STD10NF06
www.VBsemi.tw
N-Channel 60 V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
60
RDS(on) () Max.
ID (A)
0.073 at VGS = 10 V
18.2
0.085 at VGS = 4.5 V
13.2
Qg (Typ.)
19.8
• TrenchFET® Power MOSFET
• 100 % Rg and UIS Tested
• Material categorization:
For definitions of compliance please see
TO-252
APPLICATIONS
• DC/DC Converters
D
• DC/AC Inverters
• Motor Drives
G
Drain Connected to Tab
G
D
S
S
N-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS (TC = 25 °C, unless otherwise noted)
Parameter
Symbol
Limit
Drain-Source Voltage
VDS
60
Gate-Source Voltage
VGS
± 20
TC = 25 °C
Continuous Drain Current
TC = 70 °C
ID
13.6
IDM
25
Avalanche Current
IAS
15
EAS
11.25
Single Avalanche
L = 0.1 mH
TC = 25 °C
Maximum Power Dissipationa
TA = 25 °Cc
Operating Junction and Storage Temperature Range
PD
V
16.9
Pulsed Drain Current (t = 300 µs)
Energya
Unit
41.7b
2.1
A
mJ
W
TJ, Tstg
- 55 to 150
°C
Symbol
Limit
Unit
RthJA
60
RthJC
3
THERMAL RESISTANCE RATINGS
Parameter
Junction-to-Ambient (PCB Mount)
c
Junction-to-Case (Drain)
Notes:
a. Duty cycle 1 %.
b. See SOA curve for voltage derating.
c. When mounted on 1" square PCB (FR-4 material).
d. Base on TC = 25 °C.
E-mail:China@VBsemi TEL:86-755-83251052
°C/W
STD10NF06
www.VBsemi.tw
SPECIFICATIONS (TJ = 25 °C, unless otherwise noted)
Parameter
Symbol
Test Conditions
Min.
VDS
VGS = 0 V, ID = 250 µA
60
VGS(th)
VDS = VGS, ID = 250 µA
1.0
IGSS
VDS = 0 V, VGS = ± 20 V
Typ.
Max.
Unit
Static
Drain-Source Breakdown Voltage
Gate Threshold Voltage
Gate-Body Leakage
VDS = 60 V, V
Zero Gate Voltage Drain Current
On-State Drain Currenta
Drain-Source On-State Resistancea
Forward Transconductancea
IDSS
GS =
VDS = 60 V, V
GS = 0 V, TJ = 150 °C
gfs
V
nA
1
0 V, TJ = 125 °C
VDS 10 V, VGS = 10 V
RDS(on)
± 250
GS = 0 V
VDS = 60 V, V
ID(on)
3.0
50
µA
250
A
VGS = 10 V, ID = 6.6 A
0.073
VGS = 4.5 V, ID = 6 A
0.083
VDS = 15 V, ID = 6.6 A
25
S
Dynamicb
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Chargec
Qg
Gate-Source Chargec
Qgs
Gate-Drain
Chargec
Gate Resistance
Turn-On Delay Timec
Rise Timec
Fall
Timec
Turn-On Delay Timec
Rise Timec
Turn-Off Delay
Fall Timec
Drain-Source Body Diode Ratings and
19.8
VDS = 30 V, VGS = 10 V, ID = 6.6 A
30
3.6
nC
4.1
f = 1 MHz
td(on)
td(off)
pF
40
Rg
VDD = 30 V, RL = 9.6
ID 5.2 A, VGEN = 10 V, Rg = 1
0.4
2
4
8
16
11
27
tf
5
10
td(on)
38
57
58
87
18
27
8
16
tr
Timec
85
Qgd
tr
Turn-Off Delay Timec
860
VDS = 30 V, VGS = 0 V, f = 1 MHz
td(off)
ID 5.2 A, VGEN = 4.5 V, Rg = 1
tf
Characteristicsb
16.9
Pulsed Current
ISM
25
Forward Voltagea
VSD
Reverse Recovery Time
Peak Reverse Recovery Current
Reverse Recovery Charge
IF = 5.2 A, VGS = 0 V
trr
IRM(REC)
Qrr
ns
TC = 25 °C
IS
Continuous Current
IF = 5.2 A, dI/dt = 100 A/µs
A
0.8
1.5
V
34
51
ns
3
5
A
50
75
nC
Notes:
a. Pulse test; pulse width 300 µs, duty cycle 2 %.
b. Guaranteed by design, not subject to production testing.
