WSD3067DN56
WSD3067DN56
    WINSOK(微硕)
    DFN-8(5x6)
    1个N沟道和1个P沟道漏源电压(Vdss):30/-30V 连续漏极电流(Id):24/-19.8A 功率(Pd):18.9W
WSD3067DN56 数据手册
WSD3067DN56 N-Ch and P-Channel MOSFET Product Summery General Description The WSD3067DN56 is the highest performance trench N-ch and P-ch MOSFET with extreme high cell density , which provide excellent RDSON and gate charge for most of the synchronous buck converter applications . The WSD3067 meet the RoHS and Green Product requirement 100% EAS guaranteed with full function reliability approved. BVDSS RDSON ID 30V 15mΩ 24A -30V 11mΩ -19.8A Applications z Synchronous Rectification. z Motor Control. z High Current, High Speed Switching. Features z Protable equipment application. z Advanced high cell density Trench technology DFN5X6C-8 Pin Configuration z Super Low Gate Charge z Excellent CdV/dt effect decline z 100% EAS Guaranteed z Green Device Available Absolute Maximum Ratings Rating Symbol Parameter N-Ch P-Ch Units VDS Drain-Source Voltage 30 -30 V VGS Gate-Source Voltage ±20 ±20 V Continuous Drain Current, VGS @ 10V 24 -19.8 A ID@TC=100℃ Continuous Drain Current, VGS @ 10V 15 -12.6 A IDM@TA=25℃ Pulsed Drain Current 36 -30.4 A mJ ID@TC=25℃ EASa 8.5 18 IAS Avalanche Current 13 -19 A PD@TC=25℃ Total Power Dissipation 18.9 18.9 W TSTG Storage Temperature Range -55 to 150 -55 to 150 ℃ TJ Operating Junction Temperature Range -55 to 150 -55 to 150 ℃ Single Pulse Avalanche Energy (L=0.1mH) Thermal Data Symbol Parameter Max. Unit RθJA Thermal Resistance Junction-Ambient 1 Typ. --- 95 ℃/W RθJC Thermal Resistance Junction-Case1 --- 45 ℃/W Note a:Pulse width limited by max. junction temperature. Note b:Surface mounted on 1in2 pad area. Note c:UIS tested and pulse width limited by ma ximum junction temperature 150 oC (initial temperature Tj=25o C) www.winsok.tw Page 1 Rev 1: Apr.2019 WSD3067DN56 N-Ch and P-Channel MOSFET Electrical Characteristics (TJ=25 ℃, unless otherwise noted) Symbol BVDSS Parameter Drain-Source Breakdown Voltage △BVDSS/△TJ BVDSS Temperature Coefficient RDS(ON)d VGS(th) Static Drain-Source On-Resistance2 Gate Threshold Voltage Conditions Min. Typ. Max. Unit VGS=0V , ID=250uA 30 --- --- V Reference to 25℃ , ID=1mA --- 0.034 --- V/℃ VGS=10V , ID=8A --- 15 20 VGS=4.5V , ID=6A --- 18 23 1.3 1.8 2.5 V --- -5.64 --- mV/℃ VDS=20V , VGS=0V , TJ=25℃ --- --- 1 VDS=20V , VGS=0V , TJ=55℃ --- --- 5 VGS=VDS , ID =250uA mΩ △VGS(th) VGS(th) Temperature Coefficient IDSS Drain-Source Leakage Current IGSS Gate-Source Leakage Current VGS=±20V , VDS=0V --- --- ±100 nA Gate Resistance VDS=0V , VGS=0V , f=1MHz --- 3.3 4.2 Ω --- 8.3 --- --- 1.1 --- --- 1.8 --- Rg Qg e Total Gate Charge Qgse Gate-Source Charge Qgde