STS4DPF30L
www.VBsemi.tw
Dual P-Channel 30-V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
- 30
ID (A)d, e
RDS(on) (Ω)
0.029 at VGS = - 10 V
- 7.3
0.039 at VGS = - 4.5 V
- 6.3
• Halogen-free
• TrenchFET® Power MOSFET
• 100 % UIS Tested
Qg (Typ.)
17 nC
RoHS
COMPLIANT
APPLICATIONS
• Load Switches
S1
S2
SO-8
S1
1
8
D1
G1
2
7
D1
S2
3
6
D2
G2
4
5
D2
G1
Top View
G2
D1
D2
P-Channel MOSFET
P-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS TA = 25 °C, unless otherwise noted
Parameter
Drain-Source Voltage
Gate-Source Voltage
Continuous Drain Current (TJ = 150 °C)
Symbol
VDS
VGS
TC = 25 °C
TC = 70 °C
TA = 25 °C
TA = 70 °C
V
- 7.0e
- 7.3a, b
- 5.9a, b
- 32e
- 4.1
ID
TC = 25 °C
TA = 25 °C
IS
Avalanche Current
Single-Pulse Avalanche Energy
L = 0.1 mH
IAS
EAS
Maximum Power Dissipation
TC = 25 °C
TC = 70 °C
TA = 25 °C
TA = 70 °C
PD
- 2.0a, b
- 20
3.2
2.5a, b
1.6a, b
- 55 to 150
TJ, Tstg
Operating Junction and Storage Temperature Range
Unit
- 7.3e
IDM
Pulsed Drain Current
Continuous Source-Drain Diode Current
Limit
- 30
± 20
A
mJ
W
°C
THERMAL RESISTANCE RATINGS
Parameter
Maximum Junction-to-Ambienta, c
Maximum Junction-to-Foot
t ≤ 10 s
Steady State
Symbol
RthJA
RthJF
Typical
38
Maximum
50
25
Unit
°C/W
Notes:
a. Surface mounted on 1" x 1" FR4 board.
b. t = 10 s.
c. Maximum under Steady State conditions is 85 °C/W.
d. Based on TC = 25 °C.
e. Limited by package.
E-mail:China@VBsemi TEL:86-755-83251052
1
STS4DPF30L
www.VBsemi.tw
SPECIFICATIONS TJ = 25 °C, unless otherwise noted
Parameter
Symbol
Test Conditions
Min.
VDS
VGS = 0 V, ID = - 250 µA
- 30
Typ.
Max.
Unit
Static
Drain-Source Breakdown Voltage
VDS Temperature Coefficient
ΔVDS/TJ
VGS(th) Temperature Coefficient
ΔVGS(th)/TJ
ID = - 250 µA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = - 250 µA
Gate-Source Leakage
IGSS
VDS = 0 V, VGS = ± 20 V
Zero Gate Voltage Drain Current
IDSS
On-State Drain Currenta
ID(on)
Drain-Source On-State Resistancea
Forward Transconductancea
RDS(on)
gfs
Dynamicb
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Gate Resistance
Rg
Turn-On Delay Time
Rise Time
Turn-Off DelayTime
Fall Time
Turn-On Delay Time
Rise Time
Turn-Off DelayTime
Fall Time
mV/°C
4.5
- 1.0
- 3.0
V
± 100
nA
VDS = - 30 V, VGS = 0 V
-1
VDS = - 30 V, VGS = 0 V, TJ = 55 °C
-5
VDS ≥ - 10 V, VGS = - 10 V
VGS = - 10 V, ID = - 6.3 A
- 30
0.040
VDS = - 10 V, ID = - 6.1 A
23
Ω
S
1350
VDS = - 15 V, VGS = 0 V, f = 1 MHz
215
pF
185
VDS = - 15 V, VGS = - 10 V, ID = - 6.1 A
32
50
15
25
VDS = - 15 V, VGS = - 4.5 V, ID = - 6.1 A
4
f = 1 MHz
5.8
10
VDD = - 15 V, RL = 15 Ω
ID ≅ - 1 A, VGEN = - 10 V, Rg = 1 Ω
Ω
15
8
15
70
tf
12
25
td(on)
42
70
tr
td(off)
nC
7.5
45
td(off)
µA
A
0.035
VGS = - 4.5 V, ID = - 6.2 A
td(on)
tr
V
- 31
ID ≅ - 1 A, VGEN = - 4.5 V, Rg = 1 Ω
tf
35
60
40
70
16
30
ns
Drain-Source Body Diode Characteristics
Continous Source-Drain Diode Current
IS
Pulse Diode Forward Current
ISM
Body Diode Voltage
VSD
Body Diode Reverse Recovery Time
trr
Body Diode Reverse Recovery Charge
Qrr
Reverse Recovery Fall Time
ta
Reverse Recovery Rise Time
tb
TC = 25 °C
- 4.1
- 32
IS = - 2 A, VGS = 0 V
IF = - 2 A, dI/dt = 100 A/µs, TJ = 25 °C
A
- 0.75
- 1.2
V
34
60
ns
22
40
nC
11
23
ns
Notes:
a. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 %.