c. Independent of operating temperature.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
STD10NF06
www.VBsemi.tw
TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted)
0.10
25
VGS = 10 V thru 7 V
0.09
RDS(on) - On-Resistance (Ω)
ID - Drain Current (A)
VGS = 4 V
15
10
5
0.08
VGS =4.5V
0.07
VGS = 10 V
0.06
VGS = 3 V
1
1.5
0.04
2
10
VDS - Drain-to-Source Voltage (V)
15
Output Characteristics
On-Resistance vs. Drain Current
5
0.15
ID = 6.6 A
3
4
TC = 25 °C
2
1
0.12
TJ = 125 °C
0.09
TJ = 25 °C
0.06
TC = 125 °C
TC = - 55 °C
2
3
0.03
2
4
VGS - Gate-to-Source Voltage (V)
6
8
10
On-Resistance vs. Gate-to-Source Voltage
Transfer Characteristics
10
40
ID = 6.6 A
TC = - 55 °C
TC = 25 °C
30
gfs - Transconductance (S)
4
TC = 125 °C
6
Transconductance
9
12
VDS = 30 V
8
VDS = 15 V
6
VDS = 40 V
4
2
12
18
Qg - Total Gate Charge (nC)
Gate Charge
24
STD10NF06
www.VBsemi.tw
100
2.7
ID = 250 μA
2.4
10
VGS(th) (V)
IS - Source Current (A)
TJ = 150 °C
2.1
1.8
TJ = 25 °C
1
1.5
0.1
1.2
0.0
0.2
0.4
0.6
0.8
1.0
1.2
- 50
- 25
VSD - Source-to-Drain Voltage (V)
50
75
100
125
150
125
150
TJ - Temperature (°C)
Source-Drain Diode Forward Voltage
Threshold Voltage
127
1250
VDS (V) Drain-to-Source Voltage
ID = 250 μA
C - Capacitance (pF)
1000
Ciss
750
500
250
122
117
112
107
Coss
Crss
102
60
80
- 50
100
50
75
100
Capacitance
Drain Source Breakdown vs. Junction Temperature
15
1.8
1.35
RDS(on) - On-Resistance (Normalized)
- 25
10
5
0.9
- 50
- 25
50
75
100
125
TJ - Junction Temperature (°C)
On-Resistance vs. Junction Temperature
150
50
75
100
TC - Case Temperature (°C)
Current Derating
125
150
STD10NF06
www.VBsemi.tw
100
Limited by RDS(on)*
10
TJ = 25 °C
IDAV (A)
10
100 μs
1 ms
1
10 ms
DC, 10 s 1 s, 100 ms
0.1
TJ = 150 °C
TC = 25 °C
Single Pulse
1
BVDSS Limited
0.01
0.000001
0.00001
0.0001
0.001
0.01
0.1
Time (s)
Single Pulse Avalanche Current Capability vs. Time
1
10
100
* VGS > minimum VGS at which RDS(on) is specified
Safe Operating Area
2
Normalized Effective Transient
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.1
0.02
0.05
Single Pulse
0.01
10-4
10-3
10-2
10-1
Square Wave Pulse Duration (s)
1
Normalized Thermal Transient Impedance, Junction-to-Case
10
30
STD10NF06
www.VBsemi.tw
TO-252AA Case Outline
E
C2
L3
H
D
b2
D1
e1
E1
L
gage plane height (0.5 mm)
e
L5
L4
b
C
A1
DIM.
MIN.
MAX.
MIN.
MAX.
A
2.18
2.38
0.086
0.094
A1
0.127
0.005
b
0.64
0.88
0.025
0.035
b2
0.76
1.14
0.030
0.045
b3
4.95
5.46
0.195
0.215
0.024
C
0.46
0.61
0.018
C2
0.46
0.89
0.018
0.035
D
5.97
6.22
0.235
0.245
D1
4.10
0.161
E
6.35
6.73
0.250
0.265
E1
4.32
0.170
H
9.40
10.41
0.370
0.410
e
2.28 BSC
e1
0.090 BSC
4.56 BSC
0.180 BSC
L
1.40
1.78
0.055
0.070
L3
0.89
1.27
0.035
0.050
L4
1.02
0.040
L5
1.01
1.52
0.040
0.060
ECN: T16-0236-Rev. P, 16-May-16
DWG: 5347
Notes
• Dimension L3 is for reference only.
INCHES
MILLIMETERS
A
b3
STD10NF06
www.VBsemi.tw
RECOMMENDED MINIMUM PADS FOR DPAK (TO-252)
0.224
0.243
0.087
(2.202)
0.090
(2.286)
0.420
(10.668)
0.180
0.055
(4.572)
(1.397)
Recommended Minimum Pads
Dimensions in Inches/(mm)
Return to Index
(6.180)
(5.690)
STD10NF06
www.VBsemi.tw
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives ( collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to
the product.(www.VBsemi.tw)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: ( 1) any application and all liability arising out of or use of any products; ( 2) any and all liability,
including but not limited to special, consequential damages or incidental ; ( 3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
R oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 R i Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.tw)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
