6.64 6.16 5.44 4.88 4.16 A30-900 13.05 11.70 10.35 9.00 7.47 6.93 6.12 5.49 4.68 Soldering Parameters Temperature (°C ) TP 260 Pre-Heating 1 Minute Min. Soldering 5Sea.MAX Gradual Cooling 100 Profile Feature Average Ramp-Up Rate Pb-Free Assembly 3℃/second mac. (Ts max to T p) Preheat 25 Time Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free Recommended maximum paste thickness is 0.25mm Devices can be cleaned using standard industry methods and solvents. Note 1:All temperature refer to topside of the package, measured on the package body surface. Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements. JDT FUSE Industrial Corp. www.jdtfuse.com -Temperature Min(Ts min) 150℃ -Temperature Max(Ts max) 200℃ -Time(Ts min to Ts max) 60~180 seconds Time maintained above: -Temperature(TL) 217℃ -Time(tL) 60~150 seconds Peak Temperature(Tp) 260℃ Ramp-Down Rate 6℃/second max. Time 25℃ to Peak Temperature 8 minutes max Storage Condition 0℃~35℃,≤70%RH Page 4/6 A30 Series PTC Devices Physical Dimensions(mm.) A A A E E B B D B UF135 = Trademark = Radial type 30 Vrms = 1.35A hold current F D D C a30 C C A B C D E F Max. Max. Max. Max. Max. Max. Lead Style A30-030 7.4/0.29 10.2/0.4 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Straight A30-040 7.4/0.29 11.4/0.45 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Straight A30-050 7.4/0.29 11.4/0.45 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Straight A30-065 7.4/0.29 11.4/0.45 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Straight A30-075 7.4/0.29 11.4/0.45 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Straight A30-090 7.4/0.29 12.2/0.48 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Kink A30-110 7.4/0.29 14.2/0.56 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Kink A30-135 8.9/0.35 13.5/0.53 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Kink A30-160 8.9/0.35 15.2/0.60 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Kink A30-185 10.2/0.40 15.7/0.62 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Kink A30-250 11.4/0.45 18.3/0.72 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Kink A30-300 11.4/0.45 17.3/0.68 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Straight A30-400 14.0/0.55 20.1/0.79 5.1/0.20 7.6/0.3 3.0/0.12 1.2/0.05 Straight A30-500 14.0/0.55 24.9/0.98 10.2/0.40 7.6/0.3 3.0/0.12 1.2/0.05 Straight A30-600 16.5/0.65 24.9/0.98 10.2/0.40 7.6/0.3 3.0/0.12 1.2/0.05 Straight A30-700 19.1/0.75 26.7/1.05 10.2/0.40 7.6/0.3 3.0/0.12 2.0/0.08 Straight A30-800 21.6/0.85 29.2/1.15 10.2/0.40 7.6/0.3 3.0/0.12 2.0/0.08 Straight A30-900 24.1/0.95 29.7/1.17 10.2/0.40 7.6/0.3 3.0/0.12 2.0/0.08 Straight Model PHYSICAL SPECIFICATIONS : Materials : Leads A30-030 ~ 250: Tin-platedcopper-cladsteel,0.205mm2(24AWG),Φ0.51mm(0.020in). A30-300 ~ 900: Tin-plated copper, 0.52mm2 (20AWG), Φ0.81mm(0.032 in). Lead Solderability : MIL-STD-202, Method 208E JDT FUSE Industrial Corp. www.jdtfuse.com Page 5/6 A30 Series PTC Devices Packaging Quantity A30 135 K or S R or U Model Reel QTY Bag QTY Radial type Hold K= Kink leads   A30-030 ~ A30-075 - 500 Current   R=Tape&reel A30-090 ~ A30-250 3000 500 (A) S=Straight U= Bulk A30-300 ~ A30-400 1500 500 leads packaged A30-500 ~ A30-900 - 500 30 V Tape & Reel packaging per EIA468-B standard. Cross Reference Cross Reference Model Tyco / PolySwitch® Bourns / POLY-FUSE® Polytronics / EVERFUSE® A30-030 - - - A30-040 - - - A30-050 - - - A30-065 - - - A30-075 - - - A30-090 RUEF090 MF-R090-0-9 RLD30P090UF A30-110 RUEF110 MF-R110 RLD30P110UF A30-135 RUEF135 MF-R135 RLD30P135UF A30-160 RUEF160 MF-R160 RLD30P160UF A30-185 RUEF185 MF-R185 RLD30P185UF A30-250 RUEF250 MF-R250 RLD30P250UF A30-300 RUEF300 MF-R300 RLD30P300UF A30-400 RUEF400 MF-R400 RLD30P400UF A30-500 RUEF500 MF-R500 RLD30P500UF A30-600 RUEF600 MF-R600 RLD30P600UF A30-700 RUEF700 MF-R700 RLD30P700UF A30-800 RUEF800 MF-R800 RLD30P800UF A30-900 RUEF900 MF-R900 RLD30P900UF “PolySwitch” is a registered trademark of Tyco Electronics. “POLY-FUSE” is a registered trademark of Littelfuse,Inc. “EVERFUSE” is a registered trademark of Polytronics Technology Corp. JDT FUSE Industrial Corp. www.jdtfuse.com Page 6/6
A30-300 价格&库存
很抱歉,暂时无法提供与“A30-300”相匹配的价格&库存,您可以联系我们找货
A30-300
  • 5+0.34649
  • 20+0.31592
  • 100+0.28535
  • 500+0.25477
  • 1000+0.24051
  • 2000+0.23032
A30-300
  • 5+0.55989
  • 50+0.44584
  • 150+0.38881
  • 1000+0.33578
  • 2000+0.30156
  • 5000+0.28445
库存:441
A30-300
  • 10+0.91570
  • 100+0.54620
  • 500+0.38240
  • 1000+0.27310
  • 2000+0.25940
  • 10000+0.24030
库存:1032