Gate-Drain Charge Td(on) e Tre Td(off)e Tfe Cisse Coss e Crsse VDS=20V , VGS=4.5V , ID=8A --- 5.5 --- Rise Time VDD=12V , VGS=10V , RG=3.3Ω --- 10.5 --- Turn-Off Delay Time ID=6A --- 15 --- Fall Time --- 3.7 --- Input Capacitance --- 395 --- --- 105 --- --- 42 --- Turn-On Delay Time Output Capacitance VDS=15V , VGS=0V , f=1MHz Reverse Transfer Capacitance uA nC ns pF Diode Characteristics Symbol Min. Typ. Max. Unit Continuous Source Current VG=VD=0V , Force Current --- --- 3.0 A VSDd Diode Forward Voltage VGS=0V , IS=1A , TJ=25℃ --- --- 1.0 V trr Reverse Recovery Time --- 11 --- nS Qrr Reverse Recovery Charge --- 3.5 --- nC IS Parameter Conditions IF=4A , dI/dt=100A/µs , TJ=25℃ Note d:Pulse test ; pulse width£300ms, duty cycle£2%. Note e:Guaranteed by design, not subject to production testing. www.winsok.tw Page 2 Rev 1: Apr.2019 WSD3067DN56 N-Ch and P-Channel MOSFET P-Channel Electrical Characteristics (TJ=25 ℃, unless otherwise noted) Symbol BVDSS Parameter Drain-Source Breakdown Voltage △BVDSS/△TJ BVDSS Temperature Coefficient RDS(ON)d Static Drain-Source On-Resistance2 VGS(th) Gate Threshold Voltage △VGS(th) VGS(th) Temperature Coefficient IDSS Drain-Source Leakage Current IGSS Min. Typ. Max. Unit VGS=0V , ID=-250uA Conditions -30 --- -- V Reference to 25℃ , ID=-1mA --- -0.022 --- V/℃ VGS=-10V , ID=-6A --- 11 14 VGS=-4.5V , ID=-4A --- 15 20 -1.3 -1.8 -2.5 V --- 4.6 --- mV/℃ VGS=VDS , ID =-250uA VDS=-24V , VGS=0V , TJ=25℃ --- --- -1 VDS=-24V , VGS=0V , TJ=55℃ --- --- -5 Gate-Source Leakage Current VGS=±20V , VDS=0V --- --- e Gate Resistance VDS=0V , VGS=0V , f=1MHz --- 12 ±100 ----- e Total Gate Charge (-4.5V) --- 8 --- --- 2 --- --- 4 --- --- 9 --- Rg Qg Qgse Gate-Source Charge Qgde Gate-Drain Charge Td(on) e VDS=-15V , VGS=-4.5V , ID=-6A Turn-On Delay Time Rise Time VDD=-15V , VGS=-10V , RG=3.3Ω, --- 11 --- Turn-Off Delay Time ID=-6A --- 55 --- Fall Time --- 34 --- Cisse Input Capacitance --- 750 --- Cosse Output Capacitance --- 140 --- Crsse Reverse Transfer Capacitance --- 102 --- e Tr Td(off)e Tfe VDS=-15V , VGS=0V , f=1MHz mΩ uA nA Ω nC ns pF Diode Characteristicse Symbol Min. Typ. Max. Unit Continuous Source Current VG=VD=0V , Force Current --- --- -6.5 A VSD Diode Forward Voltage VGS=0V , IS=-1A , TJ=25℃ --- --- -1.2 V trr Reverse Recovery Time --- 17 --- nS Qrr Reverse Recovery Charge --- 9 --- nC IS Parameter Conditions IF=-7A , dI/dt=100A/µs , TJ=25℃ Note d:Pulse test ; pulse width£300ms, duty cycle£2%. Note e:Guaranteed by design, not subject to production testing. www.winsok.tw Page 3 Rev 1: Apr.2019 WSD3067DN56 N-Ch and P-Channel MOSFET N-Channel Typical Characteristics Drain Current 21 28 18 24 15 20 ID - Drain Current (A) Ptot - Power (W) Power Dissipation 12 9 6 3 16 12 8 4 o 0 o TC=25 C 0 20 40 60 0 80 100 120 140 160 0 20 40 60 80 100 120 140 160 TJ - Junction Temperature (°C) TJ- Junction Temperature (°C) Safe Operation Area Thermal Transient Impedance 300 Normalized Transient Thermal Resistance 3 100 ID - Drain Current (A) TC=25 C,VG=10V it im )L n o s( Rd 100ms 10 300ms 1ms 10ms 1 DC o TC=25 C 0.1 0.1 1 10 0.2 0.1 0.1 0.05 0.02 0.01 0.01 1E-3 Single Pulse o 1E-4 1E-6 100 VDS - Drain - Source Voltage (V) www.winsok.tw Duty = 0.5 1 RqJC :6.6 C/W 1E-5 1E-4 1E-3 0.01 0.1 0.5 Square Wave Pulse Duration (sec) Page 4 Rev 1: Apr.2019 WSD3067DN56 N-Ch and P-Channel MOSFET N-Channel Typical Characteristics Output Characteristics Drain-Source On Resistance 48 40 VGS=4.5,5,6,7,8,9,10V 4V 24 3.5V 16 40 RDS(ON) - On - Resistance (W) ID - Drain Current (A) 32 8 3V 2.5V 0 0.0 0.5 1.0 1.5 2.0 2.5 16 8 0 5 10 15 20 25 Transfer Characteristics Gate Threshold Voltage 1.6 Normalized T hreshold Voltage RDS(ON) - On - Resistance (mW) VGS=10V ID - Drain Current (A) 60 50 40 30 20 3 4 5 6 7 8 9 30 IDS=250mA 1.4 1.2 1.0 0.8 0.6 0.4 -50 -25 10 VGS - Gate - Source Voltage (V) www.winsok.tw 24 0 3.0 IDS=9A 2 VGS=4.5V VDS - Drain-Source Voltage (V) 70 10 32 0 25 50 75 100 125 150 TJ - Junction Temperature (°C) Page 5 Rev 1: Apr.2019 WSD3067DN56 N-Ch and P-Channel MOSFET N-Channel Typical Characteristics Source-Drain Diode Forward Drain-Source On Resistance 30 1.8 VGS =10V IDS =9A o Tj=150 C 10 1.4 IS - Source Current (A) Normalized On Resistance 1.6 1.2 1.0 0.8 1 o Tj=25 C 0.6 o RON@Tj=25 C: 18.5mW 0.4 -50 -25 0 25 50 0.1 0.0 75 100 125 150 0.8 1.0 Capacitance Gate Charge VDS=15V 9 I =4A DS VGS - Gate - source Voltage (V) Ciss 400 350 300 250 200 150 1.2 10 Frequency=1MHz 450 C - Capacitance (pF) 0.6 VSD - Source - Drain Voltage (V) 500 Coss Crss 50 0 0.4 TJ - Junction Temperature (°C) 550 100 0.2 8 7 6 5 4 3 2 1 0 5 10 15 20 0 0.0 25 3.0 4.5 6.0 7.5 9.0 QG - Gate Charge (nC) VDS - Drain - Source Voltage (V) www.winsok.tw 1.5 Page 6 Rev 1: Apr.2019 WSD3067DN56 N-Ch and P-Channel MOSFET N-Channel Typical Characteristics Power Dissipation Drain Current 21 24 18 20 -ID - Drain Current (A) Ptot - Power (W) 15 12 9 6 16 12 8 4 3 o o 0 TC=25 C 0 20 40 60 0 20 40 60 80 100 120 140 160 TJ- Junction Temperature (°C) TJ - Junction Temperature (°C) Safe Operation Area Thermal Transient Impedance Normalized Transient Thermal Resistance 300 100 -ID - Drain Current (A) 0 80 100 120 140 160 TC=25 C,VG=-10V it m Li ) on s( Rd 100ms 10 300ms 1ms 10ms 1 o TC=25 C 1 10 0.2 0.1 0.1 0.05 0.02 0.01 0.01 Single Pulse o 1E-4 1E-6 100 -VDS - Drain - Source Voltage (V) www.winsok.tw Duty = 0.5 1 1E-3 DC 0.1 0.1 3 