b. Guaranteed by design, not subject to production testing.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
2
STS4DPF30L
www.VBsemi.tw
TYPICAL CHARACTERISTICS 25 C, unless otherwise noted
1.0
VGS = 10 thru 5 V
12
0.8
TC = - 55 °C
I D - Drain Current (A)
16
VGS = 4 V
8
4
0.6
0.4
TC = 25 °C
0.2
VGS = 3 V
TC = 125 °C
0.5
1.0
1.5
0.0
0.0
2.0
0.5
VDS - Drain-to-Source Voltage (V)
1.0
2.0
2.5
3.0
VGS - Gate-to-Source Voltage (V)
Output Characteristics
Transfer Characteristics
0.09
2400
0.07
1800
C - Capacitance (pF)
R DS(on) - On-Resistance (Ω)
1.5
VGS = 4.5 V
0.05
VGS = 10 V
Ciss
1200
600
0.03
Coss
Crss
6
ID - Drain Current (A)
12
24
30
On-Resistance vs. Drain Current
Capacitance
10
1.8
ID = - 6 . 1 A
ID = - 6 . 3 A
8
VDS = 15 V
6
VDS = 7.5 V
VDS = 22.5 V
4
1.5
(Normalized)
18
1.2
VGS = 10 V
0.9
2
VGS = 4.5 V
18
27
Qg - Total Gate Charge (nC)
Gate Charge
36
0.6
- 50
- 25
50
75
100
125
150
TJ - Junction Temperature (°C)
On-Resistance vs. Junction Temperature
3
STS4DPF30L
www.VBsemi.tw
TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted
100
0.10
10
0.08
I S - Source Current (A)
ID = - 6 . 3 A
TJ = 150 °C
TJ = 25 °C
1
0.1
TJ = - 50 °C
0.01
0.06
TJ = 125 °C
0.04
0.02
TJ = 25 °C
0.001
0.0
0.00
0.2
0.4
0.6
0.8
1.0
1.2
6
8
VSD - Source-to-Drain Voltage (V)
Source-Drain Diode Forward Voltage
On-Resistance vs. Gate-to-Source Voltage
0.6
10
100
80
0.4
ID = 250 µA
0.2
Power (W)
VGS(th) Variance (V)
2
ID = 1 mA
60
40
0.0
- 50
- 25
50
75
100
125
150
0.01
TJ - Temperature (°C)
0.1
1
10
Time (s)
Threshold Voltage
Single Pulse Power, Junction-to-Ambient
100
Limited by RDS(on)*
10
100 µs
1 ms
1
10 ms
100 ms
0.1
10 s
1 s, DC
TA = 25 °C
Single Pulse
0.01
0.1
BVDSS Limited
1
10
100
* VGS > minimum VGS at which RDS(on) is specified
Safe Operating Area
4
STS4DPF30L
www.VBsemi.tw
15
12
9
Package Limited
6
3
50
75
100
125
150
TC - Case Temperature (°C)
6.0
2.0
4.8
1.6
3.6
1.2
Power (W)
Power (W)
Current Derating*
2.4
0.8
0.4
1.2
0.0
0.0
50
75
100
125
150
50
75
100
125
TA - Ambient Temperature (°C)
Power, Junction-to-Foot
Power Derating, Junction-to-Ambient
150
* The power dissipation PD is based on TJ(max) = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper
dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package
limit.
5
STS4DPF30L
www.VBsemi.tw
1
Normalized Effective Transient
Thermal Impedance
Duty Cycle = 0.5
0.2
0.1
Notes:
0.1
PDM
0.05
t1
t2
1. Duty Cycle, D =
0.02
t1
t2
2. Per Unit Base = RthJA = 85 °C/W
3. TJM - TA = PDM Z thJA(t)
4. Surface Mounted
Single Pulse
0.01
10-4
10-3
10-2
10 -1
1
10
100
1000
Square Wave Pulse Duration (s)
Normalized Thermal Transient Impedance, Junction-to-Ambient
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10-4
10-3
10-2
10 -1
1
10
Normalized Thermal Transient Impedance, Junction-to-Foot
6
STS4DPF30L
www.VBsemi.tw
SOIC (NARROW): 8-LEAD
JEDEC Part Number: MS-012
8
6
7
5
E
1
3
2
H
4
S
h x 45
D
C
0.25 mm (Gage Plane)
A
e
B
All Leads
q
A1
L
0.004"
MILLIMETERS
INCHES
DIM
Min
Max
Min
Max
A
1.35
1.75
0.053
0.069
A1
0.10
0.20
0.004
0.008
B
0.35
0.51
0.014
0.020
C
0.19
0.25
0.0075
0.010
D
4.80
5.00
0.189
0.196
E
3.80
4.00
0.150
e
0.101 mm
1.27 BSC
0.157
0.050 BSC
H
5.80
6.20
0.228
0.244
h
0.25
0.50
0.010
0.020
L
0.50
0.93
0.020
0.037
q
0°
8°
0°
8°
S
0.44
0.64
0.018
0.026
ECN: C-06527-Rev. I, 11-Sep-06
DWG: 5498
7
STS4DPF30L
www.VBsemi.tw
RECOMMENDED MINIMUM PADS FOR SO-8
0.172
(4.369)
0.028
0.022
0.050
(0.559)
(1.270)
0.152
(3.861)
0.047
(1.194)
0.246
(6.248)
(0.711)
Recommended Minimum Pads
Dimensions in Inches/(mm)
8
STS4DPF30L
www.VBsemi.tw
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives ( collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to
the product.(www.VBsemi.tw)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: ( 1) any application and all liability arising out of or use of any products; ( 2) any and all liability,
including but not limited to special, consequential damages or incidental ; ( 3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
R oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 R i Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.tw)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
9
