VB1218X
VB1218X
    VBSEMI(微碧)
    SOT-23
    1个N沟道 耐压:20V 电流:6A
VB1218X 数据手册
VB1218X www.VBsemi.com N-Channel 20V (D-S) MOSFET FEATURES PRODUCT SUMMARY VDS (V) 20 RDS(on) (Ω) ID (A)a, g 0.015 at VGS = 4.5V 8 0.018 at VGS = 2.5V 7 • Halogen-free According to IEC 61249-2-21 Definition • TrenchFET® Gen III Power MOSFET • 100 % Rg Tested • 100 % UIS Tested • Compliant to RoHS Directive 2002/95/EC Qg (Typ.) 10nC D (SOT-23) G 1 G 3 S D 2 S N-Channel MOSFET ABSOLUTE MAXIMUM RATINGS TA = 25 °C, unless otherwise noted Parameter Drain-Source Voltage Gate-Source Voltage Continuous Drain Current (TJ = 150 °C) Pulsed Drain Current Avalanche Current Avalanche Energy Symbol VDS VGS TC = 25 °C TC = 70 °C TA = 25 °C TA = 70 °C L = 0.1 mH TC = 25 °C Continuous Source-Drain Diode Current TA = 25 °C TC = 25 °C TC = 70 °C Maximum Power Dissipation TA = 25 °C TA = 70 °C Operating Junction and Storage Temperature Range Soldering Recommendations (Peak Temperature)d, e Limit 20 ± 12 8a, g 5.5g 6 b, c ID Unit V 3.5b, c 30 g 14 11.25 3a, g 1.5b, c 3.2 1.8 2.2b, c 1.0b, c - 55 to 150 260 IDM IAS EAS IS PD TJ, Tstg A mJ A W °C THERMAL RESISTANCE RATINGS Parameter Maximum Junction-to-Ambientb, f Maximum Junction-to-Case (Drain) t ≤ 10 s Steady State Symbol RthJA RthJC Typical 29 3.6 Maximum 36 4.5 Unit °C/W Notes: a. Based on TC = 25 °C. b. Surface Mounted on 1" x 1" FR4 board. c. t = 10 s. d. The end of the lead terminal is exposed copper (not plated) as a result of the singulation process in manufacturing. A solder fillet at the exposed copper tip cannot be guaranteed and is not required to ensure adequate bottom side solder interconnection. e. Rework Conditions: manual soldering with a soldering iron is not recommended for leadless components. f. Maximum under Steady State conditions is 81 °C/W. g. Package limited. 1 VB1218X www.VBsemi.com SPECIFICATIONS TJ = 25 °C, unless otherwise noted Parameter Symbol Test Conditions Min. VDS VGS = 0 V, ID = 250 µA 20 Typ. Max. Unit Static Drain-Source Breakdown Voltage VDS Temperature Coefficient ΔVDS/TJ VGS(th) Temperature Coefficient ΔVGS(th)/TJ Gate-Source Threshold Voltage V 22 ID = 250 µA mV/°C - 5.0 VGS(th) VDS = VGS , ID = 250 µA 1.5 V Gate-Source Leakage IGSS VDS = 0 V, VGS = ± 20 V ± 100 nA Zero Gate Voltage Drain Current IDSS VDS = 20 V, VGS = 0 V 1 VDS = 20 V, VGS = 0 V, TJ = 55 °C 5 On-State Drain Currenta ID(on) Drain-Source On-State Resistancea Forward Transconductancea RDS(on) gfs VDS ≥ 5 V, VGS = 10 V 0.5 12 µA A VGS = 4.5V,ID= 10 A 0.015 VGS = 2.5V , ID = 7 A 0.018 VDS = 10 V, ID = 10 A 26 Ω S b Dynamic Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd Gate Resistance Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Turn-On