KH-252515-G2.1
KH-252515-G2.1
    KINGHELM(金航标)
    SMD
    射频和同轴连接器 立贴 接口类型:内孔 50Ω 6GHz 接口直径:2.1mm
KH-252515-G2.1 数据手册
Product specification DOC. No.: 651-0163-01 P/N: KH-252515-G2.1 Rev.: C Approved/Date Approved/Date Henry Henry 06/01/18’ 06/01/18’ Page: 1/6 Initiated/Date SAM 06/01/18’ 1、Scope This product is applied to RF circuits and provides a switch interface for circuit tests . And it’s the second type of the “MINI RF CONNECTOR”,with excellent performance and less space occupation. 2、Technology Parameters 2.1 2.2 2.3 2.4 2.5 Voltage Rating 250VAC 1A Current Rating DC~6GHz Frequency Range Impedance 50Ω Operating Temperature -40℃~+85℃ 3、Electrical Characteristics 3.1 Insulation Resistance 500MΩ  3.2 Dielectric Withstanding Voltage 300V AC 3.3 Contact Resistance 120 mΩ max 1.2 max ( DC~3GHz), 1.3 max ( 3~6GHz) 3.4 Voltage Standing wave Ratio(VSWR) 3.4.1 Test Method: 3.5 Isolation 20dBmin ( DC~3GHz), 15dBmin ( 3~6GHz) 3.5.1 Test Method: 3.6 Insertion Loss 0.10dBmax ( DC~3GHz), 0.20dBmax ( 3~6GHz) 3.6.1 Test Method: WWW.BDS666.COM 0755-83044319 Product specification P/N: KH-252515-G2.1 DOC. No.: 651-0163-01 Rev.: C Approved/Date Approved/Date Henry Henry 06/01/18’ 06/01/18’ Page: 2/6 Initiated/Date SAM 06/01/18’ 4、Mechanical Characteristics 4.1 4.2 4.3 4.4 4.5 Contact Retention Force 3.4N~4.5N Mating Force 30N or less Unmating Force 5N~40N Mechanical Durability 500 Cycles Adhered Force of Solder 50N 4.5.1 Test method: 2 4.6 Shock Acceleration:750m/s (peak-to-peak). Period:6m sec. Waveform:Half-sine. 4.7 Vibration Frequncy Range:10Hz~30Hz Amplitude: 3mm. 5、Environmental Characteristics 5.1 High Temperature Cycling 50 5.2 Humidity,Steady State: Temperature:60℃ Humidity:95% RH Period:96 hours 5.3 Salt Spray Temperature:35℃ Solution Conduction:5% , Period:48 hours WWW.BDS666.COM 075583044319 Product specification P/N: KH-252515-G2.1 DOC. No.: 651-0163-01 Rev.: C Approved/Date Approved/Date Henry Henry 06/01/18’ 06/01/18’ Page: 3/6 Initiated/Date SAM 06/01/18’ 6、SMT Soldering Condition 6.1 Recommanded IR Temperature & Time Curve 6.2 IR Extreme Temperature & Time Curve ( ( 7、Profile Dimensions WWW.BDS666.COM 0755-83044319 Product specification P/N: KH-252515-G2.1 DOC. No.: 651-0163-01 Rev.: C Approved/Date Approved/Date Henry Henry 06/01/18’ Page: 4/6 Initiated/Date SAM 06/01/18’ 06/01/18’ 8、Printed Circuit Board(PCB)Pad Recomend PCB Layout General Tolerance: ±0.05 The standard solder stencil mask pattern (Mask thickness 0.12mm) 9、Package Specification 9.1 Peeling off Force of Cover Tape When cover tape is peeled off as in right figure by a speed of 300mm/minute.The peeling off force should be 1.3N maximum. 9.2 THE WAY OF PACKAGE :TAPE PACKING,1000Pcs/REEL(Ф178mm) DIRECTION OF USING EMPTY CARRIER EMPTY CARRIER COVER TAPE COMPONENTS 10、Storage Conditions Temperature:-10~+40 ℃ Relative Humidity:15~85 % RH Life:Half year. WWW.BDS666.COM 0755-83044319 Product specification P/N: KH-252515-G2.1 DOC. No.: 651-0163-01 Rev.: C Approved/Date Approved/Date Henry Henry 06/01/18’ 06/01/18’ Page: 5/6 Initiated/Date SAM 06/01/18’ 11、Accessories for Tests Type I : Type II : WWW.BDS666.COM 0755-83044319 Product specification DOC. No.: 651-0163-01 P/N: KH-252515-G2.1 Rev.: C Approved/Date Approved/Date Henry Henry 06/01/18’ Page: 6/6 Initiated/Date SAM 06/01/18’ 06/01/18’ 12、Test Plan ITEMS Test NO. 3.1 3.2 Test Group Test Items Insulation Resistance Withstanding Voltage A 1,5 2 2,6 Contact Resistance 3,12 3.4 VSWR 4,13 3.5 Insulation 5,14 3.6 Insertion Loss 6,15 4.2 Insertion Force 7,10 4.3 Unmating Force 8,11 4.5 Mechanical Durability Adhered Force of Solder C 1 3.3 4.4 B 1,4 E F G 5 5 H I J 1,3 9 1 4.6 Shock 2 4.7 Vibration 3 5.1 High Temperature Cycling 3 5.2 Humidity 4 5.3 Salt Spray The least quantity of the Specimens. D 2 5 5 5 5 5 WWW.BDS666.COM 0755-83044319
KH-252515-G2.1 价格&库存
很抱歉,暂时无法提供与“KH-252515-G2.1”相匹配的价格&库存,您可以联系我们找货