RqJC :6.6 C/W 1E-5 1E-4 1E-3 0.01 0.1 0.5 Square Wave Pulse Duration (sec) Page 7 Rev 1: Apr.2019 WSD3067DN56 N-Ch and P-Channel MOSFET P-Channel Typical Characteristics Output Characteristics 30 Drain-Source On Resistance 60 VGS=-4.5,-5,-6,-7,-8,-9,-10V -4V 50 RDS(ON) - On - Resistance (W) -ID - Drain Current (A) 25 20 -3.5V 15 10 -3V 5 0 -2.5V 0 1 2 3 4 30 VGS=-10V 20 10 0 5 VGS=-4.5V 40 0 5 -VDS - Drain - Source Voltage (V) 1.6 IDS=-7A 25 30 IDS=-250mA 1.4 Normalized Threshold Voltage RDS(ON) - On - Resistance (mW) 20 Gate Threshold Voltage 100 80 60 40 20 0 15 -ID - Drain Current (A) Transfer Characteristics 120 10 2 3 4 5 6 7 8 9 1.0 0.8 0.6 0.4 0.2 -50 -25 10 -VGS - Gate - Source Voltage (V) www.winsok.tw 1.2 0 25 50 75 100 125 150 TJ - Junction Temperature (°C) Page 8 Rev 1: Apr.2019 WSD3067DN56 N-Ch and P-Channel MOSFET P-Channel Typical Characteristics Drain-Source On Resistance 1.8 30 VGS = -10V IDS = -7A 1.6 10 1.4 -IS - Source Current (A) Normalized On Resistance Source-Drain Diode Forward 1.2 1.0 0.8 o Tj=150 C o Tj=25 C 1 0.6 o RON@Tj=25 C: 24mW 0.4 -50 -25 0 25 50 0.1 0.0 75 100 125 150 Gate Charge VDS=-15V 9 I =-7A DS -VGS - Gate - source Voltage (V) C - Capacitance (pF) 800 Ciss 700 600 500 400 300 200 Coss Crss 5 1.5 10 900 8 7 6 5 4 3 2 1 10 15 20 0 0 25 3 6 9 12 15 18 QG - Gate Charge (nC) -VDS - Drain - Source Voltage (V) www.winsok.tw 1.2 Capacitance Frequency=1MHz 0 0.9 -VSD - Source - Drain Voltage (V) 1000 0 0.6 TJ- Junction Temperature (°C) 1100 100 0.3 Page 9 Rev 1: Apr.2019 WSD3067DN56 N-Ch and P-Channel MOSFET Avalanche Test Circuit and Waveforms N Channel VDS L tp VDSX(SUS) DUT VDS IAS RG VDD VDD IL tp EAS 0.01W tAV P Channel VDS tAV L DUT EAS VDD RG VDD IAS tp IL VDS 0.01W tp VDSX(SUS) Switching Time Test Circuit and Waveforms N Channel VDS RD VDS DUT RG 90% VGS VDD 10% VGS tp td(on) tr P Channel td(off) tf VDS RD td(on) tr DUT RG td(off) tf VGS 10% VGS VDD tp 90% VDS www.winsok.tw Page 10 Rev 1: Apr.2019 WSD3067DN56 N-Ch and P-Channel MOSFET DFN5×6C-8 OUTLINE 0.15MAX 0.254 0.95±0.1 3.475±0.2 0.60±0.2 1.70±0.2 1.70±0.2 5.55±0.1 6.05±0.2 0.95±0.1 5.2±0.1 0.3 1.29±0.2 1.27 NAME DFN5X6C-8 OUTLINE DWGNO VERSION www.winsok.tw Ver.B UNIT mm DESIGNED PAGE 1 OF 1 CHECKED ISSUE DATE THIRD ANGLE SYSTEM APPROVED Page 11 Rev 1: Apr.2019 Attention 1,AnyandallWinsokpowerproductsdescribedorcontainedhereindonothavespecificationsthatcanhandle applicationsthatrequireextremelyhighlevelsofreliability,suchaslifeͲsupportsystems,aircraft'scontrolsystems,or otherapplicationswhosefailurecanbereasonablyexpectedtoresultinseriousphysicaland/ormaterialdamage.  ConsultwithyourWinsokpowerrepresentativenearestyoubeforeusinganyWinsokpowerproductsdescribedor containedhereininsuchapplications. 