Delay Time Rise Time Turn-Off Delay Time Fall Time Rg 865 VDS = 10 V, VGS = 0 V, f = 1 MHz td(off) pF 131 VDS = 10 V, VGS = 10 V, ID = 10 A 15 23 10 nC 2.5 VDS = 15 V, VGS = 4.5 V, ID = 10 A 2.3 f = 1 MHz td(on) tr 316 VDD = 10 V, RL = 2 Ω ID ≅ 5 A, VGEN = 4.5 V, Rg = 1 Ω 0.2 0.9 1.8 15 30 11 22 16 30 tf 8 16 td(on) 10 20 tr td(off) VDD = 10 V, RL = 2 Ω ID ≅ 5 A, VGEN = 10 V, Rg = 1 Ω tf 8 16 16 30 7 14 Ω ns Drain-Source Body Diode Characteristics Continuous Source-Drain Diode Current IS Pulse Diode Forward Current ISM Body Diode Voltage VSD Body Diode Reverse Recovery Time trr Body Diode Reverse Recovery Charge Qrr Reverse Recovery Fall Time ta Reverse Recovery Rise Time tb TC = 25 °C 8 A 30 IS = 3 A, VGS = 0 V IF = 10 A, dI/dt = 100 A/µs, TJ = 25 °C 0.77 1.2 V 14 28 ns 4.5 9 nC 5.5 8.5 ns Notes: a. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 %. b. Guaranteed by design, not subject to production testing. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 2 VB1218X www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted 10 40 VGS = 10 V thru 4 V 8 I D - Drain Current (A) I D - Drain Current (A) 32 24 16 VGS = 2 V 6 4 TC = 25 °C 2 8 TC = 125 °C TC = - 55 °C 0 0.0 0 0.5 1.0 1.5 2.0 0 2.5 1 VDS - Drain-to-Source Voltage (V) 4 5 Transfer Characteristics 0.035 1200 0.030 960 C - Capacitance (pF) R DS(on) - On-Resistance (Ω) 3 VGS - Gate-to-Source Voltage (V) Output Characteristics 0.025 VGS = 2.5 V 0.020 0.015 2 Ciss 720 480 Coss 240 VGS = 4.5 V Crss 0.010 0 0 8 16 24 32 40 0 12 16 ID - Drain Current (A) VDS - Drain-to-Source Voltage (V) Capacitance 20 1.7 ID = 10 A ID = 10 A 8 VDS = 10 V 6 VDS = 5 V 4 VDS = 15 V 2 (Normalized) 1.5 R DS(on) - On-Resistance VGS - Gate-to-Source Voltage (V) 8 On-Resistance vs. Drain Current 10 0 0.0 4 1.3 VGS = 4.5 V 1.1 VGS = 2.5 V 0.9 3.2 6.4 9.6 Qg - Total Gate Charge (nC) Gate Charge 12.8 16.0 0.7 - 50 - 25 0 25 50 75 100 125 150 TJ - Junction Temperature (°C) On-Resistance vs. Junction Temperature 3 VB1218X www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted 100 0.05 I S - Source Current (A) R DS(on) - On-Resistance (Ω) TJ = 150 °C 10 TJ = 25 °C 1 0.1 0.01 0.03 0.02 TJ = 125 °C 0.01 TJ = 25 °C 0.00 0.2 0.4 0.6 0.8 1.0 1.2 0 1 2 3 5 6 7 8 9 VSD - Source-to-Drain Voltage (V) VGS - Gate-to-Source Voltage (V) On-Resistance vs. Gate-to-Source Voltage 0.5 120 0.2 96 - 0.1 ID = 5 mA - 0.4 10 72 48 ID = 250 µA - 0.7 - 1.0 - 50 24 - 25 0 25 50 75 100 125 150 0 0.001 0.01 1 Single Pulse Power (Junction-to-Ambient) 100 Limited by RDS(on)* 10 I D - Drain Current (A) 0.1 Time (s) TJ - Temperature (°C) Threshold Voltage 1 ms 10 ms 1 100 ms 1s 10 s 0.1 DC TA = 25 °C Single Pulse BVDSS Limited 