SM1210RGB
SM1210RGB
    BIVAR
    LED指示灯 三色 红色,翠绿色,蓝色(RGB) 1210 共阳极 正贴
SM1210RGB 数据手册
SURFACE MOUNT LED RED/GREEN/BLUE, 1210 PACKAGE SM1210RGB ♦ ♦ ♦ ♦ ♦ ♦ Industry Standard Package RoHS Compliant Three Chips in One Package Water Clear Lens Wide Viewing Angle Ideal for Status Indication and Lighting Bivar Surface Mount 1210 package RGB LED combines three chips in a single package. They are ideal for small scale applications where multiple signals need to be displayed. Wide variety of colors can be created by simply mixing the three chips in different combinations. Bivar offers water clear LED lens for high luminous intensity and wide viewing angles making them suitable for lighting and display applications. The SM1210 RGB LED is packaged in standard tape and reels for pick and place assemblies. Part Number SM1210RGB Material Emitted Color Peak Wavelength λp(nm) TYP. AlGaInP RED 645 InGaN BLUE 468 GaN GREEN 523 Lens Appearance Luminous Intensity (mcd) TYP. Viewing Angle 72 Water Clear 130° 72 285 Outline Dimensions Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. ATTENTION OBSERVE PRECAUTIONS FOR HANDLING ELECTROSTATIC SENSITIVE DEVICES RoHS Compliant Moisture Sensitivity Level 4 Bivar reserves the right to make changes at any time without notice. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/09 Page 1 of 5 3mm (T1) Package LEDs SURFACE MOUNT Discrete LED AMBER RED/GREEN/BLUE, 1210 PACKAGE Absolute Maximum Ratings TA = 25°C unless otherwise noted Red - 78 mW Blue, Green - 84 mW Power Dissipation Forward Current ( DC ) Peak Forward Current 25 mA 1 100 mA Reverse Voltage 5V Operating Temperature Range -30 ~ +80°C Storage Temperature Range -40 ~ +85°C Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2 Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec. 260°C 2. Solder time less than 5 seconds at temperature extreme. Electrical / Optical Characteristics TA = 25°C & I F = 20 mA unless otherwise noted Part Number SM1210RGB Recommend Forward Current (mA) Forward Voltage (V)1 Emitted color Reverse Current (μA) Dominant Wavelength (nm)2 Luminous Intensity Iv (mcd) Viewing Angle 2Ө½ (deg) MIN TYP MAX MIN TYP MAX MAX MIN TYP MAX MIN TYP MAX TYP RED / 2.1 2.6 / 20 / 10 / 631 / 45 72 / 130 BLUE / 2.9 4.2 / 20 / 10 / 470 / 45 72 / 130 GREEN / 3.1 4.2 / 20 / 10 / 525 / 180 285 / 130 Notes: 1. Tolerance of forward voltage : ±0.05V. 2. Tolerance of dominant wavelength : ±1.0nm. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/09 Page 2 of 5 3mm (T1) Package LEDs SURFACE MOUNT Discrete LED AMBER RED/GREEN/BLUE, 1210 PACKAGE Typical Electrical / Optical Characteristics TA = 25°C unless otherwise noted Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/09 Page 3 of 5 3mm (T1) Package LEDs SURFACE MOUNT Discrete LED AMBER RED/GREEN/BLUE, 1210 PACKAGE Recommended Soldering Conditions Tape and Reel Dimensions Note: 3000 pcs/Reel Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance: ±0.010" unless otherwise noted. Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A. Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com Revision A 03/09 Page 4 of 5 3mm (T1) Package LEDs SURFACE MOUNT Discrete LED AMBER RED/GREEN/BLUE, 1210 PACKAGE Outline Drawings Notes: 1. All dimensions are in inches [millimeters]. 2. Standard tolerance unless otherwise noted: X.XXX ± 0.010" X.X ± 0.1” Packaging and Labeling Plan Note: 1 Reel / Bag Sealed ESD and Moisture Barrier Bag Internal Quality Control Label X.XXX Humidity Indicator Card X.XXX Desiccant Bivar Standard Packaging Label Bivar reserves the right to Bivar make reserves changes the at any time in order to improve design and to supply right to make changes at any time without notice. the best product possible. Bivar, Bivar, Inc. Inc. — —4 4 Thomas, Thomas, Irvine, Irvine, California California 92618, 92618, U.S.A. U.S.A. Phone: Phone: (949) (949) 951-8808 951-8808 Fax: Fax: (949) (949) 951-3974 951-3974 E-mail: E-mail: bivar@bivar.com bivar@bivar.com Web: Web: www.bivar.com www.bivar.com Rev. A A 01/16/08 Revision 03/09 Page Page 4 5 of of 4 5
SM1210RGB 价格&库存
很抱歉,暂时无法提供与“SM1210RGB”相匹配的价格&库存,您可以联系我们找货
SM1210RGB
  • 3000+21.825663000+2.83630
SM1210RGB
  • 3000+20.29073
SM1210RGB
  • 1+37.055061+4.81540
  • 10+27.3426510+3.55325
  • 100+21.57345100+2.80353
  • 500+19.04669500+2.47517
  • 1000+18.224811000+2.36836
库存:3046