2,Winsokpowerassumesnoresponsibilityforequipmentfailuresthatresultfromusingproductsatvaluesthatexceed,  evenmomentarily,ratedvalues(suchasmaximumratings,operatingconditionranges,orotherparameters)listedin productsspecificationsofanyandallWinsokpowerproductsdescribedorcontainedherein. 3,SpecificationsofanyandallWinsokpowerproductsdescribedorcontainedhereinstipulatetheperformance, characteristics,andfunctionsofthedescribedproductsintheindependentstate,andarenotguaranteesofthe performance,characteristics,andfunctionsofthedescribedproductsasmountedinthecustomer’sproductsor equipment.Toverifysymptomsandstatesthatcannotbeevaluatedinanindependentdevice,thecustomershouldalways evaluateandtestdevicesmountedinthecustomer’sproductsorequipment. 4,WinsokpowerSemiconductorCO.,LTD.strivestosupplyhighͲqualityhighͲreliabilityproducts.However,anyandall semiconductorproductsfailwithsomeprobability.Itispossiblethattheseprobabilisticfailurescouldgiverisetoaccidents oreventsthatcouldendangerhumanlivesthatcouldgiverisetosmokeorfire,orthatcouldcausedamagetoother property.Whendesigningequipment,adoptsafetymeasuressothatthesekindsofaccidentsoreventscannotoccur.Such measuresincludebutarenotlimitedtoprotectivecircuitsanderrorpreventioncircuitsforsafedesign,redundantdesign, andstructuraldesign. 5,IntheeventthatanyorallWinsokpowerproducts(includingtechnicaldata,services)describedorcontainedhereinare controlledunderanyofapplicablelocalexportcontrollawsandregulations,suchproductsmustnotbeexportedwithout obtainingtheexportlicensefromtheauthoritiesconcernedinaccordancewiththeabovelaw. 6,Nopartofthispublicationmaybereproducedortransmittedinanyformorbyanymeans,electronicormechanical, includingphotocopyingandrecording,oranyinformationstorageorretrievalsystem,orotherwise,withouttheprior writtenpermissionofWinsokpowerSemiconductorCO.,LTD. 7,Information(includingcircuitdiagramsandcircuitparameters)hereinisforexampleonly;itisnotguaranteedfor volumeproduction. Winsokpowerbelievesinformationhereinisaccurateandreliable,butnoguaranteesaremadeor impliedregardingitsuseoranyinfringementsofintellectualpropertyrightsorotherrightsofthirdparties. 8,Anyandallinformationdescribedorcontainedhereinaresubjecttochangewithoutnoticeduetoproduct/technology improvement,etc.Whendesigningequipment,refertothe"DeliverySpecification"fortheWinsokpowerproductthatyou  Intendtouse. 9,thiscatalogprovidesinformationasofSep.2014. Specificationsandinformationhereinaresubjecttochangewithout notice.
WSD3067DN56 价格&库存
很抱歉,暂时无法提供与“WSD3067DN56”相匹配的价格&库存,您可以联系我们找货
WSD3067DN56
  • 1+1.44480
  • 10+1.36080
  • 30+1.19280
  • 100+1.06680
  • 500+0.98280
  • 1000+0.92400
库存:994