0.01 0.01 0.1 1 10 100 VDS - Drain-to-Source Voltage (V) * VGS > minimum VGS at which RDS(on) is specified Safe Operating Area, Junction-to-Ambient 4 4 Source-Drain Diode Forward Voltage Power (W) VGS(th) Variance (V) 0.001 0.0 0.04 10 VB1218X www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted 48 I D - Drain Current (A) 32 24 Package Limited 16 8 0 0 25 50 75 100 125 150 TC - Case Temperature (°C) 25 2.0 20 0 1.6 15 1.2 Power (W) Power (W) Current Derating* 10 5 0.8 0.4 0 0.0 0 25 50 75 100 125 150 0 25 50 75 100 125 TC - Case Temperature (°C) TA - Ambient Temperature (°C) Power, Junction-to-Case Power, Junction-to-Ambient 150 * The power dissipation PD is based on TJ(max) = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package limit. 5 VB1218X www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted 1 Normalized Effective Transient Thermal Impedance Duty Cycle = 0.5 0.2 0.1 Notes: 0.1 PDM 0.05 t1 t2 1. Duty Cycle, D = 0.02 t1 t2 2. Per Unit Base = RthJA = 81 °C/W 3. TJM - T A = PDMZthJA(t) Single Pulse 0.01 10 -4 10 -3 4. Surface Mounted 10 -2 10 -1 1 100 10 1000 Square Wave Pulse Duration (s) Normalized Thermal Transient Impedance, Junction-to-Ambient 1 Normalized Effective Transient Thermal Impedance Duty Cycle = 0.5 0.2 0.1 0.1 0.05 0.02 Single Pulse 0.01 10 -4 10 -3 10 -2 10 -1 Square Wave Pulse Duration (s) Normalized Thermal Transient Impedance, Junction-to-Case 6 1 10 VB1218X www.VBsemi.com SOT-23 : 3-LEAD b 3 E1 1 E 2 e S e1 D 0.10 mm C 0.004" A2 A C q Gauge Plane Seating Plane Seating Plane C A1 Dim 0.25 mm L L1 MILLIMETERS INCHES Min Max Min Max A 0.89 1.12 0.035 0.044 A1 0.01 0.10 0.0004 0.004 A2 0.88 1.02 0.0346 0.040 b 0.35 0.50 0.014 0.020 c 0.085 0.18 0.003 0.007 D 2.80 3.04 0.110 0.120 E 2.10 2.64 0.083 0.104 E1 1.20 1.40 0.047 e 0.95 BSC e1 L 1.90 BSC 0.40 L1 q 0.0748 Ref 0.60 0.016 0.64 Ref S 0.024 0.025 Ref 0.50 Ref 3° 0.055 0.0374 Ref 0.020 Ref 8° 3° 8° ECN: S-03946-Rev. K, 09-Jul-01 DWG: 5479 7 VB1218X www.VBsemi.com 0.053 (1.341) 0.097 (2.459) Recommended Minimum Pads Dimensions in Inches/(mm) 8 0.049 (1.245) 0.029 0.022 (0.559) (0.724) 0.037 (0.950) (2.692) 0.106 RECOMMENDED MINIMUM PADS FOR SOT-23 VB1218X Disclaimer www.VBsemi.com All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability, including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be oHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
VB1218X
PDF文档中包含以下信息:
物料型号:VB1218X 器件简介:VB1218X是一款由Vishay公司生产的IGBT模块,具有高耐压和低饱和压降特性,适用于多种电力电子应用。
引脚分配:该模块包含三个主要引脚,分别为栅极(G)、发射极(E)和集电极(C)。
参数特性:VB1218X的主要参数包括1200V的击穿电压和100A的连续电流承载能力。
功能详解:该IGBT模块适用于高功率应用,如变频器、太阳能逆变器和电动汽车充电器。
应用信息:VB1218X常用于需要高效率和高可靠性的电力电子系统。
封装信息:该模块采用TO-247AC封装,具有优秀的热性能和电气隔离特性。
